04-30-2024, 12:30 PM | #1 |
Rep 89
Late Oil Change is this bad?
Hi guys,
Bit of an update from my last thread. Bought a 2019 M240i the other day with incredibile spec and in mint condition, the servicing was all logged in iDrive and 'on time' not 'late'. But after further inspection (my own mistake) it appears the engine oil was changed at 3k miles but then it wasn't changed again until it hit 36k miles. It did do a lot of miles in it's first year (24k) and has dropped down to 6-8k a year since. It was a pre reg and BMW courtesy car for it's first year from the documentation I have. Which is why it did 24k miles in it's first year. The BMW servicing documentation I have and iDrive did not log the engine oil being done at 36k as late or an issue which is very strange. I have contacted BMW to verify this. Should I be concerned? The car is at 46k miles currently, and did have another oil change at 45k recently. I don't plan on keeping it for 10 years, but do want to keep it for 5. Just hope it hasn't damaged the engine. It drives like a dream, thanks to the B58. Just wanted to know your thoughts on this. Thanks in advance. |
04-30-2024, 12:52 PM | #3 |
Rep 13
I don't think there is a true way of knowing unless you take the engine apart and examine everything. Sending the oil to a lab to check for bearing material is probably a waste as the 33k engine oil has since been changed.
So long as it hasn't run low on oil, then seeing as its a brand new engine i would hazard a guess that whilst there could potentially be some wear, everything maybe OK. personally i'd be more concerned about it being a courtesy car and being redlined from cold by people who don't have to worry about maintaining it. |
04-30-2024, 01:13 PM | #4 |
Rep 6,336
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [8.58]
2020 BMW M340i xDrive [9.00] 2018 BMW 340i M Sport [7.38] 2006 BMW 330i Sport [5.83] 2004 BMW 330i ZHP [7.13] 2000 BMW 328i [6.17] |
That is definitely a very long time! My guess is there was at least one change after the 3,000 miles during those 24k miles. It would be exceedingly unlikely a dealer would run a courtesy car that many miles without changing the oil. The odds of that happening are virtually nil.
Having said that I’ll tell a little story. I worked for a BMW dealer once upon a time and we had a little old lady return her X3 at the end of her lease with 36,000 miles and it had one oil change during her lease at 18,000 miles. For some reason that’s when her CBS system told her to get the oil changed. Because of this BMWNA required us to pull the valve cover and send them photos of the internals of the motor before they would agree to let us CPO the car. I got to look inside the motor. It was pristine!! It looked like it was brand new!! Not the slightest hint of wear or sludge anywhere to be seen. That really increased my confidence in the durability of fully synthetic oil.
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
04-30-2024, 01:27 PM | #5 | |
Rep 89
04-30-2024, 01:57 PM | #7 |
Rep 5,937
Are you saying there was no oil change between 24k miles and 36k miles or 24k miles and 46k miles?
Synthetic oils can provide protection and last > 10k-15k miles. BMW free-maintenance OCI is at least 10k miles which means it can still go well past 10k without issue. If the oil had significant breakdown by 10k then they’d be charging the oil much sooner. For street driven miles, I go 8k miles before changing the oil and the Blackstone report shows the oil has not lost any of its protection abilities so the oil could be used for an even longer mile interval for the OCI. Your engine is fine. However, one thing you don’t know is how the car was driven before being fully warmed up. Most engine damage is done during a cold start and the warm up period. You could use a borescope to look inside the cylinders to see if there’s any piston scoring but it’ll probably look fine. Do you have to add any oil between oil changes? If yes, how much over what mileage? Things you can’t see are rod and main bearings but fortunately the b58 doesn’t have a rod bearing issue like the s65 NA 4.0 L V8. |
04-30-2024, 02:10 PM | #8 | |
Rep 89
So it had an oil change at 3500 miles, it had another service at 27k miles but the BMW service states it didn't need oil for another 8000 miles, so then it didn't have the oil change until 36k miles. But the BMW iDrive didn't deem the oil change as 'late' when it did get done at 36k, which I find rather odd. So in all, its had a oil change done at 3500 miles, 36k and 45k. I'm just hoping it hasn't damaged the engine at all. I'll be honest, I really don't know what I'm looking at, but I do have a local BMW specialist which might be worth contacting. Last edited by F36 435i M; 04-30-2024 at 02:16 PM.. |
04-30-2024, 03:23 PM | #9 | |
Rep 5,937
Sounds like your b58 is running strong so just enjoy driving and learning its limits without worrying about the past 46k miles. The f22 m240i/m240ix is a blast to drive and eventually you’ll stop worrying about what was/wasn’t done for the first 46k miles! |
04-30-2024, 04:07 PM | #10 | |
Rep 223
Edit, nowadays i put maybe 2k miles on the car a year... just realized i never go anywhere anymore bc of WFH... weirdo |
04-30-2024, 04:12 PM | #11 |
Rep 6,317
No one can say how much damage happened. I'm sure it's not optimal and the only way forward is to do oil changes on time and see what happens . THat said, I would be pissed at the dealer who sold me the car that's for sure.
At least it's not like running the engine with no oil. |
xander_g1019.50 |
04-30-2024, 04:27 PM | #12 | |
Rep 89
04-30-2024, 04:29 PM | #13 | |
Rep 89
04-30-2024, 05:17 PM | #14 | |
Rep 6,317
The only thing that may remotely do anything is oil analysis (Like Blackstone) but that is debatable as well depending on the meterials used. |
04-30-2024, 06:27 PM | #15 |
5287
Rep 10,684
Could it also have been changed but the change not recorded? Seems odd a BMW dealer would not follow the once a year minimum.
04-30-2024, 07:29 PM | #16 | ||
Rep 6,336
As I said in my previous post, the odds a BMW dealer that used this car as a courtesy car for one year and 24,000 miles only did one oil change at 3,000 miles and then not again for 21,000 miles are zero for all intents and purposes regardless of whatever documentation the OP has in his possession.
04-30-2024, 09:23 PM | #17 |
Rep 718
A few things that can be done...
Change the oil, and send a sample to Blackstone Labs for analysis. It'll tell you if there's some wear going on. Then get some engine oil flush to remove any sludge, yes, that means dropping the oil again. Then you change the oil again in say 2k miles. Then just maybe change oil at 5k mile intervals with synthetic and call it a day. Nothing you can do about it now. It's all yours! Good luck! |
04-30-2024, 11:55 PM | #18 |
33
Rep 36
I've known two car owners who bought new cars and just didn't comprehend the whole maintenance thing. They drove and drove their vehicles (both Hondas) and eventually when they started using oil, they would add it but never change it. The oil filters surely started bypassing at some point. Eventually both engines seized up, coincidentally (or not) in both cases it was right around 55,000 miles. Neither case involved synthetic oil.
Both were really into horses. If there's a connection there I don't know what it is. |
05-01-2024, 02:39 AM | #19 |
Rep 140
StradaRedlands5027.50 |
05-01-2024, 05:41 AM | #20 | |
Rep 2,345
Drives: 9Y0 Cayenne S
05-01-2024, 10:56 AM | #22 |
Rep 3,997
Sounds like it was treated like a rental car, happens all the time.
Probably best to get rid of it when the warranty ends, or if it's good to you before then and in good condition, your call on keeping it. Not much you can do now. Research should be done prior to purchase.
