10-15-2023, 03:03 PM | #1 |
Rep 140
Vehicle key missing
This one had the BMW Technician beaten.
Can anyone help me resolve this problem; each time I try to start the car (50e) the following message is displayed: "Vehicle key not available or function failure. Ready-to-drive mode cannot be started. See Owner's Handbook for further information." followed by "Hold the vehicle key against the marker on the steering column. See Owner's Handbook for further information." Any idea what is causing this (the battery has been replaced)? Thanks |
10-15-2023, 04:32 PM | #2 |
13571
Rep 20,211
Did you replace it multiple times just to make sure you didn't have a bad battery. Also make sure you are not using an Energizer brand battery since those have created issues in the past.
sarpal12368.50 |
10-15-2023, 07:09 PM | #3 |
Rep 4,372
Drives: 2020 M850i Coupe
Although I do have Energizer CR2032's with no issue it sounds like the OP may have replaced the battery with a nearly depleted battery as well. There's a shelf life for any unused battery and why I just cycle the "standbys" every couple of years.
sarpal12368.50 |
10-15-2023, 07:34 PM | #4 | |
Rep 4,416
I've run into this issue with my wife's car, it turned out that the replacement battery was nearly dead. Strangely enough, I remember when we bought it, I bought it to replace the OEM battery in her second key fob. Not knowing that she bought a new battery when that other key fob needed it , I used the one I bought a couple years ago to replace a battery in yet a diff key fob in a diff car and low and behold, to make a long story short, it died while simply waiting to be used. All batteries have a shelf life. So, I guess I'm saying what the others here already said.. .. just buy another new one and replace it and see if that works. |
sarpal12368.50 |
10-15-2023, 09:45 PM | #5 |
Rep 8,802
Drives: eVeRyOnE mAD!
some of these batteries have a protective film on them, so make sure that's removed before installation.
if you're certain the key fob batteries are good ones and installed properly but still have the issue, you may just need to disconnect the 12V battery for a few minutes. this has actually helped restore key recognition for a lot of 45e owners with similar issue in the past |
sarpal12368.50 bloozemanAZ4307.00 |
10-16-2023, 05:14 AM | #6 | |
Rep 140
UPDATE Replaced the battery twice, no change Last edited by sarpal123; 10-16-2023 at 06:03 AM.. Reason: Update: |
10-16-2023, 05:18 AM | #7 | |
Rep 140
10-16-2023, 06:55 AM | #8 |
Rep 8,802
ah, it’s a loaner? so hopefully not much longer!
10-16-2023, 08:29 AM | #9 | |
1229
Rep 1,350
10-18-2023, 08:21 AM | #12 | |
Rep 1,095
1. A package of two 2032 Energizers retails for $5.47. A package of two Duracells retails for $5.72. 2. Both brands have identical dimensions (20mm thick x 32mm dia), are rated at 3 volts, and are lithium chemistry. Maybe they're both made in the same Chinese factory(?). 3. The Energizers are packaged in a clear plastic blister with foil backing. The Duracells are packaged in a cardboard and plastic blister that most folks can't open without experiencing personal injury. 4. The Duracells have a clear plastic film that covers most of the + side, and contains a bitter tasting compound so your pets and kids are less likely to eat them. This film must be removed before battery use. 5. The Duracell package is marked with a date code; the Energizer is not. There is no reason a new Energizer cell taken right out of its package should fail to operate any device that specifies a 2032 coin cell battery. However, lacking a date code, some retailers that don't turn inventory regularly might have aged product, and this could result in performance failure. I will compare manufacturer spec sheets and perform testing on these two brands in coming months, and report my findings in a future thread. |
10-18-2023, 08:37 AM | #13 | |
Rep 4,416
10-18-2023, 09:48 AM | #14 | |
Rep 869
Drives: BMW Z4 M40i, BMW X5x40i
2023 Z4 ///M40i Thundernight Metallic/Cognac Vernasca/Moonlight/Shadowline/19" Black 799M/PP/DAP/ACC/HK
2022 X5 xDrive40i Phytonic Blue/Cognac Vernasca/DAPP/LSP/PP/CCP/PAP/20" Style 738/Spare Tire/Trailer Hitch |
10-18-2023, 10:35 AM | #15 | |
Rep 4,416
I just replaced both batteries in my wife's GTi a few weeks ago, those were 5.5yrs old before they died. I replaced them with Energizer 2025's that I bought in Jan 2021. So far so good. Both batteries are 3V, the 2032 is slightly thicker as it has a higher capacity than the 2025, 235mAh vs 170mAh but the load on it in the GTi I suspect is much less. I think the last two digits, 32 or 25 represent the thickness of the battery where the 2032 is 3.2mm thick and the 2025 is 2.5mm thick. The 20 means they are 20mm round |
10-18-2023, 12:26 PM | #16 | |
Rep 869
And you are correct on the button battery numbers. First 1 or 2 digits are diameter in mm, last 2 digits are thickness in tenths of mm.
10-18-2023, 01:54 PM | #17 | |
Rep 1,095
Regarding Panasonic, they are a reputable brand. Just not as commonly found on battery racks in the box stores as Duracell and Energizer. |
GerryC1677.50 |
10-18-2023, 02:01 PM | #18 | |
13571
Rep 20,211
10-18-2023, 02:31 PM | #19 | |
Rep 4,416
1. People not paying attention to dates stamped on packages when they buy batteries, I know I normally don't cause I'm in a hurry to get whatever working again. 2. Duracel, the famous Copper Top battery, being more popular due to their marketing so their turnover is higher. So, the less popular brand may have a shorter life once someone installs them I'm just guessing as I've never had an issue with any brand. |
10-18-2023, 06:36 PM | #20 | |
Rep 869
10-18-2023, 07:18 PM | #21 |
Rep 626
I'm one of the owners who first tried an Energizer battery without success. However, when I put in a Panasonic battery, the message went away. To this day, I still can't understand why, but hey if it works, it works!
10-19-2023, 04:22 AM | #22 |
Rep 140
I've just bought some BRAND NEW Duracell 2032s and tried two of them - still no joy. The temp solution is to get in and hold the key to the steering column, then press start (then just close the error message). Tedious but it works.
Anyone got any thoughts as to what could be the cause? |
