01-01-2024, 02:04 PM | #463 |
Rep 3,757
I would say at least ask what it take to use copper. You can prep a little by looking at Al vs Cu cost difference at Home Depot or Lowe, and see if what the incremental charge make sense.
My very personal tske is this. Current NEC code isn’t really setup with EV charging in mind. This usage is kind of new, like drawing 40A continuously for a many hours. Not to say NEC isn’t safe enough, because NEC has tons of build in margin. As TurtleBoy said, when use Al wire properly, it should be safe. My comment is more based in the cost difference vs total cost of project. If it is small portion, I personally will go with Cu. But say if the cost increase is 50%, then I may stay with Al. Btw, pulsar wall box is a good choice. And I am with krypttic as well, start to think about where you want evse to be in my garage. It will likely dictated by how you park inside. But do decide that instead of let electrician decide for you.
2022 G05 B58/PHEV
+ a few very old BMWs |
01-01-2024, 02:23 PM | #464 | |
Rep 585
I would also strongly recommend you hardwire the charger rather than using a NEMA plug. Most electricians go the NEMA route because they have done a lot of them at customer request. However, if you also run a neutral wire (but leave it unused), that will allow you flexibility to install a NEMA outlet, sub panel, etc. in that same area later on if want. Again, it's about flexibility and paying a little more now instead of a lot more later. |
01-01-2024, 02:28 PM | #465 | |
Rep 3,757
2022 G05 B58/PHEV
01-01-2024, 02:54 PM | #466 | |
Rep 585
As no neutral is required for hardwiring, I specifically requested that my electrician install one anyway in case I wanted to wire something different later that required one. It's a lot cheaper to run an extra wire now in the same conduit, and it sounds like you're already paying for it in your contract. You should also consider if you want to run any extra wires for more plugs, etc. in your garage now. Just have a conversation with your electrician rather than accept whatever their vanilla plan is. You're the one that's going to have to live with this installation, after all. |
01-01-2024, 03:39 PM | #467 | |
Rep 3,757
As to plug vs hardwire for 50A circuit, I would like to see any electricians make they claim with proper justification. So far, there is only one person here making up lies and show video that actually show hard is worse. But that video has a lot of credibility issue. The one less failure point argument is actually very laughable. Everything we add in life is additional failure point. I am open to new information.
2022 G05 B58/PHEV
01-01-2024, 05:09 PM | #468 |
Rep 585
Here's the top hits of a Google search for "Nema or Hardwire EV Charger":
https://www.kuhlmanelectricalservice...s-nema-outlet/ https://tothelectricllc.com/is-it-be...in-ev-charger/ https://www.reddit.com/r/evcharging/..._read_that_an/ Just do your own research and make the best decision for you. Personally, I had no need for a plug so I chose to hardwire. If you do choose to hardwire, as eelnoraa says, your electrican may indeed skip the neutral. I would insist they don't let that happen. |
01-01-2024, 05:38 PM | #469 | |
Rep 3,757
Have to say tho, first link is pretty good and subjective . 2nd link, a lot of blanket general, but misinformation. I am not bias toward one vs the other for a 50A setup. I think both are good. It really depend on one’s need. But I don’t like mis, fear monga information. Some are plain low for so specific agenda.
2022 G05 B58/PHEV
01-01-2024, 06:33 PM | #470 |
Rep 6,946
The reliability of the socket can vary. What you really don't want is the plastic one that often goes for about $20 or so, but one made of Bakelite that is like 5x the cost. While the plastic ones are fine for say a stove that will have the elements cycling on and off, with an EVSE, the load is constant, so it doesn't have much chance to cool off in the interim.
A socket is not indicated as ideal if you expect to be removing and reinserting the EVSE's plug (like maybe to take it to a vacation home). There can be some significant heat buildup caused by the repeated heating/cooling of the wires and the blades in the socket expanding and contracting leading to loss of temper. Loose connections mean more resistance and thus more heat. You can find examples of even level 1 receptacles melting when things are plugged into one...your planned EVSE can pull a LOT more current, making any deficiency more problematic. You can find online wire resistances, and then calculate how much power is lost in just the lines. 100' is a fairly long run, so voltage drop and resistance all start to matter. You might want to consider running an even heavier gauge cable to a subpanel. That would also tend to minimize the voltage drop and waste heat. Not useful if you think you'll never want any other electrical devices in or near the garage. This is from a Tesla user forum... Last edited by jad03060; 01-01-2024 at 06:45 PM.. |
01-01-2024, 11:56 PM | #471 |
75
Rep 373
Hi All and Happy 2024!
Query: is the Tesla Gen3 charger adaptable to the 50e? I'm looking at installing another Tesla charge point in my garage (already have a Model Y with a Tesla Gen3 charge point). Thanks |
01-02-2024, 12:28 AM | #474 | |
Rep 296
As mentioned many different brands. I use a TeslaTap. |
eelnoraa2088.00 |
01-02-2024, 02:22 AM | #475 |
Rep 6,946
Look at the max current a particular adapter can supply.
On some of the Tesla EVSEs, you may need to flip a configuration switch, otherwise, it may refuse to charge a non-Tesla vehicle, but given those two cravats, it should work. |
03-05-2024, 08:54 AM | #477 |
Rep 3
THANK YOU!
Been meaning to write this post for a while now but better late than never... I just wanted to thank all those following this thread who posted to give me input on my EV charger install. I took your advice and insisted on getting all copper, all 6 gauge wire and a neutral wire installed and left in the junction box for potential future use. I feel great about the final install and knowing that my install is "over built" and should never have an electrical issue moving forward. Been using the EV charger for a couple months now and I have had virtually no issues with it. What more can I ask for?
Anyway, just wanted to thank those on this thread that took time to help me out since I was completely clueless about all this stuff. Much appreciated!!! |
