      03-09-2024, 05:25 AM   #1
Therealmatzaman
Drives: X5 G05
New nav destination pop up at start?
My car did an OTA the other day to what I assume is the latest for a ‘21 G05 M50i. Ever since then, when I start the car the BMW nav pops up with a suggested destination like it’s trying to predict where I want to go. Problem is, Ive never been to this place and I dont want to go there. In fact I never use the BMW Nav- I use Google Maps or Waze in CarPlay. If you arent looking at the pic, this is different than the notification that used to appear up at the top of the screen that also went away on its own- this one needs intervention to dismiss.
Anyone know whats causing this and how to disable?
arkhi170.50
      03-09-2024, 05:52 AM   #2
Condorll
Drives: 2023 BMW X5 xDrive 40i
Does your wife drive the car? She might have used the BMW app on her phone to send a destination to the car.
      03-09-2024, 02:49 PM   #3
lackland
Drives: BMW iX M60 2024
At least in my X5 50e running 8.5 that is not normal behavior. One wonders if a reboot of the system and/or smartphone apps will end it. (Although as you note, that isn't the usual little notice that 8.5 displays in the upper left screen when it has been sent a destination. Rather, it looks more like a search made once the navigation program is already running with a different destination set.)
      03-09-2024, 03:21 PM   #4
nzzzzz0832
Drives: BMW x5 45e
I have the same problem, it always starts with a random location and always seems to be the same one. Never used app to send any address. Curious to see why
arkhi170.50
      03-09-2024, 03:22 PM   #5
CGG
Drives: G05 x5
You probably have on your "Learning Route" in navigation - it shows you possible destinations based on driving habits. To deactivate:
1. Go to Navigation screen
2. Settings (on right side of nav screen)
3. Configure services
4. disable Learning route to deactivate the function.
Ibiza3611.50
      03-09-2024, 06:40 PM   #6
Therealmatzaman
Drives: X5 G05
Thanks. I did shut off that service and it didnt change yet. Maybe it takes time. My wife doesnt drive the car. So weird.
      03-09-2024, 07:12 PM   #7
MattAu
Drives: BMW X5 xDrive40i (MY2021)
I setup myBMW app to connect with my calendar (iOS) and it would pick up address of upcoming calendar event. The problem is the location would still pop up after the date of the calendar event. So I disconnect it (i.e. no access to calendar) and the "problem" disappeared. So, give that a try.
PetroM543.00
      03-09-2024, 10:11 PM   #8
GerryC
GerryC's Avatar
1616
Drives: BMW Z4 M40i, BMW X5x40i
If she sends it from the app, it will be tied to her profile. You wouldn't see it while your profile is active.
2023 Z4 ///M40i Thundernight Metallic/Cognac Vernasca/Moonlight/Shadowline/19" Black 799M/PP/DAP/ACC/HK
2022 X5 xDrive40i Phytonic Blue/Cognac Vernasca/DAPP/LSP/PP/CCP/PAP/20" Style 738/Spare Tire/Trailer Hitch
      03-09-2024, 10:12 PM   #9
GerryC
GerryC's Avatar
1616
Check your Notifications settings. You can select which types of notifications can be displayed.
      03-10-2024, 06:55 AM   #10
TurtleBoy
TurtleBoy's Avatar
13275
Drives: 2019 X5 40i,2021 M340i
Have you accepted the destination? If not, try that and maybe it will go away.
2019 BMW G05 X5 xDrive40i - Phytonic Blue/Cognac - 11/2023.50
      03-10-2024, 07:44 PM   #11
fate9834
fate9834's Avatar
62
Drives: 2020 X5 M50i
Recently I start to see the exact same thing, the car suggests a destination at startup even though I didn't send any destination in MyBMW. I then realized that the car is suggesting a destination for an upcoming event in my Google Calender. Not sure why the integration is not checking the dates... typical BMW software solutions!
      03-11-2024, 04:50 AM   #12
Therealmatzaman
Drives: X5 G05
I’ll check the calendar integration on the app. My wife doesnt use the app or the car, so I wonder if it’s some funky thing like youre saying.
      03-18-2024, 06:53 AM   #13
PetroM5
PetroM5's Avatar
43
Drives: 2022 M5 Competition
I'm an M5 owner and this started happening to me also. I disconnected access to calendar in my iphone settings and the problem disappeared.
Thanks for this.
For those having problems this is what I did:
1. Settings Icon(Iphone)
2. Scroll down to My BMW(Tap to go to next screen)
3. Uncheck Calendars
Appreciate 4
X6ix GTA142.00
1Boxer34.50
JimVR4337.50
arkhi170.50
      03-25-2024, 06:34 PM   #14
JimVR4
JimVR4's Avatar
Drives: 21 X5 M50i M-Sport
Thanks for this.
Thanks for this suggestion. I suspect that an update to the My BMW app has caused the permission to Calendar to be enabled. I'm on Android so I went to Settings/Apps/My BMW and disabled the calendar access. We'll see if that fixes it.
2021 G05 X5 ///M50i / Phytonic Blue / Cognac Vernasca
iStep 03/2023.50
arkhi170.50
      03-26-2024, 09:39 PM   #15
JimVR4
JimVR4's Avatar
It wasn't fixed after removing Calendar permissions. Today I disabled Route Learning and that seems to have eliminated the pop-up.
iStep 03/2023.50
arkhi170.50
      03-27-2024, 10:08 AM   #16
Kgerry59
Drives: 2023 BMW X5
my 2023 used to do that every morning as well until I turned off Route Learning or Route Anticipation, whatever it was called...
      03-30-2024, 01:52 PM   #17
arkhi
Drives: 21 540i
Getting this on the G30 too. Will try disabling Route Learning and update.
      03-30-2024, 02:11 PM   #18
crabman
Drives: 2024 X5M
It was route learning for me.
      03-31-2024, 05:18 PM   #19
arkhi
Drives: 21 540i
Disabling Route Learning didn't work. Disabling calendar permissions didn't work either :/ The destination I get is half way around the world in the UK (I'm US): Orange Blossom Clinic, 32 Sandy Ln, Woodbridge IP12 4DG, United Kingdom.
On the app, you can see calendar addresses but none of it is for the UK.
Edit: I refreshed the calendar destinations on the BMW App to reflect no destinations. That seem to have done the trick.
