04-01-2023, 11:59 AM | #23 |
Unapologetic Tool Hoarder
736
Rep 966
As for the 3rd brake light location. I referenced the wiring diagrams in TIS and it uses connection X974*1V. I'm attaching a screenshot of the wiring diagram. For me, there were 2 options, either tone/trace the wire coming from the BDC and tap in somewhere along the way or just tap in up by the 3rd brake light before the noise filter. Was just the path of least resistance for me. Same reason I tapped the CAN connections in the rear versus pulling panels and running back the BDC.
PS - I totally get being OCD about the wiring. I actually ordered twisted pair wiring in the same color scheme to match factory for the CAN. I didn't want anything to stick out as "aftermarket" or be obvious if I needed the vehicle serviced. |
04-01-2023, 03:19 PM | #24 | |
Rep 20
I see that the BDC is mounted in the front passenger well. I wonder how the wires are run from the BDC to the rear driver side? As you said, I don't want to have to remove any more panels than I have to. Did you notice what direction that black wire ran? Is the 3rd brake light the only solid black wire in the car wiring? Where did you order the right color twisted wiring? I was unable to find the blue/gray brown/gray twist. From my EE days I know the varied rate of twist is important to reject different frequencies of electrical noise. Final question for now, can you program this with BimmerCode or do you need something more powerful? Thanks, Chris |
04-04-2023, 09:47 AM | #25 | |
736
Rep 966
On the coding, I used ISTA since it was a new module and needed both firmware flash and coding together. ISTA already has this retrofit listed as an options is you basically just click the checkbox and it updates the vehicle order at the same time so no recoding after OTA updates. |
06-12-2023, 09:12 AM | #26 | |
Rep 2,084
Current '21 DG X5MC, '22 X5M50i, '11 E90 M3
Recent Past '12 E92 M3 ZCP, '08 E93 M3, '18 F80 ZCP, '04 E46 M3 I think I have an M3 problem. |
11-20-2023, 01:00 PM | #28 | |
Rep 2
I sent you a PM not sure if it has been sent since it is a new account to me. I have a 2021 X5 without the 8SL option. Please do let me know the cost for your wiring harness and lead time. Also some advise on how to fish the lines through the rubber hose at the tail gate. I have an E60 and I have ISTA and INPA. Not sure if it can read the G05. Please advice on what software and cables I need in order to communicate with the car? Thank you! |
01-14-2024, 11:13 AM | #30 |
25
Rep 44
The parts and evertything listed should be listed at the beginning of this post if you go back to page 1. Screen shot or save the page/website so it makes it easier for you to review if necessary. You’ll basically be making a wiring harness that you’ll splice into the cars system and plugs into the modules you’ll need to buy. It sounds more difficult than it actually is and worth it for an open style install.
taaz20@outlook.com10.50 |
01-21-2024, 08:51 AM | #31 | |
Rep 18
02-12-2024, 02:26 PM | #32 | |
Rep 18
Hello did you have the chance to also log what you did as well as reference to follow. THANKS! for all you guys have done helping members out |
02-12-2024, 04:55 PM | #33 |
736
Rep 966
02-14-2024, 03:05 PM | #34 | |
Rep 18
03-07-2024, 08:20 AM | #35 |
Rep 10
I just came by to mention that my car actually came with the 8SL package, but this is a great thread. Exactly what needs to be documented on forums.
03-11-2024, 01:54 AM | #36 | |
25
Rep 44
03-23-2024, 05:51 AM | #37 |
Rep 7
Thanks so much for sharing the write-up and the video! Very helpful and detailed instructions, appreciate time and effort to post this.
I’ve got the parts and will be doing the same myself soon. I have a G06 though, not G05. Does anybody have an idea if the wiring in the fuse panel is the same? |
04-26-2024, 01:46 PM | #38 |
Rep 1
Any updates?
I recently bought a new 2024 X5 unknowingly without the S8L option. I really appreciate your guide to create an OEM compatible pigtail for the electric harness. To date, are there any updates on this technique or commercially available kits?
05-14-2024, 03:33 PM | #39 |
Rep 400
I find it totally unacceptable that BMW advertises this SUV to have a 7200lb towing capacity yet doesn't install the 8SL as a matter of course, or at least make the module easily installable.
Makes me want to sell the car. Just absurd.
2020 M2 CS
1978 911 SC 1988 Landcruiser |
