01-23-2021, 02:48 PM | #1 |
Rep 21
'21 X5...Car has been turning on by itself
This is a strange one. Over the last 2 weeks, I have returned to my car (after parking it, turning it off, doors locked) at least 3 times only to find the ignition on. Yesterday I parked in, went in to a store for 45 minutes, came back and found it on. What should I be looking for?
01-23-2021, 03:02 PM | #2 | |
258
Rep 319
MJBradley1967198.00 nvsocr755.00 |
01-23-2021, 03:03 PM | #3 |
Rep 283
Just a few thoughts from a new owner:
1. Did you make sure you turned it off fully when you left the car? (I’m sure you did but had to ask ) 2. Check to see if you have a scheduled remote start in the Idrive or on your phone app. 3. Maybe monitor the status over the next few days using your app and see if it shows a status of the vehicle running to help diagnose. 4. Errant key fob presses?. Just a few quick thoughts off the top of my head. Good luck figuring that out - can be super scary! |
01-23-2021, 03:57 PM | #4 |
1169
Rep 1,780
what does it say when you get in the car? there should be a warning in the driver's side dashboard that says 'press stop/start button before driving off' or something. once you do that, then all your steering wheel adjustments and things turn on.
if you're getting that warning, it means that you're somehow triggering remote start. If you're not getting that warning, that probably means something else is not right that may need service |
kkratochvil313.50 |
01-23-2021, 04:51 PM | #5 |
Rep 21
It does prompt me to press start/stop button and then release emergency brake. How do I disable remote start? If it’s this easy to remotely start the car, I’d much rather have feature disabled. It’s not like I’m entirely unfamiliar with the car. This is my 6th consecutive X5 but probably first with remote start. I always put key in my pocket after leaving the car. Needless to say, slightly uncomfortable coming back and seeing car has been on for who knows how long.
01-23-2021, 04:54 PM | #6 | |
Rep 4,479
jg05303.50 |
01-23-2021, 05:29 PM | #7 |
1169
Rep 1,780
Even if you inadvertently trigger it, it won't stay on for longer than, i think, 15 minutes. Other various conditions also need to be met for remote start to work.
01-23-2021, 05:33 PM | #8 |
3245
Rep 1,661
Remote engine start is designed to shut off the engine after 15 minutes. I use it to precondition the interior (cool it on scorching days, warm it on bitterly cold days) when it’s parked outdoors at work. Typically I activate it via the Connected app, since I’m typically across town when I want to initiate it.
Related to Marty’s recommendation to disable remote engine start, if you return to your X5 with the engine running (with that feature still enabled and if you have the time, and if it’s not creating a carbon monoxide hazard), see if it automatically shuts off within 15 minutes. If it doesn’t, it may not be tied to that feature. |
01-23-2021, 05:41 PM | #9 |
Rep 21
01-23-2021, 06:45 PM | #10 |
1169
Rep 1,780
I do the same, except the really annoying thing is how long it takes to send the command to the BMW servers and then give you the confirmation signal. I usually send the command and then put my phone in my pocket and sometimes the command just wont go through. I guess maybe I shouldn't complain but that's why this forum exists.
01-23-2021, 08:26 PM | #11 |
3245
Rep 1,661
Same here. Confirmation of the precondition command consistently takes 2-3 minutes via the Connected app, but lately (since about mid-2019) it consistently goes through for me.
thereef5101169.00 |
01-23-2021, 09:44 PM | #14 | |
Rep 1,203
Drives: 2023 BMW i4 M50
01-23-2021, 11:09 PM | #15 | ||
1169
Rep 1,780
I can't point to a fault in the car, the app or their servers. It could entirely be the old covered parking garage thwarting the signals that's causing my intermittent signal loss. On topic: OP I hope you figure out what's setting your car off. It's quite a nice feature. I hope you come to like it eventually. |
01-24-2021, 03:10 AM | #16 | |
Rep 2,420
If I activated it and put it in my pocket before getting confirmation it usually fails too So what I do now is activating the signal and put my phone on my desk until I have the confirmation. With bad WiFi can help to switch to cellular network. |
thereef5101169.00 |
01-24-2021, 10:09 AM | #17 |
200
Rep 353
I got tired of waiting for confirmation so I finally hooked BMW Connected up to Alexa. Now I just ask her to do it and don't need to take the phone out of my pocket.
thereef5101169.00 |
01-24-2021, 11:21 AM | #18 |
1169
Rep 1,780
Hi, can you please expand on this further? we are an apple household and I was hoping I could do this with Siri but so far, I cant. How are you able to use alexa to remote start the car? Do I need a physical amzn device like an echo or can I just use the phone app to do it?
01-24-2021, 02:19 PM | #19 | |
200
Rep 353
You can use the Amazon Alexa app on the iPhone without an echo device I think.
thereef5101169.00 |
01-24-2021, 03:01 PM | #20 | |
1169
Rep 1,780
ideally i wish i could just say 'hey siri, turn on my car'. i know siri doesnt work but could an automation be created via alexa to do the same thing? that would be ideal becauase most of the day i have my airpods in my ears and can easily trigger siri. I know you can Alexa app with Siri, but I was hoping to create an iphone automation that would trigger alexa and then an alexa automation with a one word trigger. Last edited by thereef510; 01-24-2021 at 03:11 PM.. |
01-24-2021, 07:01 PM | #21 |
200
Rep 353
No, you can use Alexa hands free on iPhone, but only after you open the Alexa app. But at least you don’t have to wait for the confirmation of the Connected app
To be truly hands free you need an Echo device |
thereef5101169.00 |
01-24-2021, 07:52 PM | #22 | |
1169
Rep 1,780
so all i need is an echo right? have you tried to launch the amazon app with just Siri, and then try to execute the alexa command when the app is in focus? I will try that tomorrow when im on campus and see if it works. I'm just not sure how the iphone will respond when the phone is locked and you're trying to trigger automations solely with siri. idk why BMW just didnt open up their app for siri like they did for Alexa. |
