06-11-2023, 06:43 PM | #243 | |
Rep 6,948
The EVSEs sold in the USA tend to all have a tethered cable, but if you're at a public charging station, like maybe at work, where you might need to share the connection, leaving it unlocked so someone else could start a charge when yours was done is nice without having to unlock it for them. It also has it's issues if you're paying for it...in theory, someone might be able to disconnect it, plug it into theirs, and the charges wouldn't stop on your account. I don't think that's a common thing, and may not work with all units, but is a consideration, too. |
KT_OH45.00 |
06-11-2023, 06:54 PM | #244 |
Rep 589
Costco has JuiceBox 40 Amp with NEMA for $530 right now: https://www.costco.com/juicebox-40-a...100574926.html
06-11-2023, 06:59 PM | #245 |
Rep 589
My fuse panel is as far away from where I park my car as possible. I'm getting quotes to install a NEMA-50 plug near the garage, but it's ridiculously expensive. I may be charing this thing with the included Level 1 charger for the foreseeable future...
06-11-2023, 08:49 PM | #247 | |
Rep 3,761
06-12-2023, 08:36 AM | #248 |
Rep 118
I just had mine installed. It was $2,200 in total - the wire alone was ~$1,000. Same as your situation the panel to the garage was a 100 ft run and 2/3 of that was through a finished basement.
06-12-2023, 02:40 PM | #250 |
Rep 6,844
Because these companies produce EVSE's as a main business. They are likely more reliable, cheaper, and more robust. For a PHEV, fancy EVSE's are kind of a waste.
06-12-2023, 02:52 PM | #251 |
184
Rep 337
Don't over analyze as I did. Is not that important, they charge and offer some characteristics, but you will be fine with either one. I ended up buying an Emporia..
06-12-2023, 03:39 PM | #252 |
Rep 132
BTW, i got the bmw wall charger. the electrician said there were NO instructions in the box. he set it up and I plugged in my new X5 and ...nada! I searched the internet and found the correct (i hope) rocker switch settings. we tried it and it worked. so caveat emptor if you go bmw.
06-12-2023, 04:10 PM | #253 | |
184
Rep 337
06-12-2023, 07:39 PM | #254 |
Rep 6,948
The first thing to check is if your electric utility offers any specials when you install a particular one. Other than that, any EVSE will charge your vehicle. Some offer features you might want, but they also have more that can fail. I'd like it to have a UL listing, and my preference is to get one that is hard wired in place...every extra connection is another potential source of a problem.
06-13-2023, 04:59 PM | #255 |
Rep 589
Anyone tried one of these instead of running a brand new wire all the way back to the fuse panel? https://getneocharge.com/pages/smart-splitter
06-13-2023, 05:28 PM | #256 | |
Rep 3,761
https://splitvolt.com/?absrc=Google&...BoCx7kQAvD_BwE I choose splitvolt manly because the input and output plug can be different. In my case, I need the splitter to plug into 14-30 (dryer output). The split into 14-30 for dryer and 14-50 for EVSE. Neo doesn't have such an option. Other than this, I do think this is a great option for EVSE if you have dryer in garage Another important note, dryer circuit only allow 24A sustained draw, so you must have 1)a 24A EVSE or lower. or 2)EVSE with user selectable max current. Set to 24A in this case.
2022 G05 B58/PHEV
+ a few very old BMWs |
06-13-2023, 07:07 PM | #257 | |
Rep 589
06-13-2023, 07:28 PM | #258 | |
Rep 3,761
If you dryer is close to panel, I would say it maybe cheaper just to run 50A circuit. The expansive part is the distance/wire. If 50A plug can be next to panel it is cheap, maybe cheaper than this splitter. As for extension cord, as far as I know, you should not run extension cord for L2 EVSE. But it is your call. I personally won't do it.
2022 G05 B58/PHEV
06-13-2023, 08:09 PM | #259 | |
Rep 589
I figure if I get a JuiceBox, I can set the current limit to 24A. If I do the same in the car, there is redundancy. If for some reason both of those fail, I figure I'll just trip the 30A breaker. Or, instead of using the JuiceBox or BMW charger, I can just purchase a charger that only pulls 24A, like this one: https://splitvolt.com/products/cgb-nema-10-30-24-amp Depending on how long the JuiceBox power cable is, I may be able to reach the dryer plug. Otherwise, they sell these: https://splitvolt.com/products/egb-n...40775381385356 Last edited by krypttic; 06-13-2023 at 08:22 PM.. |
06-14-2023, 09:35 AM | #260 |
TiggsBimmer
Rep 1
Autel
We have the 50e and use the Autel charger. Great looking charger 25 foot cord and the software is pretty easy to use. You can change your charge current from 48 v down to what you need. I know like charge point you have to call. For the money well worth it. Those that have the Grizzle what do you use for software?
https://autelenergy.us/pages/residential |
06-14-2023, 12:34 PM | #261 | |
Rep 118
Energy costs are already low and we have supplier choice. I could get off peak rates with my local utility, but have to take their pricing to do that. Lots of choices for other suppliers here and their rates more that offset benefit of off peak charging. Our transmission and generation cost was $0.055 / kwh. That went up in June, but still fairly reasonable. |
06-15-2023, 03:26 PM | #262 |
64
Rep 49
Hey All -
Recently got my BMW Wallbox Gen 3 installed and interestingly could not connect to Wi-Fi to do a firmware update. My electrician reached out to Wallbox who subsequently directed him to BMW who stated that currently, there is no way to connect to Wi-Fi and that it will work fine. My 50e is still on order so I’ll confirm upon receipt. But wondering if anyone had thoughts on never being able to do a firmware update. My settings are already set to 40 amps and it’s in my garage so no concerns with other cars “stealing” my electricity. Any other potential issues with no firmware updates? It’s my first hybrid vehicle. |
06-15-2023, 09:14 PM | #263 |
Rep 6,948
I haven't looked at the user's manual for the BMW EVSE, but it should work just fine as a 'dumb' EVSE. The smarts may help you set some automations and calculate some statistics, but those aren't required to feed your X5 power.
