08-26-2020, 12:28 AM | #67 |
Rep 446
I confirmed the HTML hex code for red as FE, 00, 00 allows the two LED lights nearing the reading lights to function as normal. FE, 00, 00 equates RGB 254, 0, 0. It appears any value maxed in the RGB spectrum (255) causes a glitch with the BMW DME that shuts off the splash LEDs near the sunroof controler. 254 R is the same to the eye, so you will never notice. I will update the original post.
*Note... for anyone creating custom colors, you should not use any HTML hex code with the value FF. Substitute FE for the FF part of the HTML hex code and it will look exactly the same but won’t affect the overhead splash LEDs that shine on the shifter area. Last edited by 130FeetDeep; 08-26-2020 at 12:35 AM.. |
08-26-2020, 08:14 AM | #68 | |
135
Rep 372
08-26-2020, 12:30 PM | #69 |
Rep 446
My opinion (I know quite a bit about the color wheel and color grading) is that we are best going 254 red versus adding G or B. Both could trick the eye a bit and I want red. 🙂
08-31-2020, 01:03 PM | #70 |
Rep 223
I just noticed that by doing the bronze colour to red and bronze/white to the blue/red combo, my green/white has also changed to a red/combo. How can I fix that?
Also, I set it to the FF combo and everything seems to be working for me, should I still recode it to the FE value
08-31-2020, 02:45 PM | #71 | |
1054
Rep 1,952
08-31-2020, 05:56 PM | #72 | |
Rep 446
09-01-2020, 09:44 AM | #73 |
Rep 268
Drives: bmw m4 csl 992 turbo S
Bmw m8
Amazing lighting
09-01-2020, 10:05 AM | #77 |
Rep 436
What's the setting to add go go dancers!?
NorCalAthlete3201.50 |
09-01-2020, 10:15 AM | #78 |
5949
Rep 10,319
09-01-2020, 10:27 AM | #79 |
Rep 984
What color code would you input to completely turn off one of the led strips? I would like to turn off the lower dash lighting. The one that runs just below the trim and vents. Is that possible?
09-01-2020, 11:28 AM | #81 | |
Rep 223
Still don't understand why BMW has not allowed to edit these profiles in iDrive. It's possible and something a $100000 car should do, especially when the competiion does.
09-01-2020, 12:17 PM | #83 | |
3202
Rep 1,669
Perhaps, but the good husbands who like to tinker (and want to bank a bit of goodwill for later, inevitable fuckups) will do it. |
09-01-2020, 05:36 PM | #88 |
fuck this field
2193
Rep 2,605
This would work on any G05, correct? Doesn't need to have certain packages or be a certain trim?
BMW family... for now.
