01-04-2020, 09:52 PM | #133 | |
Rep 2,610
01-05-2020, 03:29 AM | #134 | |
1202
Rep 1,587
I always VO code every ECU using coding verification before attempting any VO Coding. It's the only way to identify every impacted ECU and FDL setting. So yes I have VO Coded those ECU when attempting to enable 1CR, and validated each ECU's 1CR settings post coding. As dealers don't do FDL coding and only use VO Coding for adding retrofit features, it's logical that adding this feature via VO coding and FSC would be the best BMW delivery method for retrofit. This site has forums with posts that talk about the CA bulletin for a 1CR retrofit. The bulletin itself references a subsequent bulletin which will detail the exact steps the dealer should follow to apply the retrofit. I haven't seen that bulletin, but obtaining it would be my priority if I wanted the feature active. |
01-08-2020, 10:07 AM | #135 | |
Rep 5
01-08-2020, 02:47 PM | #136 | ||
Rep 2,610
In this case and at present, I suspect only available help will come from your dealer. Considering that many that received cars manufactured before April 2019 paid for 1CR and didn't get it, a fairly strong demand for your dealers to fullfil their and BMW's contracted obligations is appropriate.
tartan4319.50 |
01-13-2020, 10:48 PM | #137 | |
Rep 27
https://cartechnology.co.uk/showthread.php?tid=59280 |
01-13-2020, 11:04 PM | #138 | ||
135
Rep 372
01-19-2020, 08:56 PM | #139 | |
Rep 27
“Hi Sorry only neaw I see I can help only for EUR cars your car is US I can't orther 17C fsc for US cars” Apparently if you know the right process you can order 17C FSC from BMW... Last edited by tartan43; 01-20-2020 at 06:36 PM.. |
12-08-2020, 07:01 PM | #141 | |
Rep 1
12-23-2020, 10:10 PM | #142 |
Rep 8,889
Drives: eVeRyOnE mAD!
i just took delivery of a 2021 xDr45e in the US but don't see a Remote Start option in iDrive under Preconditioning or in my iPhone BMW Connected app v10.9.2.2059. nothing in the manual as well.
is this no longer a feature? |
12-24-2020, 01:29 AM | #143 | |
Rep 143
You can do it on demand or schedule it through the app; I have it set up to be climatized every work day at 08:00 AM so I always get into a warm car in the mornings without having to think about it. Works like a charm |
nZtiZia4769.00 |
08-13-2021, 10:38 AM | #144 |
Rep 422
Reviving this old thread... remore engine start is now avaialble in connectted store..purchased it and..... nothing :-(
i noticed 1CR was not present so i added via VO... everything now works (meaining the sequencing with the keyfob to start the car) lights flashes but the car doesnt start.. i went back to my connected drive account and shows my vin with the remote engine start option checked as purchased... but nada does anyone know where the esys modules and fdl are so i can double check ?
2023 I4 40 Msport White/red interior 19"Rims
2023 Ix 50 MSport Hraphite Gray.Oyster interios 22" Rims Retired 2020 X7 MSport 40i 2020 I3s Bev |
09-26-2023, 05:44 AM | #146 | |
Rep 5
I'm italian. Tahnk you |
