I'm hoping that this goes away after some more break-in (1500mi so far), but wondering if others have seen this before.
Thanks.
bioman wroteCould be the AC/heat blower perhaps? I get a hum from the blower fan when it's at full speed. If I dropped the speed, the drone stopsNot sure how common this is, but getting a high pitched frequency noise coming from the electronics behind/near the a/c screen. It's relatively faint, but I can pick it up when there is no music on. If you put your ear near the a/c screen, you can definitely hear it. More annoying than anything when I'm trying to drive in silence.
Thanks.
Doc5513 wroteYou're lucky they haven't started following you yet:rolleyes:I hear nothing...except the voices in my head
MystroX5 wroteAgreed. Frankly, mine is louder than I'd like (certainly louder than my previous X5s) on the lowest setting.I did notice the climate control fan can be loud on high.
munich67 wroteYes. Absolutely. Different sounds and different problems.And again, same prob here-but ventilation and hum noise are two different pairs of shoes.
bioman wroteI have this too. I isolated it to the recirculate/external ventilation. If you have it on automatic, the high pitched sound comes from the flap closing off the external air flow. If you leave it on fresh air, the flap, stays open. It’s annoying AF when auto is on and it keeps closing/opening the flap and making the squeaking noise.Not sure how common this is, but getting a high pitched frequency noise coming from the electronics behind/near the a/c screen. It's relatively faint, but I can pick it up when there is no music on. If you put your ear near the a/c screen, you can definitely hear it. More annoying than anything when I'm trying to drive in silence.
Thanks.
lumpydog wroteNot sure but I think these might be two separate sounds. I hear the high-pitched sound referenced above when the HVAC is off completely. I do hear other annoying sounds, though, when the HVAC is on. Seems like there might be multiple audio gremlins.I have this too. I isolated it to the recirculate/external ventilation. If you have it on automatic, the high pitched sound comes from the flap closing off the external air flow. If you leave it on fresh air, the flap, stays open. It’s annoying AF when auto is on and it keeps closing/opening the flap and making the squeaking noise.
The control/flap is in the passenger footwell. I pulled the cover off and when you manually set the vent to recirculatemand back to fresh air, you can clearly hear it (There is a slight delay between changing the setting and the noise).
I leave mine on fresh air.
lumpydog wrotemine happens with the HVAC off, would the flap be affected in this case?bioman wroteI have this too. I isolated it to the recirculate/external ventilation. If you have it on automatic, the high pitched sound comes from the flap closing off the external air flow. If you leave it on fresh air, the flap, stays open. It’s annoying AF when auto is on and it keeps closing/opening the flap and making the squeaking noise.Not sure how common this is, but getting a high pitched frequency noise coming from the electronics behind/near the a/c screen. It's relatively faint, but I can pick it up when there is no music on. If you put your ear near the a/c screen, you can definitely hear it. More annoying than anything when I'm trying to drive in silence.
Thanks.
AndroidRobot wroteUnsure. The way to test is - under the tempersture readout screen/display, hit the “menu” button and then set the air circulation to fresh air (can’t remember the name of the setting but selecting it that stops the flap from opening/closing automatically and the noise should stop).mine happens with the HVAC off, would the flap be affected in this case?
lumpydog wroteMine is hard to describe, my wife rode with me and couldn't pinpoint the source either. It's not persistent all of the time, but does occur at higher speeds rather easilyUnsure. The way to test is - under the tempersture readout screen/display, hit the “menu” button and then set the air circulation to fresh air (can’t remember the name of the setting but selecting it that stops the flap from opening/closing automatically and the noise should stop).
Rereading above, we may be talking about a different noise/source. I’ve isolated this one in my X5 and it comes from the blower fan’s (passenger footwell) external air/recirculating vent flap. Seems like the noise you all are describing is more persistent
