10-11-2023, 10:21 AM | #23 | |
Rep 1,106
10-11-2023, 10:31 AM | #24 |
Rep 3,751
I don’t dispute the need to keep tires within certain diameter, but 2mm!! For reference, I just measure US penny thickness, it is 1.5mm. So please think if 2mm is reasonable and realistic. Also think what actual the transfer case is doing, it cannot use 0.2% as criteria to start engaging clutch, if so, clutch will be engaged when you make a turn, when you go in those freeway round about. …. Basically all the time when car isn’t doing dead straight.
2022 G05 B58/PHEV
+ a few very old BMWs Last edited by eelnoraa; 10-18-2023 at 02:30 AM.. |
10-11-2023, 11:04 AM | #25 | |
Rep 76
Installing non-factory tires may cause you more problems, especially denying with warranty covered service. https://f15.bimmerpost.com/forums/sh....php?t=1740387 |
10-11-2023, 11:24 AM | #26 |
Rep 3,751
I would also add, thread depth is merely a approximation when the accuracy is in the unit is mm. Also need consider psi, temperature, load …. It is an unmeasurable quantity without some precision instrument. We are taking less than a thickness of an US penny, at the height of the car.
If bmw need that kind of tight toloraance in tires, these cars are too fragile, needs to be parked in garage and never been driven. And sure this will be my last and only xdrive car.
2022 G05 B58/PHEV
+ a few very old BMWs |
LuckyBrand1448.50 |
10-11-2023, 12:32 PM | #27 | |
Rep 1,106
Don't casually dismiss the importance of tire maintenance. TPMS is now mandated on all cars sold in the U.S. because most people would otherwise ignore their tire pressure, endangering themselves and others. Cruising down the expressway at 75 mph, remember your life is riding on 4 rubber donuts. Warranty voiding as a consequence of non-OEM parts is pure B.S. See https://www.ftc.gov/business-guidanc...ctions-repairs But I would agree that lifting your suspension, adding wheel spacers and mounting oversize wheels and tires can cause you warranty problems and possibly insurance problems. |
Swappy539.00 |
10-13-2023, 09:31 AM | #28 |
Rep 134
UPDATE.
Oct 9 Canadian Thanksgiving so everyone was off. Oct 10 Warranty replacement approved. Oct 11 Transfer case part ordered. Oct 12 Originally supposed to be shipped from Vancouver but they only had one and apparently it was already used for another client. So now they have to ship it direct from Germany and will take up to 2 weeks. Oct 26-27 Expected time of transfer case replacement. |
X3_Alaska161.50 |
10-17-2023, 04:29 AM | #29 | |
Insta~ f10_sapphire
158
Rep 412
Now I'm out of warranty. When the unit was replaced initially I had warranty still. Part number 5 or 12-14 is what I suspect if it's not that there's something bigger defective on the new unit to leak. Last edited by F15_SGM; 10-17-2023 at 04:51 AM.. |
10-17-2023, 04:54 AM | #30 | |
Rep 272
Personally, I had heck a lot of problems with that car[1].. Here was the last point that I simply sold this piece of shit - https://g05.bimmerpost.com/forums/sh...3#post29734283 [1] During my 30k KM (I bought the car new) dec.2020-jan.2023 - 1) H&K amp 2) entire gearbox unit 3) driver’s seat’s frame 4) A/C compressor 5) Driver’s door handle’ merino leather 6) Exhaust tips 7) Ambient light leds 8) something was changed inside the driver’s seat as ventilation failed 9) also had problems with creaks/noises/etc.. The car was at the dealer during my 2 years ownership about ~25 times. I'm not counting several visits when they replaced leather or fixed bumper alignment...as they have their hands growing from you know what place that is.. |
10-17-2023, 11:47 AM | #31 | |
Rep 630
10-17-2023, 01:20 PM | #32 |
Rep 272
10-17-2023, 01:21 PM | #33 | |
Rep 124
10-17-2023, 08:40 PM | #34 | |
Rep 116
funny how that goes
Oh, talk about timing! Just after seeing this post, my transfer case started acting up too. It threw a "Drivetrain malfunction". Now I'm stuck waiting for a whole transmission tear down, all because of some tiny $8 part (torque converter shaft seal). Thank god for the extended warranty!!!!, though. BMW's handling it without making me spend a dime. This got me thinking, does this happen a lot? Also, I'm playing with the idea of getting another extended warranty, in case they don't fix it right and something else decides to bail on me. |
10-17-2023, 08:54 PM | #35 | |
Rep 134
10-18-2023, 02:14 AM | #36 | |
Rep 272
I no longer own bmw because of that. Though, I had 740Le bought as a 1yo car. And my x5 was a brand new custom ordered car. Thanks to those unprofessional people, I no longer want bmw |
hotvee141.00 |
11-02-2023, 10:17 PM | #37 |
Rep 134
UPDATE: Parts arrived from Germany. Repair has been completed to the tune of $12,000+ but covered under warranty. The parts also carry a warranty of 2 years.
Here’s the bill from BMW attached. Any thoughts? |
11-05-2023, 10:33 AM | #38 |
17
Rep 41
This scares me to death
I get a slight shudder when I back into my driveway and I just pretend to ignore it... how rough is the shuddering? Mine is very faint. 70k on it |
11-05-2023, 10:46 AM | #39 | |
Rep 134
Do you have warranty? |
11-05-2023, 01:22 PM | #40 |
Rep 7
Sorry for potentially dumb question but is this issue only associated with ‘X’ Drive? I’m assuming the transfer case is for the AWD system, not the 2WD ‘S’ Drive.
11-05-2023, 01:27 PM | #41 |
Rep 3,751
Yes. Rwd doesn’t have transfer case nor front differential.
2022 G05 B58/PHEV
02-07-2024, 05:02 PM | #43 |
26
Rep 31
"I changed out my OEM runflats (275/40R22 front & 315/35R22 rear) and squared up with a set of 275/50R20's, which keeps front and back diameters identical and changes the diameter/circumference by only +0.3%. Most important, these Michelins are rated with 60K treadwear, and I can rotate the tires every 5K to even out the wear. Others might disagree, but I believe this is a better configuration than OEM as far as the transfer case health goes. I check the tread depth and wear every couple thousand miles, and monitor the pressure almost every time I drive."
This is something I'm trying to understand. The 275/40R22 & 315/35R22 are practically identical, aside from width. There is zero difference in diameter, sidewall, and circumference. Wouldn't this make xDrive safe from transfer case issues? I want to put these on my X5, but obviously the TC issues scare me. Although these sizes are more comparable in favor of transfer case health than the 275/35R22 & 315/30R22 my vehicle came with, which have differences in circumference, diameter, and sidewall. Seems like a no brainer to go with the 275/40 & 315/35, what am I missing? |
