11-09-2023, 12:25 PM | #89 | |
Rep 909
Depends on how much engine you use, but should last a long long time |
11-09-2023, 12:44 PM | #90 |
Rep 148
11-09-2023, 01:45 PM | #91 |
13528
Rep 20,169
No one drives under ideal conditions. Depending on speed, traffic, etc. I would think you should be able to get between 25 - 30 mpg on a road trip.
11-09-2023, 05:04 PM | #92 |
Rep 6,881
On my 45e, from NH to MI and back, with little opportunity to recharge, I averaged about 28mpg (that's over 2000-miles).
One's definition of a road trip is open ended, so without more details, the answers can be skewed considerably. You'll see a big difference between cruising at 70 versus 80...the drag goes up with the square of the speed. That trip was mostly at about 75-mph on adaptive cruise. The 50e should get a little better unless you trounce on it. |
11-09-2023, 05:58 PM | #93 |
Rep 873
Seems like I get 28mpg pretty regularly on my 45e even with the EV battery at —, but it’s odd to me that the EPA rating is only 19/22.
M3 - X5 - 911 - Miata - Raptor - Edge
11-09-2023, 07:06 PM | #96 |
Rep 873
Right, but makes me wonder why the ‘official’ figures are so low—in fact, lower than the standard 40i model.
11-09-2023, 07:23 PM | #97 | ||
Rep 3,708
I have a table posted somewhere, but quick calculation. At the same highway speed, where both will be at 8th gear. 45e needs to spin ICE at 2425 RPM, 40i only need to speed at 2166. Difference is 15%. Speed at this RPM should be ~71.5MPH. My math may be off. But gear ratio numbers are from BMW
2022 G05 B58/PHEV
+ a few very old BMWs Last edited by eelnoraa; 11-09-2023 at 07:56 PM.. |
11-09-2023, 07:28 PM | #98 |
Rep 6,881
In the USA, the EPA test for fuel efficiency is a fairly strict set of conditions to make comparisons between vehicles more reliable. Ideally, it represents the real world, but it will never be perfect (it's done on a rolling test bed so air resistance isn't a factor). One reason why the Euro standard gets different numbers is the test is done differently. Theirs estimates longer range/efficiency than the EPA tests.
11-09-2023, 07:29 PM | #99 |
Rep 873
EPA figures are mostly self-reported by the manufacturers so it’s likely that they absolutely did claim 19/22, which equates to about 20mpg combined.
11-09-2023, 07:30 PM | #100 |
13528
Rep 20,169
They come from EPA testing which rarely, if ever, reflects real world usage.
11-09-2023, 07:38 PM | #101 | |
Rep 3,708
I think 20 combine without HVB isn't far off. 28MPG on highway is also with HVB. I get this as well. When HVB is gone, then it is more like 25-26MPG
2022 G05 B58/PHEV
+ a few very old BMWs |
11-09-2023, 07:56 PM | #102 | ||
Rep 873
12-03-2023, 11:15 AM | #103 | |
Rep 132
When the PHEV battery is down to a 0% SOC, the 50e still acts as a strong hybrid and will shut off the engine when coasting, or at a stop light, or even when driving at low to medium speeds over short distances -- it's being a strong hybrid and is using the energy being recuperated. Any distance traveled with the ICE off is not being booked against the ICE fuel consumption/distance traveled metric on the trip computer, it is being booked under the EV KwH/distance metric. So that being the case, I would recommend the best way to estimate the actual MPG when the PHEV battery is at a 0% SOC is to take a trip in battery hold mode. For that trip, the overall MPG estimate will take into account miles traveled with the ICE off (due to energy recuperation only) as part of the MPG estimate. On a recent 55 mile trip on I-95 (in heavy traffic, in the rain, 34.8 mph average speed, lots of speeding up and slowing down), where the entire 55 mile distance was accomplished in HOLD mode, I averaged about 27 MPG. So based on my observations, with a full battery at a 100% SOC, you can expect to travel 39-42 miles using only the electricity stored in the battery (100% to 0% SOC), and then average 26-30 MPG thereafter (depending on speed/driving conditions) until you recharge again. The ~22 MPG in your calculation would only occur if the engine never shut off during the drive (I suspect you'd might see close to that MPG value in Sport Xtraboost mode). Last edited by TexAg91; 12-03-2023 at 11:22 AM.. |
12-03-2023, 12:04 PM | #105 | |
Rep 3,708
Here is my observation 1. Under stop and condition, the amount of reg is very mild. Say between two traffic lights. The main regen is the part you slow to to stop. However, this portion is small, where as soon you hit the gas paddle, car is moving, ice is on. 2. In highway, the regen is even smaller at coasting. The car know the most efficient way is minimal regen. You do get some regen to when slow down, say to exist highway, but this happens far and few in between. To get the car back up to speet, it take more energy than 40i because of the weight. In pre lci, the weight difference is 800lb, or 15%. Which is significantly. 3. In my test, if regen has meaningful mount, I should see significant edrive miles. But I don't. Per tank, I was doing about 350 miles. Trip computer recorded single digital edrive mile for every tank. Single digital here mean 5 miles. So even if I factory in 5 mile in my formula, it is a 1-1.5% different.
2022 G05 B58/PHEV
12-03-2023, 12:11 PM | #106 | |
Rep 132
That said, was the HVB (High Voltage Battery) at a 0% SOC at the trip start? If yes, then that would be indicative of the MPG you could expect in the future, once the SOC (provided by the power grid) in the HVB is depleted. |
12-03-2023, 12:13 PM | #107 | |
Rep 3,708
Based on a few members sharing 50E mile/kWh number, we can assume average is about 2. This journey consumed 12.8kwh, meaning probably 25.6 miles are from edrive. Let's call it 25. So ice mile is 69, or 73.4%. So actual ice mpg is about 32.5 x 73.4% = ~24mpg. It is not unreasonable because your average speed is very high, 68.3. this means you were probably as fast as 85-90 at some point. This higher speed significantly impact mpg.
2022 G05 B58/PHEV
12-03-2023, 12:21 PM | #108 |
Rep 549
The HV battery was almost full since I left from home, and battery hold was not active.
And yes, there were definitely some 85-90mph stretches (shhh). |
12-03-2023, 12:58 PM | #109 | |
Rep 132
I have not done a trip on 0% SOC yet on my 50e, but will around 21 Dec. I have to take a trip from Fredericksburg VA to Charlotte NC and back. I'll start with a 100% SOC on the HVB and will use ECO pro for the trip down. I should arrive with 0% SOC, and I won't have time to recharge the HBV before the return leg. So for the return trip I should get a good data point for the actual MPG at highway speed once the HVB is depleted. To date, I've only taken one 55 mile trip using the battery hold mode and achieved a trip MPG of 27 mpg. So I have a data point of 1 in stop and go I-95 traffic. I did that because didn't have my Lectron Telsa to J1772 adapter, and was having to use 110 power to recharge the 50e. FYI -- it was taking 24+ hours to go from 0-100% SOC in the 50e using 110 power. Anyway, at the start of this 55 mile trip home, I had about 3 miles of EV range. So I turned on SOC hold mode to save myself about 2 hours of charging to get it back to 100%, and I was curious to see what kind of mpg I would achieve. With my Telsa charger and the Lectron adapter, I can now recharge my 50e at 32A, so it only takes about 3 hrs to go from a 0-100% HVB SOC. I intend to use a much grid power as possible moving forward. Costco is such a pain. |
12-03-2023, 01:35 PM | #110 | |
Rep 3,708
I think the real culprit is the HVB size if we use PHEV as HEV. HVB really never get more than 10%, this mean 90% of the HVB isn’t used. That is a good 600-700lb of dead weight. Think Toyota Highlander hybrid has only 2kWh battery. This is why I keep saying, being able to charge is the necessary condition form PHEV ownership. As for mpg number, bmw actually says 45e combined mpg after HVB is depleted is 20mpg. My single data point real world test is already 22, so not too bad. I wonder bmw will ever publish the same figures for 50e.
2022 G05 B58/PHEV
