      08-28-2009, 10:09 PM   #45
mkPOTO
Mr. Nice Says Hello
mkPOTO's Avatar
638
Drives: BMW M3 | X5 xdrive 35i MSport
Subscribed
      08-28-2009, 10:18 PM   #46
Pay2play
Chief
Pay2play's Avatar
Drives: G01 M40i
Cool
2018 X3 M40i
      08-28-2009, 11:56 PM   #47
Buffalo_Bush
Drives: 07 E92 335i
Originally Posted by O-cha View Post
I wonder how many other people went from the 335 to older and way more powerful BMWs?
My 335 lease is up in a couple of months... Im about to buy an e36 M3 as well....
      08-29-2009, 11:54 AM   #48
94JZA80
Drives: 1994 BPU Supra
subscribed
      08-29-2009, 05:11 PM   #49
SMA335i
SMA335i's Avatar
Drives: 2012 BMW 550i
subscribed
      08-29-2009, 08:13 PM   #50
positiveions
positiveions's Avatar
Lebanon
962
Drives: 19 Tacoma, 16 Golf wagon
Sniz, great work mon amie. I don't know about S/C either. I used to own an '95 OBDI E36 M3. I purchased some goodies before I ended up w/ a Blower from Dinan. I had Schrick cams on it. When the Blower was added, torque wasn't readily available 'til like 4k rpm; which I was disappointed at, because when I drove a Dinan tuned '96 M3, the car was a jet off the line. That made me purchase the blower. Even my mechanic told me there is a lag and that we should remove the cams. He said the window of power moved quiet a bit. But upper power was a plenty. It pulled hard all the way to 165 mph (not going to say where I pulled that off )
GL w/ the "renewed" project.
      08-30-2009, 02:23 PM   #51
02black330ci
02black330ci's Avatar
Drives: 997 Turbo E90 M3
Awesome pics and thanks for the update bro.... I'll have to visit you guys at the garage sometime, I am in the college park area!
Is the engine built at all, head, bottom end, etc? What is the stock limit to the e36 engine under boost? What turbo system did it come with?
Thanks again for the posts man!!
      08-30-2009, 02:28 PM   #52
Sniz
Sniz's Avatar
661
Drives: e92 335 - gone // e36 M3 turbo
hey man, yeah you'll have to come hang out for sure
the bottom end of the motor is all stock w 85k miles on it. Thicker MLS headgasket and ARP studs have dropped the compression ratio though.
stock engine has been good for most people until 650whp or so. I dont plan on getting to that point but when its necessary i'll build the motor.
car came with a Technique Tuning stage II setup, great kit.
      08-30-2009, 07:37 PM   #53
Sniz
Sniz's Avatar
661
UPDATE 8/30
Got a little more time....30 minutes or so and opened up the 35r to "reclock" it and rotate the compressor housing to match the old turbo. Also took the time to degrease and clean the compressor housing.
Nothing crazy, more coming tomorrow night....god willing it will be mounted.
Got it apart
Compressor
Housing (no gasket)
Rotated to match the 60-1
Random parts laying around the garage, will have these organized and cleaned tomorrow too
Downpipe and Wastegate pipe
mid pipe and charge pipe
      08-30-2009, 09:52 PM   #54
Eazy-e
Dope-like a pound or a key
Eazy-e's Avatar
12
Drives: 09 e82 135i
nice!
      08-30-2009, 11:55 PM   #55
MisterSkiMask
147
Drives: I Can not say
Loving this project.
      08-31-2009, 04:14 PM   #56
OverDrive
CHEAT TO WIN!!
OverDrive's Avatar
101
Drives: E92 M3, 718 GT4
+1.
Awesome car Sniz!
keep us updated!
________
HONDA E SERIES HISTORY
________
TOYOTA SPORTS 800
________
Vapir No2 Review
________
Headshop
      08-31-2009, 09:15 PM   #57
Sniz
Sniz's Avatar
661
UPDATE 8/31
UPDATE 8/31
Spent about 2 hours working on the car/turbo tonight.....work keeps getting in the way of my fun!!
test fitted the gt35r to find 2 points of contact with the transmission/engine block.
Problem #1
This fitting for the vacuum hose for boost control is in the wrong spot. Previous owner had the compressor housing 180 degrees in the other direction so it worked for him. Had to remove it. Will find a brass plug for this hole tomorrow and find someone to retap in a better location.
Problem #2
and then the exhaust housing is/was contacting the transmission here. Spent about 30 minutes with a grinding wheel and got my clearance
ITS ON BABY
ok, well now its off, have to get that fitting retapped tomorrow and then it will be on for good.
I have a weeping oil pan gasket and rear main seal as you can see here. These will be addressed this winter once I have more downtime on the car.
thats it for today
      08-31-2009, 09:33 PM   #58
TK-421
Registered Sex Offender
Drives: E46 M3 | 1JZ S13
I can't take it anymore, I need dynos! Videos!
Stop putting stuff like painted reflectors and premium package in your signature. You're embarrassing.
      08-31-2009, 09:48 PM   #59
Sniz
Sniz's Avatar
661
lol....you and me both man!!
      08-31-2009, 10:13 PM   #60
OnTilt75
Drives: Evo 8, B5 S4, 335i, VW Corrado
No offense, but I do not see why this project is such a big deal. If maybe you were doing a 1000+whp project then thats a little different but you aren't even going to come close to that, but it will be a pretty QUICK car.
      08-31-2009, 10:16 PM   #61
hkbaby
BEEP BEEP
Hong Kong
Drives: 996
the reason for this car is for him to rebuild a clean/reliable/daily driver e36 turbo M3. not to create a serious 1000whp car.
I find it interesting and kinda of a big deal, considering he went from a 335i e92 to a e36.
2003 911 Turbo | K24/18G | Bone Stock Exterior
      08-31-2009, 10:24 PM   #62
Sniz
Sniz's Avatar
661
no offense taken. Its not a big deal to you, it is to me since its something i'm doing myself. You dont need to read my posts. Not like i'm spamming your inbox with updates.
thanks man......maybe i'm just crazy for building a 500-600hp daily driver
at least i dont think so
      08-31-2009, 10:34 PM   #63
OnTilt75
I guess it was the higlight on the main page of E90post.com showing this build that made me come to the conclusion that it was a major deal.
      08-31-2009, 10:35 PM   #64
Sniz
Sniz's Avatar
661
its cool
I guess one of the admin's here like the thread so they put it up there.
back to me hacking up my car....
      08-31-2009, 11:20 PM   #65
lee.minwoo_
instagram: black.listed_
20
Drives: e92.| e90.| E70.| P. | Duc.
damn! cant wait to see the final results of this monster!!
| Instagram: black.listed_ |
      09-01-2009, 02:50 AM   #66
hkbaby
BEEP BEEP
Hong Kong
Drives: 996
