06-11-2023, 11:01 AM | #68 |
Rep 8
I would appreciate the cheatsheet if anyone can share (couldn’t PM due to new user): cxyzs7@gmail.com
06-14-2023, 04:59 PM | #70 |
Rep 453
Drives: 2017 X5, 2020 X5 & 2021 X5
Anyone wanting a copy of the cheatsheet can download a copy from the Facebook Easy Bimmer Coding group Home page on Facebook. You will probably have to join the group to access it
Current: MY 21 X5 3.0d xDrive MSport
MY 20 X5 2.5d xDrive MSport MY 17 X5 2.5d sDrive |
06-14-2023, 05:05 PM | #71 | |
Rep 453
I cannot see BMW giving online access to any third parties other than maybe Alpina which will be most likely restricted to Alpina models only
MY 20 X5 2.5d xDrive MSport MY 17 X5 2.5d sDrive Last edited by Bambazonke; 06-18-2023 at 11:57 PM.. |
06-14-2023, 05:41 PM | #72 |
13718
Rep 20,399
All but a few ECU's require server contact so only a few cosmetic items can be coded. I don't even think Bimmercode has put them on their site since it would not really be worth it.
06-24-2023, 03:09 AM | #74 | |
Rep 5
I have the same symptoms with my G01. I know iFR sir mentioned before that it only works on G05, G07.. vehicles. I also tried to enable TLA feature according to your table, but I couldn't find a suitable parameter to disable country restriction on G01. Tried disabling FA of 8TR decoding item, still failed. Hope it can be working in my country in the future. |
07-03-2023, 02:44 AM | #75 | |
Rep 453
MY 20 X5 2.5d xDrive MSport MY 17 X5 2.5d sDrive Last edited by Bambazonke; 07-08-2023 at 02:50 AM.. |
07-05-2023, 10:45 AM | #76 |
Rep 33
I coded line change assistand and is nice, visible on cluster.
But Austomatic lane assistant cant work correctly. Car is in Poland. Who can help, what is missing in standard list of codings? |
07-07-2023, 01:34 AM | #77 |
Rep 22
07-08-2023, 02:41 AM | #78 | |
Rep 453
This feature was enabled in X5's assembled after July 2019 and should be already active in your 22 X5
MY 20 X5 2.5d xDrive MSport MY 17 X5 2.5d sDrive Last edited by Bambazonke; 07-23-2023 at 09:52 PM.. |
07-08-2023, 02:46 AM | #79 |
Rep 453
It only works on certain types of road ie dual carriageways Motorways Interstates etc and above a certain speed.(70 kmph)
MY 20 X5 2.5d xDrive MSport MY 17 X5 2.5d sDrive Last edited by Bambazonke; 10-06-2023 at 05:45 AM.. |
07-08-2023, 11:24 PM | #80 | |
Rep 22
Btw, I used bimmercode to code that particular param and it worked! |
Shawzy44184.50 |
08-13-2023, 12:25 PM | #82 |
Rep 226
Drives: 2022 BMW X5 M50i
I've used your cheat sheet and coded my G05 and UCC , Highway exit both works perfectly fine just the TLA is little hit and miss i think it has to do with red lights in USA are not exactly marked on idrive maps properly sometimes i can feel that car hesitate or gets confused where to exactly stop at red light ,but thanks a lot for your cheat sheet and helping me out with the coding.
Bambazonke213.00 |
09-15-2023, 07:32 AM | #83 |
1054
Rep 1,952
Bambazonke - Do you know if BimmerUtility has been updated yet with the proper mapping for aSLA coding? my G05 was just updated to 07.2023 and I don't have the SAS3 or the VIP modules showing up in E-Sys. I'm able to code most of aSLA but get an error saying "Driver Assistance changed in this region".
09-15-2023, 10:43 AM | #84 | |
Rep 464
Run ISTA diagnostics, if you have it, to see if ISTA reads SAS3/VIP and fix any errors ISTA reports. If Esys/ISTA cannot read SAS3/VIP, try disconnecting/reconnecting your vehicle battery(ies). Sometime my vehicle communications hangs when updating firmware and can only be fixed by disconnecting and reconnecting my vehicle batteries.
2020 Black Sapphire M340iX
2014 Estoril Blue 435iX - sold |
VTENGR1053.50 |
09-15-2023, 04:28 PM | #85 |
Rep 453
BU have recently done an update to v1.0.63 Had a quick look at my cheat sheet for the SAS3 module and all the labelling is there now I will check the other ECU's and let you know.
I am still on 07.2022 reluctant to update until I am sure that Pre LCI G05's will not be affected with ECU's being locked out. As you know BU is now independent of Esys & regular updates of Psdzdata. I would try download a generic copy of E Sys and the latest Psdzdata via Shawn S on a separate laptop if you don't have ISTA as Larry suggested above. Hopefully the generic version will read be able to read all the missing ECU's. Make a copies and edit them in BU and upload and let us know
MY 20 X5 2.5d xDrive MSport MY 17 X5 2.5d sDrive Last edited by Bambazonke; 09-15-2023 at 04:35 PM.. |
09-15-2023, 08:01 PM | #86 |
Rep 453
As per my post above i have started going through my cheat sheet and have already noticed a couple of mapping errors firstly in the HU_MGU the ADAS_2DH_HORIZON_EXTENSION is incorrectly labelled NAVI_MECCA_INDICATOR and in the DSC_VIP ECU labeling for "EM_AdasIntegration_AdasExtendedPdu" is missing and must be enabled for UCC (Urban Cruise Control) to work.
I therefore strongly suggest that those who use the cheat sheet to change the coding in Comfort mode, manually check their coding changes in expert mode after they have saved it as I have also seen in a few instances another bug where after using the function preview tab some features already enabled eg Lane Change Assistant which was enabled from factory showing as "nicht aktiv" or disabled or in some cases not changed at all after coding see screenshot below.
MY 20 X5 2.5d xDrive MSport MY 17 X5 2.5d sDrive Last edited by Bambazonke; 09-19-2023 at 05:41 AM.. |
09-15-2023, 09:47 PM | #87 | |
Rep 226
09-15-2023, 10:07 PM | #88 |
Rep 453
No unless u have done an OTA update since u coded it last and u have lost all your coding modifications
postbox1918154.50 |
