      06-20-2023, 10:21 AM   #1
FLYZ
Drives: 2020 X5 sDrive40i M Sport
Software Update not installing 03/2023.50
I received the in-app notification a few weeks ago that the 03/2023.50 update was available for download. Next time I was on wifi I downloaded it, and next time I was in the car for a longer drive, I initiated the transfer. That was weeks ago.
Now every time I go to the Software Update menu in the car, it tells me that the update has been downloaded, but it will tell me when it's ready to be installed. What the hell is there to wait for? I can understand that maybe, MAYBE a little processing time might have been required after the update transferred from my phone to the car, but weeks or a month? I have driven the car dozens of times since them for varying lengths. Any necessary wait should have elapsed.
Should I schedule a service appointment or are others having the same problem? If this is by design and the car is supposed to wait, why would BMW push the update if it wasn't ready to install?
'20 X5 sDrive40i M Sport 21"/741M Alpine White/White Merino/Tetragon/Premium/DAPP/Lux Seating/Park AP/Glass Controls/Climate Comf./M Brakes - Blue
'22 X3 sDrive30i M Sport 20"/699M Tanzanite Blue II/Cognac/Ash/Premium
      06-20-2023, 11:11 AM   #2
Berzerker
Drives: 2024 M4 Convertible
The transfer is from the phone to the car, that probably hasn't completed. Check the MyBMW app to see what stage it's at.
      06-20-2023, 11:18 AM   #3
FLYZ
Sorry, amigo. Transfer completed long, long ago. The car shows its completed. The phone shows its completed, ready to install, follow instructions in the vehicle. Car says it will tell me when it's ready and has to be parked. Said that for weeks.
I have completed several of these in the past, so I have tried parking the car in my garage with it on. Tried it with both keys in it. Everything. The actual install just won't initiate.
      06-20-2023, 02:39 PM   #4
MotoWPK
Drives: '13 128i vert, '14 X5 40i
I experienced the same thing. Called BMW Genius who advised to give it some more time and if it still had not installed, take it to the dealer to install. After waiting a couple of weeks further with no install, did just that. Service manager advised this was a common issue with recent updates, BMW has indicated a fix is coming but there is no estimate yet as to when.
Also, dealer updates are always the latest, so 03/2023.60 was installed.
And, If you're using Bimmercode to program ASS off, that will no longer work with the update until Bimmercode comes up with a solution.
MB1003.00
FLYZ100.50
      06-20-2023, 02:46 PM   #5
MB100
MB100's Avatar
Drives: 2020 BMW G05 X5 xDrive 40i
Same on my end. Initially downloaded and transferred a few weeks ago, but no prompt to install, just wait. May take dealer option then.
FLYZ100.50
      06-20-2023, 03:54 PM   #6
nZtiZia
nZtiZia's Avatar
Drives: eVeRyOnE mAD!
I received notification on the MyBMW app for OTA update 03/2023.50 yesterday evening.
NOTE: i just came back 2d ago from vacation; for 8 days, my vehicle sat in the airport garage with 14% HV battery capacity and was unplugged, but i did plug in and charge overnight. since i connect my iPhone via CarPlay, fulfilling those 3 connection requirements were pretty much instantaneous as soon as i settled in my seat. it took 13m to transfer the update data from my iPhone to the vehicle while sitting in my garage in the drive-ready state (U.S. MY21 45e). I didn’t have to drive around
it took 15m to complete the install
most of my BimmerCodes reset as expected, but I can’t speak to ASS or dimming instrument cluster codes for I never had issues with these in the first place (thus nothing to re-code). I didn’t lose presets or any apps either. this is my fourth OTA i-Level update since ownership, and all have gone as smoothly as described above
FLYZ are you making those 3 connections the MyBMW app is prompting (wifi, bluetooth, apps)? you can't proceed to transfer the data from your phone to the vehicle until you do. also, if you have an iPhone, did you enable "Local Network" under the MyBMW app in the iPhone Settings? once transferred and assuming you are parked with the engine off, iDrive will ask you two things:
Upgrade now
Perform upgrade later
      06-20-2023, 05:48 PM   #7
chefwong
Drives: X5
All these recent posts ... I just threw mine on the trickle charger just to top off the SOC to see if it will phone home so home will send me a update
      06-20-2023, 06:06 PM   #8
Aimster82
Drives: 2018 X3 M40i 2019 BMW X5 5.0
My dealer told me it is not their problem. The update never installed and it is saying no longer available.
My warranty is over now. I guess I have to deal with it?
      06-20-2023, 08:20 PM   #9
STEALERHSIPS GONE SOON
131
Drives: X5
bmw has ALWAYS sucked at car electronics
they fcuk up everything, they don't miss ANYTHING: navigation system, steering wheel, radio going mute for no reason AM and FM, sound amplifier fried and base totally going dark, software updates not finalizing or impounding the vehicle, and so on and so on. ANd that is valid for their ENTIRE range of vehicles!
Sub-standard quality vehicles for premium prices!
those who think I'm just badmouthing, just ask me and I'll provide you documented proofs for every issue listed above.
bmw turned into: the ultimate STALLING machine
dean530.00
      06-21-2023, 08:35 AM   #10
Guy Fleegman
Drives: 2022 BMW X5 45e
I don't get it. Mine went flawlessly. I sat in the car while the update downloaded. It took about 15 minutes, max, then went into install mode after I set the parking brake.
Maybe it's the app? I know the car "confirms" it's been updated but obviously it hasn't. I have Android. Some with Apple have reported similar issues.
      06-21-2023, 08:48 AM   #11
nZtiZia
nZtiZia's Avatar
I’m guessing folks with issues may not have the proper phone settings enabled, such as Local Network for the iPhone. it should be part of the upgrade process
      06-21-2023, 08:53 AM   #12
MotoWPK
Phone settings would affect downloading to the vehicle, but the issue brought up by the OP, and that I too experienced, is the vehicle failing to install the downloaded update. This is confirmed by the iDrive reporting the software has been downloaded and will advise when it can be installed, but never does.
It is an issue recognized by BMW, according to the service manager at my dealer.
Appreciate 3
FLYZ100.50
      06-21-2023, 09:00 AM   #13
Jcit
Jcit's Avatar
53
Drives: 2024 X5 50e M-Sport
2024 BMW X5 50e  [0.00]
Same problem with my car on this latest update (and also with previous updates). I can download the update to the car via MyBMW app on my phone (wifi + bluetooth) but the software never installs in the car. It just tells me it will advise me when the install can occur but it never happens. Previously I had to bring it to the dealer to install updates as well.
      06-21-2023, 09:34 AM   #14
chefwong
Drives: X5
For those stating it will not install but it's downloaded on phone, I would try dumping it on a trickle charger to see if it will trigger it.
I can't say for sure if the parameters are SOC, but there was one instance where I had it similar and right after a trickle charge, the following drive , was prompted for the install
      06-21-2023, 11:58 AM   #15
FLYZ
OK, people who keep talking about the phone connections, I seriously don't know how much more clearly I can state this - the update has already transferred from the phone to the car. The connection works. It did work. It still works. It worked so well that the updated transferred from the phone to the car weeks ago. My phone knows it. The myBMW app knows it. The car knows it. Everything agrees that the update has transferred. It has NOTHING to do with my phone because the data is already off of my phone and in the car. I simply cannot get the car to initiate the installation of the update program. In fact, my phone keeps telling me that the update has transferred and I need to follow the on-screen prompts in the car to complete the install - the car just won't initiate it.
However, MotoWPK has essentially told me everything I need to know. Sounds like I need the dealer to initiate the install. Thanks for the help, Moto.
      06-21-2023, 02:09 PM   #16
B///MWGuy
Drives: 2019 X5 xDrive40i
I dont think this is phone to car connectivity issue.
My car has been stuck with updates before but it never went through since it last automatically updated back in 2021...After that I always had to get it updated at the dealer while changing oil.
I think what BMW messed up is their parameters to update.
I remember there being some requirement for the update to progress:
1. Car temperature
2. Battery level (may be both for dual battery cars?)
3. Good connectivity to cell network
And potentially more.
As our car ages, I'm suspecting if the car wants the battery level to be at certain capacity but due to age it never gets to that or something...
There could be other complications but I really wish BMW would make it simple...
May be they're just using this as a tactic to pull people into dealerships..
      06-21-2023, 02:16 PM   #17
nZtiZia
nZtiZia's Avatar
I prefer downloading updates onto a flash drive then connecting it to the vehicle. it may solve the “sticky” prerequisites issue in addition to waiting for it to roll-out on their ambiguous schedule to each respective vehicle
      06-21-2023, 02:56 PM   #18
jad03060
Drives: X5 45e
When the BMW area rep looked at mine, he said he thought that if you were NOT using the app at all, it would still download via the vehicle's cellular network. I'm not sure how easily that could be tested. BUt, I agree, it would be easier if we could download the data, throw it on a flash drive, and insert it in the vehicle. I'd like to have the entire US nav maps available that way, too, but unlike some other parts of the world, you can only get your local region updated OTA which can make a long distance trip kind of a pain as you have to change your home region for it to trigger an update...just driving into the area does not, or at least it didn't when I traveled into the adjacent region and was there for a week.
      06-22-2023, 08:54 AM   #19
Guy Fleegman
You're assuming that your car isn't lying to you.
This might be an AI thing.
      06-22-2023, 02:36 PM   #20
FLYZ
      06-23-2023, 05:06 AM   #21
W0ut
Belgium
244
Drives: BMW G05 X5 xdrive45e
I have the exact same issue.
Downloaded, transferred to car and 'prepared' the update weeks ago. Car and phone fully charged, did multiple >1h road trips since. It refuses to start the install.
Previous 3 OTA updates were installed successfully using the same phone
FLYZ100.50
      06-23-2023, 06:37 AM   #22
micmitch
Drives: 2019 X5, 2018 Accord
Same issue here
FLYZ100.50
