03-15-2022, 12:51 PM | #1 |
359
Rep 365
Removed Warning Stickers off of Visors - Much Cleaner
I had the X5 for a week before I removed warning stickers. There is a very good YouTube video on the removal that shows you how to do the removal without removing the visors.
2022 X5 40I - Ours
2016 BMW M2 LBB 6 Sp / ED Pick Up on 07/12/2016 - Her's 1995 Porsche 993 Cab - Mine 2001 Toyota Tundra SR5 Ext Cab - Hay Hauler |
03-15-2022, 12:56 PM | #2 |
Rep 598
nice! I have been wanting to do the same thing but nervous with the alcantara healiner. But looks like you have the same and didn't have an issue. Did you follow what is shown in the video?
03-15-2022, 02:08 PM | #3 |
359
Rep 365
I did. Driver's side peeled right off. Passenger side was a little stubborn but I got it off. Very easy.
2022 X5 40I - Ours
03-15-2022, 03:34 PM | #6 |
Rep 106
I actually tried a heat gun on the plastic non alcantara. I was scared but after trying for a few minutes I feel like that sticker is built into the plastic. I had zero success with removal.
03-15-2022, 03:34 PM | #7 |
Rep 744
I didn’t even notice it, I just went to check my X5 and there it is! Mr. Observant here, I’m embarrassed to say I was an imagery analyst in a previous life!
03-15-2022, 06:35 PM | #8 |
Rep 443
Hate to do this but a huge warning to anyone with Alcantara. I did it after reading a post from someone who did it on their X7 (if I remember correctly) with Alcantara. I removed on our previous 3 series (no Alcantara) and it was a breeze. But like the OP, the driver side came right off but the passenger side was a different story. For me, the passenger side couldn't be salvaged (photos attached) and I ended up having to buy a complete OEM European replacement set from IND. Hate to throw cold water on this but thought I should share my experience as I would've left as-is if I knew the risk. Oh and hey, I have a brand new OEM European (no sticker) driver side visor if anyone is looking! Plan to post in the classified section at some point.
03-15-2022, 09:20 PM | #10 | |
359
Rep 365
In 2016 I removed the stickers off of my wife's new M2 vinyl visors without issue. https://f87.bimmerpost.com/forums/sh....php?t=1308214
2022 X5 40I - Ours
ipayincash48.50 |
05-10-2024, 01:29 PM | #12 |
Rep 3
removal of airbag stickers on Alcantara visors
Thanks to all of you who posted your tips & stories about removing the unsightly airbag warning stickers from the visors. Was feeling unusually brave yesterday and gave it a go. Happy to report it worked with minimal effort (and I did not even attempt to remove the visors first out of fear of breaking the clips).
Method I used: 91% isopropyl alcohol (put into small spray bottle) + microfiber rag Sprayed alcohol directly onto corner of sticker (held rag underneath to catch any drips) and then pressed rag onto sticker for ~30 seconds. Started peeling (and praying I wasn't doing any permanent damage). Continued to spray sections where sticker would not peel easily. Drivers side came off in large section with minimal bits I had to peel off with my fingernails. Passenger side was more difficult for some reason, but just continued to alternate spraying the alcohol and peeling. After all sticker removed, I gave the whole section a wipe down with the microfiber and a bit of alcohol to remove any remaining residue. Followed with another wipe down with a clean microfiber rag with water a tiny bit of Dawn dish soap. Zero shadowing or outline left behind, no damage to the Alcantara. Entire process took about 15 minutes. My nails however will probably have tiny bits of sticker stuck under them for a few weeks - totally worth it. Attachment 3454244 |
05-13-2024, 09:04 AM | #13 |
20
Rep 42
I want to give this a shot... Curious if my blue Alcantara headliner will be as forgiving as the black? I guess only one way to find out!
20 ///X5MC Tanzanite Blue II Metallic - RachChip, MSS Springs, Cat-back Titanium Exhaust
17 X5 50i Space Grey Metallic - ESS Tune, Catless Downpipes, X5M Air Filters, H&R Springs & Spacers , BBK 96 SC ///M3 Racecar - CP Pistons & Rods, ARP Studs, VAC SC Cams, VF V3 Blower, 12lb Pulley, RK Tune & lots, lots more... |
05-13-2024, 11:23 PM | #14 |
20
Rep 42
chicagofan0019327.00 |
05-14-2024, 08:07 AM | #16 |
1047
Rep 1,564
^Like it was never there...well done
2021 Jeep Grand Cherokee SRT Black 2006 Ford Mustang GT Convertible (show car) |
05-14-2024, 08:21 AM | #17 |
Rep 24
For non-alcantara, this looks like a decent option:
https://www.amazon.com/Universal-Sun.../dp/B091V6S243 |
05-15-2024, 03:52 PM | #18 |
Rep 2,729
05-19-2024, 10:51 AM | #20 | |
20
Rep 42
Luckily mine all came off, but a slight glue ring in my opinion is still better than those ugly yellow stickers.
1230vani660.00 |
