04-12-2024, 01:53 PM | #1 |
185
Rep 303
How to drain water from the X5?
I’ve got a 2019 X5 and it sounds like there’s water in the chassis or in lower body molding area.
No water in the doors. No visible water inside or on the carpet or anywhere. I’ve searched a number of the ‘sunroof drain fix’ threads and don’t see anywhere where I can locate a drain to get the water out. Any ideas as to where I can find the drains?
Shawzy44
2024 BMW X1 28i 2023 BMW X3 M40i 2019 BMW 440iX M Performance Cabriolet |
04-15-2024, 10:34 AM | #2 |
185
Rep 303
Still experiencing issues with the water in the frame. I found the source (drain tube cut during Stealth hitch install).
Anyone have any schematics of the drains so I can have my local mechanic try? I am at a real loss as to how to get this water out. TIA!
Shawzy44
04-15-2024, 10:52 AM | #3 | |
Rep 4,454
Hopefully someone else who has dealt with this before will chime in. You could, though risky, blow compressed air through them from the sunroof opening. The risky part is that you would not want them to disconnect as I somehow believe there are two or more connected together to make the long reach to the bottom of the car. . |
04-15-2024, 11:09 AM | #4 |
Rep 3,952
There is a drain in each corner of the sunroof.
Front ones are easy to check. They drain out an opening near the front door hinge on each side. The rear drains exit behind the rear wheel inner splash shields. |
04-15-2024, 11:26 AM | #5 |
Rep 4,454
Do you know if the drain hoses are one single length or are there two serially connected sections on one or more? Looks like a connector at the bottom end of them but I would have thought the diagram would have shown the extensions
04-15-2024, 12:06 PM | #6 |
1003
Rep 1,507
The diagram shows them (i think) as mostly 1 piece with the exception of the bottom, which appear to be connected to the actual outside frame connecting tube.
2021 Jeep Grand Cherokee SRT Black 2006 Ford Mustang GT Convertible (show car) |
04-15-2024, 09:13 PM | #7 |
185
Rep 303
Thanks, I have water in what sounds like the frame. I need to find the drains in the body not the sunroof.
Shawzy44
04-18-2024, 07:34 PM | #8 |
BMW CCA 69606
89
Rep 228
04-19-2024, 03:29 PM | #9 |
185
Rep 303
I think it might be. I will have to start taking panels off and see. So odd.
Shawzy44
04-20-2024, 05:52 PM | #10 |
BMW CCA 69606
89
Rep 228
Do you see water on the door sills after a rain?
If you remove the door sill trim & clips, you will find holes you can stick a ~1/4" od tube thru and draw the water out. This happened on my E39. |
04-29-2024, 06:56 PM | #11 |
185
Rep 303
Thanks for the ideas.
No water in the doors. It’s been coming in after a drain hose was not put back during the Stealth Hitch install. I have traded the X5 for a 2023 X3 M40i.
Shawzy44
