10-30-2023, 11:55 AM | #45 | |
Rep 8,873
Drives: eVeRyOnE mAD!
next time you’re in a similar travel/mileage situation, don’t activate Battery Hold and let us know how many electric miles the 50e maintains at minimum. again, it will do this regardless of activating Battery Hold |
eelnoraa2086.50 |
10-30-2023, 12:11 PM | #46 |
Rep 3,751
Yes I agree with nZtiZia on this. With 45e, there is no battery hood feature, driving in hybrid will get 2-3 miles worth of HVB just from regen, sport mode will get 5-6 miles, given there is just a little slow traffic or down hill in the route, where you can coast.
Overall due to 7-8th gear advantage, and TU2 can run miller cycle, I do expect 50e go to better on highway.
2022 G05 B58/PHEV
+ a few very old BMWs |
nZtiZia4754.00 |
10-30-2023, 12:43 PM | #47 | |
Rep 3,751
I can also share some read out from quite a few members here, of course with their name redacted. 😁
2022 G05 B58/PHEV
10-30-2023, 03:14 PM | #48 |
75
Rep 373
Are 50e owners getting around 45 - 50 miles on full electric around town? BMW says"up to 110km" full electric, hopefully I get up to 80kms (49 miles)
10-30-2023, 03:19 PM | #49 |
Rep 3,751
Which country matter to the answer. US get much less than Europe, maybe average to 40-42 miles from what I read.
2022 G05 B58/PHEV
10-30-2023, 04:48 PM | #51 |
Rep 29
Not sure how helpful these numbers will be. They include SUBSTANTIAL Battery Hold & Sport Mode use to force ICE operation (and yet I still have a few dozen miles during this trip to complete break-in). So, not really reflective of "normal" or efficient driving behavior.
10-30-2023, 05:09 PM | #52 | |
Rep 3,751
2022 G05 B58/PHEV
cat3dual33.00 |
10-30-2023, 05:34 PM | #53 |
Rep 29
Thank you for the insight. When I finish break-in and have my fun, I'll reset the "Trip Individual" and track for the next couple thousand miles and see what "normal" looks like. My ICE use is going to decrease dramatically.
10-30-2023, 11:55 PM | #54 |
Rep 3,751
as promise, here is a list of members that gave me their trip computer read out. There are more entries, just need to filter them to make sure data is valid. In this table, I sorted the total miles driven from top because they are more valid data. The last column are ICE MPG and EV mile/kWh after I separted ICE mile and EV mile. The green box means reading is maxed out, so actual number should be higher. The red box indicated data definitely not valide
I also plotted histogram. Majority of data point for mile/kWh fall between 1.81 to 2.03. Highest is 3.44, I had doubt but we discussed and think it is valid. It is from member is very unique location and driving style. 3.44 is about where Tesla Model Y average is. This member has some of the finest control right foot, very impressive. You know who you are. As for ICE MPG, I take these as combined MPG, majority is right at 22MPG. This does NOT include my own data. But my own data match this result. I did about 7 tanks of gas, across 3.5 months, without charging HVB. Result in 22.x MPG combined as well. 45e and 50e member feel free to send me your trip computer read out, I will log these and update once in a while or upon request. You name will of course be redacted out.
2022 G05 B58/PHEV
+ a few very old BMWs Last edited by eelnoraa; 10-31-2023 at 12:05 AM.. |
10-31-2023, 12:35 AM | #56 | |
Rep 917
10-31-2023, 12:54 AM | #57 | |
Rep 3,751
not sure if average speed record is available on 50e trip computer. I found both ICE MPG and EV mi/kwh are almost linearly proportional to average speed. Linear fit equation is: MPG = 0.17 x (average speed in MPH) + 18.5. valid average MPH range is from about 20MPH to 50 MPH. the error on this one is small. I only need to throw out one outliner. mi/kwh = 0.0444 x (average speed in MPH) + 0.959, valid average MPG range here is 11-36MPG. this one still fit pretty well. threw out two data point, including one show 0.39mi/kWh with average speed of 48MPH, which doesn't make sense at all. I can easily do 2.3Mi/kWh at 48MPH. Majory average MPH is between 20-25. Keep in mind, these are mostly since factory. You can certainly have high average MPG on a road trip, but it seem overall the life if the cars, average MPH is quite low. It kind of make sense, because it is mile per hour. The dominator is time, meaning for the same miles, the car spend a lot more time at slow speed. I can accept this explanation.
2022 G05 B58/PHEV
+ a few very old BMWs Last edited by eelnoraa; 10-31-2023 at 01:09 AM.. |
cat3dual33.00 |
10-31-2023, 01:10 AM | #58 |
Rep 917
10-31-2023, 01:58 AM | #59 | |
Rep 29
A
Total Miles Driven: 2140.8 Actual Gals + kWh Equivalent Gals Used: 49.9+13.1 = 63 2140.8 / 63 = 34.0 mpge Once I stop using the ICE in the city where it's not efficient and mostly just use the battery, I'm hoping to improve significantly on that number! Last edited by cat3dual; 10-31-2023 at 02:26 AM.. Reason: Modify terms used |
10-31-2023, 04:28 PM | #61 |
Rep 6,946
Regardless of the mode selected, you will still get some augmentation from the EV motor. There is no way to totally disconnect the EV motor from helping out when the computer dictates it's useful. So, even in sport mode, you're getting some EV help at least sometimes.
10-31-2023, 04:41 PM | #62 | |
Rep 3,751
10-31-2023, 04:44 PM | #63 |
Rep 3,751
So the Actual MPG is driving in pure ICE mode, not in hybrid?
In my calculation, there is limitation. It is estimating pure ICE mpg. The kWh from regen will get added to kWh used and Edrive miles. So technically hybrid mpg will be higher. But since regen is rather weak in 45e, I think error should be very small, single digit percentage. Another reason I make this claim is I did drive the car for 3.5 months without charging, result combine mpg is still 22.x, very similar to if I did this calculation for my car. There are so much misinformation on the drive chain, mysterifiy information. The fact is, very rare both Edrive and ICE drive the car at the same time. Even in those 30->85mph hard acceleration in sport mode, eDrive won’t kick in. From what I have seen only hard acceleration from very slow speed in sport M/S mode, both ice and Edrive will work together for a few seconds. So for practical purpose, eDrive and ice are really working independently for majority of driving conditions. |
10-31-2023, 05:05 PM | #64 | |
Rep 917
The hv battery does charge the 12v system which run the vehicle electronics; but that is not very relevant to this discussion |
10-31-2023, 05:13 PM | #65 | |
Rep 3,751
Adding one more piece of detail. 45e really need eDrive to help to achieve good 0-60, because 45e's first gear is unusually tall. If not for eDrive, it will be bad for acceleration and clutch wear. First gear ratio comparison 40i: 5.25 45e: 4.72 50e: 5.5 looking at these 50e has the best 0-60 also make sense. 1st gear is very short to achieve a great launch, maybe even eboost isn't needed much
2022 G05 B58/PHEV
+ a few very old BMWs Last edited by eelnoraa; 10-31-2023 at 05:22 PM.. |
10-31-2023, 06:39 PM | #66 |
Rep 6,946
Depending on your current speed, and how far you press the accelerator, you can get both the ICE and EV motors to work simultaneously in all modes. It may only be for a very short time, and may not record as distance traveled in EV mode since the ICE is running, but you will get the advantage of the EV motor in all modes.
tooloud10796.50 |
