03-18-2023, 06:00 AM | #89 |
///M-Thusiast
3688
Rep 955
Drives: '23 X5 M50i
Why the hell does no one use their parking brake? Just. Pull. The. Parking. Brake. Up.
Is this an American thing? Curious.
Current: 2023 G05 X5 M50i xDrive
Soon: 2024 G87 M2 Past: G80 M3x, G80 M3, G05 X5, F82 M4, F87 M2C, F20 M140i |
03-18-2023, 08:55 AM | #90 | |
Rep 550
I drove a manual my entire life until about 10 years ago, so the parking brake was second nature. |
03-18-2023, 09:15 AM | #91 | ||
Rep 221
03-19-2023, 10:24 AM | #92 | |
Rep 1
03-20-2023, 08:50 AM | #93 | |
Rep 550
I recall as a much younger man, rental cars in Europe were mostly manual transmissions long after US cars were automatic. I wonder if the parking brake as second nature is more ingrained in the EU market than it is here. |
03-20-2023, 09:09 AM | #94 |
Rep 8,874
Drives: eVeRyOnE mAD!
I’m also a product of manual transmission > parking brake
03-20-2023, 03:40 PM | #96 | |
Rep 156
Somehow, the tactility of it is much more intuitive and easier to work with than the electronic window-switch lever. Hooray for the auto-hold mode that automatically engages the parking brake. |
03-21-2023, 08:00 PM | #97 |
Rep 6,946
If you drove the vehicle, but always left it in gear or park, depending on the transmission versus using the parking brake, it could easily become stiff from corrosion, and when you actually did use it, stick and be a bear to get to release.
I've only owned three BMWs, but they all have had a button to activate the parking brake, but I almost always engage the AUTO BRAKE button, so once it's stopped, the parking brake is on. All three also had a separate park button...never accidentally have left it in neutral versus park. |
03-22-2023, 04:05 PM | #98 | ||
Rep 883
M3 - X5 - 911 - Miata - Raptor - Edge
03-22-2023, 06:17 PM | #99 |
Rep 6,946
Because my parking brake gets activated numerous times each trip via the auto hold function, I've not experienced anything sticking...I do think when that is only rarely engaged is when you tend to have issues with it sticking.
03-22-2023, 06:23 PM | #100 |
983
Rep 1,562
When one thinks its not needed is usually the time when something happens that one didn't expect.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
03-22-2023, 08:01 PM | #101 |
Rep 284
Drives: 2023 X5 X45e
In my 2020 X3 M40i, when I put the car in park, and turned it off, it'd set the parking brake automatically - mainly I noticed because every time I'd get into it to go somewhere, the brake was set. I noticed the X5 45e does not do that...I've found it not set nearly every time, unless I happened to remember to set it before I exited it on the last trip.
03-22-2023, 09:48 PM | #102 | |
Rep 114
03-22-2023, 09:56 PM | #103 |
983
Rep 1,562
I have had auto hold on for a couple of weeks and find it can be annoying. I would like the parking brake to turn on when I turn the car off, but I don't think that is an option. Not sure why they tied auto parking brake to auto hold.
03-23-2023, 04:11 AM | #104 |
110
Rep 319
When the car is put into P and the engine switched off, doesn't the handbrake automatically engage anyways?
I always thought it did - will be checking and manually activating it in future!! |
03-23-2023, 04:41 AM | #105 |
303
Rep 382
No it doesn't. This is how I know it from F-Series BMWs with AT:
Engine off - Transmission automatically switches to P, no parking brake Auto Hold ON - Auto Hold turns into parking brake if engaged while turning the engine off (It just simply holds it where it was while turning off the engine) That the transmission switches to P automatically almost caused me to wreck a friends car (Alfa Giulietta with AT) since I was SO used to it that I just turned off the engine and left the car parked at a gas station, leaving it in D and not engaging the parking brake, wondering where the car went when coming back out. It only rolled a few meters forward until it was stopped by a small curb but I was VERY lucky that this didn't turn into a catastrophe. |
03-23-2023, 06:56 AM | #107 | |
Rep 8,874
https://www.bimmerpost.com/forums/sh...php?p=29910935 |
tooloud10796.50 |
03-23-2023, 07:36 AM | #108 | ||
303
Rep 382
nZtiZia4754.00 |
03-26-2023, 02:01 PM | #109 | |
Rep 156
In normal operation, such as driving around town and stopping at a traffic light, PARK is green on the dash when auto-hold is engaged. At the end of a drive, if I press the P-to-Park button on the gear shifter, PARK illuminates green on the dash. But when I power off the vehicle by either opening the door or pressing the STOP/START button, it changes to red PARK, thusly: |
03-26-2023, 02:08 PM | #110 | |
Rep 8,874
test: disable Auto Hold and perform the same maneuvers. report back. I’ll do the same. EDIT: YOU ARE CORRECT. Auto Hold engages the parking brake when exiting the vehicle. it did so after I pressed the Start/Stop button to end the trip and also opening the door without first pressing the Start/Stop button. what’s neat is when restarting the vehicle, the parking brake automatically disengages. thanks, I learned something new! for me though, I’m not a fan of Auto Hold in general. i also have the habit of consistently engaging the parking brake myself. while it’s a great safety feature, I feel regular reliance on such ‘automaticity’ opens oneself to potential accidents should it fail. if I did rely on this, I would still verify it does what it’s supposed to do before I could comfortably leave the vehicle. |
aMIC31.00 |
