01-31-2021, 04:11 PM | #1 |
Rep 153
DIY seat height adjustment
Anyone know the size of the screws that hold the seats down? I'm going to add washers to increase the height and see if that helps with horrible steering wheel position. I'm pretty short so I "have the room" to go higher.
I just want to make sure I get a longer screw and wasn't sure how to look up this exact screw size based on any of the diagrams? If there is a link to a diagram that would be great (sorry if I missed it). |
02-01-2021, 08:22 AM | #2 |
Rep 153
Incase anyone needs it - M10-1.5 and I ended up putting in 50mm length (raise the seat up about an inch with spacers).
11-22-2021, 09:50 AM | #5 |
Rep 962
Drives: G87 M2, G20 330d, Brabus Smart
Serious question: Did you guys get the only X5s without power seats or something? When I was cleaning the other day, I personally found the max raised position of the front seats very high. I'm genuinely curious...
@DBV_
Current: '23 G87 M2 6MT / '21 G20 330d / '18 Brabus Smart Gone: '21 G05 X5 M50d / '18 MB C63s (632hp) / '16 F80 M3 6MT (570hp) / '09 F01 750i / '16 Abarth 595 Competizione (202hp) |
11-22-2021, 11:21 AM | #6 |
Rep 12
I'm with you. I can't get the seat low enough. In previous cars I've set my seat height to look out of the vertical middle of the windshield. In my X5 with the seat as low as it can go, I'm looking out 2/3 of the way up.
11-23-2021, 04:05 AM | #7 | |
Rep 153
11-23-2021, 05:41 AM | #8 | ||
David R
79
Rep 58
I'd be willing to bet those cheap bolts do not have the required shear strength to meat crash standards. Also now that the seat is resting on stacks of washers instead of the brackets, as designed, the rigidity of the assembly has been compromised. This is very dangerous. |
11-23-2021, 08:36 AM | #9 | ||
Rep 3,009
The issue is you don't want the bolt to shear in an accident and have the seat and you shift or worse become disconnected. If you cannot determine from the factory bolt. Call a vendor that sells race seats and ask them the proper grade and the proper way to raise the seat height. https://www.homedepot.com/c/ab/grade...fab90189731df8 |
11-23-2021, 08:47 AM | #10 |
Rep 8,828
Drives: eVeRyOnE mAD!
keeva381 i agree with others here. while your modification may increase comfort and line of sight, it screams safety concerns with the use of questionably-rated bolts and raising on spacers where you've increased the lever-effect making it much easier for the seat to separate from the rack (much like how the back of a hammer easily removes a nail).
gqgambler719.00 |
12-01-2021, 07:08 AM | #11 | |
Rep 153
Does anyone know where you can get the "highest" grade bolts now that I know size/length? I don't mind paying a premium for the best grade bolts out there. Sounds like the HD/Lowes option might not be high enough grade. |
12-01-2021, 07:41 AM | #12 | |
Rep 3,009
Maybe talk with Recaro and see what grade they use? Guessing they will tell you not to modify your seat base but may tell you about their baseframes and hardware. Guessing the proper way to modify is by installing a higher base frame but also guessing no-one makes one. Personally, I wouldn't mess w/the factory mounting, especially the way it mounts to the floor but good luck. |
03-04-2022, 09:00 AM | #13 |
Rep 1
Yes. Has anyone been able to lower the seat into a more "cockpit" style arrnagement?? I would really like to know if that is possible for an X5? I came from a Cayenne S seating and I gotta say, IMHO, the seating style and positioning of that car is far better than the X5.
05-16-2022, 11:09 AM | #14 |
Rep 520
Does anyone know of a good way to raise the front of the drivers seat while leaving the rear part of the seat alone? I would like for my knees to be about two inches more higher than my hips than they currently are.
01-15-2024, 09:26 AM | #16 |
Rep 153
01-19-2024, 12:01 PM | #17 | |
Rep 470
Drives: 11 128i 6MT Sport
RealOEM.com has all the vehicle parts diagrams. The stock bolt is p/n 07149321690 which is listed as M10 x 28mm long. If you're adding an inch of spacer (25.4mm) you can probably get away with 50mm bolts since some of the thread is usually sticking past the end of the nut but you could use 55mm long bolts to be safe. McMaster.com has all kinds of hardware and a pretty easy interface to drill down to exactly the size and strength of bolt you need. For a socket head cap screw, they only have 12.9 grade bolt in 55mm long. You might also want a washer to replicate the flanged head of the stock bolt. https://www.mcmaster.com/91290A219/
11 128i slicktop
13 WK2 19 Alltrack S |
