08-02-2023, 04:37 PM | #45 | |
Rep 145
In that scenario if one puts the 45e in sport mode before getting out would the ICE and AC kick in and stay on? |
08-02-2023, 04:40 PM | #46 | |
Rep 1,236
Very few people put transmission to neutral nowadays. BMW can see from their data how often people do that. Probably for 99.9% of customers, it's "D" or "P". They may still want to allow some cases like towing? I don't know for sure, but making it "unrollable" in all circumstances may have prevented some use case scenario like towing, or emergency rescue situation. |
08-02-2023, 05:02 PM | #47 | |
Rep 3,723
So in order to solve a problem, 1st step is to identify the problem. And the problem statement is the concern of car rolling when driver exist, right? Again, the solution is to put the car in Park and maybe engage E-brake when door is opened? NOT to just turn off the car, and counting on the driver did NOT put the car in neutral. This nowhere a good solution to the problem you describe. As for being towed, I got that. But again, BMW's choice isn't the solution to the problem if there is a concern people being run over by a roll-able car. Since being towed should be a rare event, taking 1 or 2 extra step to put the car in neutral should be totally acceptable. Other cars (BMW and other) has been doing it better for the longest Older cars have shift lock and let you get car in natural. Tesla has tow mode in manual, so user can go in and engage tow mode ... Many good ways. 45e's way, car off and leave car in neutral is far from it.
2022 G05 B58/PHEV
+ a few very old BMWs |
08-02-2023, 05:35 PM | #48 |
Rep 21
Don't currently have a charging option but that will change.
08-03-2023, 02:10 AM | #49 | |
301
Rep 382
08-03-2023, 08:32 AM | #50 | |
Rep 548
My problem is adjusting to the joystick shifter instead of the conventional ones when it was much more obvious which gear I was in (I drove standard transmission cars most of my life). I haven't developed the habit of verifying that the car is in Park before getting out because the car takes care of it 99% of the time just by turning it off. And my 45e is so #$%! quiet I don't have those audible cues as well. |
08-03-2023, 10:20 AM | #51 |
Rep 3,723
I am fine with car remain in neutral in this specific case. I always use e brake. I just don’t like how the car must be off when door open. It does not address someone’s concern about the car can roll and kill themselves. I just pointed out they are orthogonal issues.
08-06-2023, 03:07 AM | #53 |
Rep 62
I do this all the time in Winter when battery is too low for precon either from sport mode or with the shifter to the left to start the ICE, parking brake on, shifter pops back to park, engine stays on until I return. Havent really tried it with passenger in car but pretty sure that works to, especially if key left in car. Its all described in the manual somewhere. Once ICE starts charging the heater /AC works
08-06-2023, 08:29 AM | #55 |
Rep 8,828
Drives: eVeRyOnE mAD!
read my earlier post, last paragraph. while mine is the 45e, it's the same setting and behavior on the 50e
https://g05.bimmerpost.com/forums/sh...4&postcount=41 |
aaaaaaaaaz576.50 |
12-13-2023, 03:19 PM | #57 |
Rep 6,911
And, something comes up, and you're there for an hour? The phone rings, your wife asks you a question, your kid has an issue, you can't find what you went in for, etc. Then what?
12-13-2023, 08:24 PM | #59 |
Rep 877
Virtually every car in existence lets you exit with the car still on, including every other BMW I've owned, so I don't consider that a very good reason, either.
M3 - X5 - 911 - Miata - Raptor - Edge
12-13-2023, 09:26 PM | #60 |
Rep 4,381
Drives: 2020 M850i Coupe
Agreed as every car I've owned has allowed me to do so. From a BMW standpoint our 2017 X5 on iD6 did. My 2020 M850i does but the car will beep letting one know that the car is on but the drivers fob is no longer in the vehicle. Just tested the wife's LCI 40i and it lets me do the same. So it's got to be a PHEV "feature" of frustration.
12-13-2023, 10:33 PM | #61 |
Rep 8,828
it doesn’t bother me. I lose virtually no time pressing the Start button once I get back inside the vehicle from a quick errand
12-13-2023, 10:52 PM | #62 |
Rep 6,911
With the PHEV's battery low, you might be in your closed garage. The engine is off...you go inside, and the engine turns on because the battery level dropped enough, so to me, at least, it does make sense to shut things off when you leave.
On my 2011 BMW, an ICE, unless the driver's seatbelt was connected, it would shut the engine off when the driver's door was opened, so that logic has been in BMWs for a long time, at least on some models. My 2014 i3 was the same way...open the driver's door with the belt off, it would shut down. So, all of my limited BMW sampling operated the same, whether ICE, EV, or PHEV. Liability and the risk of someone suing someone in the USA with the lowest ratio of people to lawyers also may be part of the issue. |
12-13-2023, 10:58 PM | #63 |
Rep 3,723
Like I said many time. Even for 45e, if you can manage to get ice running at park or neutral, you can open driver door and car will remain on and ice will remain running. So bmw decide to somehow treat EV mode differently the ICE mode.
For me, it bothers me enough I bought a fake seat belt anchor, I insert into seat belt buckle when I need to run out to get things. |
12-14-2023, 12:17 AM | #64 |
Rep 100
Have BMW ever been sued for "rollaway" incidents, especially in the US? If so, causing the drive motor to shut off might be a response to BMWs reluctance to be sued repeatedly or even being the recipient of a class-action.
12-14-2023, 12:46 AM | #65 |
Rep 3,723
then why not all cars? why only the EV portion of the PHEV and maybe EV?
2022 G05 B58/PHEV
12-14-2023, 12:59 AM | #66 |
Rep 6,911
As I said, my 2011 BMW 535i GT would shut off when the driver's door was opened, so that characteristic is not new to BMWs. So, my three types of BMW I've owned, ICE, EV, and PHEV have all operated the same exact way...open the driver's door without the seatbelt latched, they shut off. Why some appear to let the engine stay on and others don't, can't say.
