04-23-2023, 09:34 PM | #1 |
31
Rep 48
X5 50e Range
Early days but i just drove my 50e from the dealer to my house ~75 miles on hybrid mode with navigation. Reached home with 7% electric charge and 397 miles on fuel (max range was 400 miles). Maybe full charge is >40 mile pure electric range. Will keep updating as I drive more. Right now car is at the detailer for ceramics.
10
Mattl08061007.00 bbari23.00 SwissBeemer302.50 rogerramjetx59.00 AloneAlien67.50 Hicky596.00 Elle BMW65.50 wxdave70.50 aMIC31.00 |
04-24-2023, 12:38 PM | #3 |
Rep 144
[QUOTE=Bhuvi;30063664]Early days but i just drove my 50e from the dealer to my house ~75 miles on hybrid mode with navigation. Reached home with 7% electric charge and 397 miles on fuel (max range was 400 miles). Maybe full charge is >40 mile pure electric range. Will keep updating as I drive more. Right now car is at the detailer for ceramics.
Does this mean you drove 72 miles using 93% of battery? |
04-24-2023, 01:00 PM | #4 |
13712
Rep 20,388
No it doesn't. The fuel range does not predict what you will get but rather what you should get if you drive exactly like you have been for the last 20 miles or so. In this case the vehicle was new so the max range was based on the time the vehicle was run at the factory, for loading, at the dealer etc. Looking at the numbers provided I don't think any conclusions can be drawn for a number of reasons.
04-24-2023, 09:13 PM | #7 |
13712
Rep 20,388
Under normal circumstance the battery never runs out completely, it will always have some charge due to the charging by the engine so some electric assistance will always be available.
04-24-2023, 09:14 PM | #8 | |
Rep 6,946
- e-assist is always available - e-boost, requires some non-zero range value Now, say you're going up a long mountain grade and you run the battery down...at that point, you're running on the ICE and e-boost won't be available, but e-assist for a momentary assist will likely still be there, just not for long. But, e-boost is also limited in duration as the heat buildup would otherwise be an issue. There's a huge amount of learning to understand and take full advantage of the vehicle...there's a reason why the manual is over 400-pages long. The onboard videos can help as well. |
Steve737106.00 |
04-25-2023, 12:49 AM | #9 |
303
Rep 382
Is that the case though? There's been an extensive debate going on over here where the consensus seems to be that you will almost always have power from the electric motor leading to the same acceleration times, even with 0% battery, as also evidenced by this video.
70% vs. 0% 0-87mph: Same 0-124mph: 0.5s slower 0-145mph: 2.9s slower |
04-25-2023, 07:21 AM | #11 |
Rep 257
from my experience e-boost is available with --- (0) EV miles range.
there will always be e-boost available for quick brief acceleration unless you are racing on track with long acceleration periods, but there is regen |
08-26-2023, 09:34 AM | #14 | |
Rep 84
Once you learn how to use battery hold, charge on long downhills, braking, etc. you won't get any less than 45 (and I mean driving normally or even spirited, not hypermiling). |
08-26-2023, 09:45 AM | #15 | |
Rep 187
08-26-2023, 12:21 PM | #17 |
Rep 194
Drives: 2024 X5 50e
My commute to work is 46 miles roundtrip, and I don't charge at work because the prices are super high. I drive in electric mode, and when I pull into my garage at home, I'm still in electric and it hasn't switched to hybrid. That works for me.
Former: 2020 Volvo XC60, 2018 Volvo XC90 T8, 2016 X5 40e, Lexus RX 450h, Acura MDX
First: 1963 Chevy Corvair (in 1984) |
Asoliveri7.50 |
08-27-2023, 04:46 AM | #19 | |
Rep 179
08-27-2023, 09:00 AM | #20 |
Rep 8,875
Drives: eVeRyOnE mAD!
08-27-2023, 10:32 AM | #22 |
Rep 84
In normal (Hybrid) mode no - just drive. It will do so automatically.
But say you are taking a 200 mile trip. No way to cover that all electric. You want to arrive with some battery to drive electric at your destination (lots of reasons). Put on battery hold on the highway part (where ICE is more efficient anyway). Any long downhill stretches, turn battery hold off (just push the button), after downhill, turn back on and keep driving. Will add some miles on your trip. |
