332.8KVIEWS
295REPLIES
177APPRECIATES
156ACTIVE PEOPLE
02-10-2026LAST POST
01-31-2019
X5 xDrive45e
07-22-2019
I will be ordering an X5 in the fall but my wife is concerned if the tailgate is an issue when loading groceries or other items into the back. I know you can leave the tailgate up and lift things over it, however, can you tell me from your experiences if it causes any issues:happyanim:? Thanks
07-22-2019
You can lower it to load and just close it when done loading. My wife is about 5'6" and has no issue loading over the tail gate. So far no issues with mine, I rather like the ability to open and unload without worry anything will fall out.
07-22-2019
Thank you. That helps. My wife is also 5’ 6”,so it looks like a go:happyanim:
01-11-2021
Anyone have the wading depth of the G05?
01-11-2021
My previous posts - regard G05 fording depth:
Fording depth at standard ground clearance of 8.7" is approximately under 20" at 19.68". With 2-axle air suspension, vehicle height adjustability is two stages to a maximum of 1.6" above the standard setting.
https://g05.bimmerpost.com/forums/showpost.php?p=24777295&postcount=2
The wading depth is just over 21 inches and there's a water passage identification system that closes your grill and maintains ride height to minimize the possibility of water damage to the engine and electronics.
https://g05.bimmerpost.com/forums/showpost.php?p=24778005&postcount=6
10-24-2021
Thanks love it.!
01-18-2025
Hello
I’m new here and just would like to know what are the thoughts from the experts here.
I’m debating to get a 2019 x5 loaded with m package
Or a 2023 x5 base model. Both around the same price $30 to $35k with 50,000 miles
I love the look of the m package and that has ventilated seats. But I fell
Is they around the same price might be better to get the newer x5.
Thoughts!?
Than you in advance
08-22-2025
This post is awesome as per sa
02-10-2026
Thanks, I like it.!
