178KVIEWS
167REPLIES
58APPRECIATES
79ACTIVE PEOPLE
12-05-2020LAST POST
05-22-2019
BIMMERPOST Logo
BIMMERPOST / NEWS
Pricing and Specs For BMW X5 M50i and X7 M50i With Newest N63 V8 Announced
• New M Performance variants of BMW X5 and X7 SAV’s.
• 523 hp and 553 lb-ft of torque and M GmbH model specific tuning.
• 0 to 60 mph in 4.1 seconds for X5 M50i and 4.5 seconds for X7 M50i.
• Pricing: $82,150 for X5 M50i and $99,600 for X7 M50i. Plus $995 Destination.
• Production to begin August 2019.
Woodcliff Lake, NJ – May 21, 2019...Today, BMW introduces two new M Performance models, the BMW X5 M50i and BMW X7 M50i, which join the X5 and X7 lineups this fall when production begins in BMW Plant Spartanburg, SC.
Both models feature the new top version of the N63 4.4L TwinPower Turbo V8 engine backed by an eight-speed sport automatic transmission, BMW’s xDrive intelligent all-wheel drive , M Sport differential, M Sport exhaust system and model-specific M GmbH suspension tuning.
Offering true sports car performance, both BMW Sports Activity Vehicles offer excellent handling and traction across varied surfaces and weather conditions complemented by luxurious interior appointments and the same towing capabilities as their non-M Performance siblings.
Power and performance
The latest generation of the 4.4-liter eight-cylinder engine features numerous detailed improvements. Two twin-scroll turbochargers with charge air cooling located within the V- shaped space between the cylinder banks, High Precision Injection, VALVETRONIC fully variable valve control and Double-VANOS variable camshaft timing all form part of the
M Performance TwinPower Turbo technology package which delivers 523 hp between 5,500 and 6,000 rpm and 553 lb-ft of torque between 1,800 – 4,600 rpm. - an increase of 67 hp and 74 lb-ft of torque over the X5 xDrive50i and X7 xDrive50i models.
A new aluminium alloy has been used to increase the strength of the engine block. The wire- arc sprayed iron coating for the cylinder walls serves to reduce frictional losses. Reinforced, Grafal-coated pistons and optimized piston rings are designed to endure the stress on the crank drive that comes with the extra output and torque. To enhance engine smoothness, torsional vibration is minimized with the help of a viscous damper on the crankshaft.
The BMW X5 M50i accelerates from a standstill to 60 mph in just 4.1 seconds with the larger X7 M50i right behind at 4.5 seconds. Both vehicles feature electronically limited top speeds of 130 mph when equipped with all-season tires and 155 mph when equipped with summer performance tires.
Eight-speed Sport Automatic transmission
The eight-speed Sport Steptronic transmission’s new control electronics help to increase the powertrain’s overall performance and efficiency. Intelligent connectivity enables the Sport automatic transmission to adapt its shift strategy according to the route and driving situation by working with the navigation system and if equipped, combining this data with information from the Active Cruise Control system’s radar sensor. This makes it possible for the transmission to shift proactively instead of reactively insuring that the vehicle is always in the correct gear for the upcoming road conditions.
Shift paddles on the steering wheel allow for quick manual gear selection, while a Launch Control function allows for accelerating from a standing start with maximum available traction.
xDrive all-wheel drive with M Sport rear differential.
BMW’s rear-biased xDrive intelligent all-wheel-drive system, found in the X5 M50i and X7 M50i, is able to split drive-torque between the front and rear wheels with great speed and precision. Full power can be directed automatically by the system to the rear wheels in situations where all-wheel drive traction is not required.
The standard electronically controlled rear M Sport differential helps support dynamic driving by optimizing the transfer of power to the road in all driving situations. Managed by the Dynamic Stability Control (DSC) system, the locking function for the rear differential improves traction and power delivery when driving over road surfaces with differing levels of grip for the left-rear and right-rear wheels by reducing wheel spin when a specific tire is struggling for traction.
Chassis and Suspension
The BMW X5 M50i and X7 M50i models feature a double-wishbone front and five-link rear suspension that has been painstakingly gone over by M GmbH. This setup provides the best balance of exceptional traction on rough terrain and excellent dynamic response and ride comfort on pavement. The bushings, spring and damper settings have all been tuned to complement the new models’ increased power and performance.
The BMW X5 M50i is equipped with the Adaptive M Suspension while the BMW X7 M50i is equipped with a two-axle air suspension system (optional on the X5 M50i) which allows for a 0.8 inch lowering of ride height when in Sport mode or when speeds exceed 85 mph. The driver may also increase vehicle ride height of air suspension equipped vehicles by 1.6” for greater ground clearance when required.
Wheels, Tires and Brakes
Both models are equipped with large M Sport Brakes featuring two-piece, lightweight compound brake disks with blue painted calipers and M logos.
The BMW X5 M50i is equipped with standard 20 inch M Star-spoke, bi-color, light alloy wheels shod with 275/45R20 all-season run-flat tires. Optional wheel and tire packages include 21 inch wheels with 275/40R21 front and 315/35R21 performance run-flat tires and 22 inch wheels with 275/35R22 front and 315/30R22 rear performance non run-flat tires.
The BMW X7 M50i comes equipped with standard 22 inch cerium grey M V-spoke light alloy wheels with 275/40R22 front and 315/35R22 performance run-flat tires. Options include bi- color orbit grey or black 22 inch wheels and 21 inch wheels mounted with 285/45R21 all- season run-flat tires.
M Performance design and features
The new BMW X5 M50i and X7 M50i models feature front bumpers with larger openings to allow for greater air flow to the cooling system. The rocker panels and rear bumpers have been sculptured to set the models apart from the rest of the line. BMW Individual high-gloss Shadowline trim and Cerium Grey highlight selected individual exterior components.
Interior features include; door sill plates feature an illuminated “M50i” logo, M leather steering wheel, gear selector with M logo, Vernasca perforated leather upholstery with contrast stitching, Anthracite headliner in the X5 M50i and Alcantara Anthracite headliner in the X7 M50i.
Standard and optional equipment
Standard equipment includes:
• 20 inch wheels with all-season run-flat tires on the X5 M50i
• 22 inch wheels with performance run-flat tires on the X7 M50i
• M Sport Brakes
• M Sport Differential
• Adaptive M Suspension
• Two-axle air suspension on the X7 M50i
• Adaptive Full LED lights with Automatic high beams on the X5 M50i
• Icon Adaptive LED with Laserlight on the X7 M50i (optional on X5 M50i)
• Active Driving Assistant including Active Blind Spot Detection and Lane Departure Warning
• Multi-contour sport seats
• Harman Kardon Surround sound system
• Live Cockpit Professional with iDrive 7 Operating system
Apple Car-Play Compatibility
• WiFi hotspot
• Wireless charging
Selected optional equipment includes:
• Remote Engine Start
• Glass Controls
• Two-axle air suspension on the X5 M50i
• Trailer hitch (7,200 lb rating X5 M50i and 7,500 lb rating X7 M50i)
• Bowers & Wilkins Diamond Surround Audio System
• Dynamic Handling Package – Integral Active steering and Adaptive M suspension professional with Active Roll Stabilization.
• Driving Assistance Professional - Extended Traffic Jam Assistance for limited access highways, Active Cruise Control with Stop & Go, Active Lane Keeping Assistant with side collision avoidance, Automatic Lane Change, Evasion Assistant and front cross traffic alert.
• Parking Assistance Plus Package – Parking Assistant, Back-Up Assistant, Active Park Distance Control and Surround View with 3D View
BMW Live Cockpit Professional: Seventh generation of BMW iDrive
The BMW Live Cockpit Professional combines a new display and control concept and the ultimate in connectivity to create a superb all-round package. The latest-generation of the iDrive comprises a high-resolution digital 12.3” instrument cluster display behind the steering wheel and a 12.3” center display diagonally across. The system offers many hardware upgrades including new haptic controls on the iDrive controller, an advanced tablet-like touch interface, stunning visualizations, and the largest displays available in a BMW. The multi-modal approach of the iDrive touch controller, large touchscreen center display, cloud based voice control, and gesture control allow users to interact in the way of their choosing.
The seventh incarnation of iDrive has a cutting-edge, fully-digital design and is geared more closely to the driver’s needs by allowing them to tailor the system to their own preferences with customizable widgets of information. This new level of personalization is then stored in the BMW cloud and can follow the customer to other BMW vehicles. Information from categories such as driving, entertainment, navigation, connectivity, and from the vehicle info itself, can be selected in nearly any combination in any of four layouts on the Center Display. Multiple pages can be created and easily accessed with a simple swipe across the screen with a finger.
Other elements of the BMW Live Cockpit Professional are the Navigation Professional system, a hard-drive-based multimedia system with 32 GB of memory and six USB ports, plus Bluetooth interfaces. The driver can be automatically detected and personal settings activated either using the traditional vehicle key or by downloading the driver’s personal settings from the BMW Cloud.
A collection of bundled digital services will be offered as the Connected Package Professional. The Connected Package Professional provides Remote Services, Concierge Services, On- Street Parking Information, and Real Time Traffic Information for the first 4 years of ownership. This package allows easy integration and adaptation of new technology over time. Customers can continue to download various new digital services individually as they become available or renew existing services via the ConnectedDrive Store.
05-22-2019
I used to think that I know almost all BMW models...not anymore!
This will help fake ///M badges to blend in and no more hate on the forums...so it's good :D
05-22-2019
I wish they offered the upgraded engines without the "M GmbH suspension tuning"
05-22-2019
X5 m50i In uk ? Anyone know ?
05-22-2019
Why? Suspension must be calibrated and adjusted to compensate for the increase in power.
05-22-2019
Yes
05-22-2019
I am totally blown away by the performance numbers of the M50i X5. This is faster than the E70 X5M. I've driven that numerous times and always came away very impressed. Bravo BMW!!
05-22-2019
Can only imagine the performance numbers for the upcoming F95. The X5 M50 is 0.1 sec slower than the F85; F95 should be mid 3 sec 0-60. Crazy for a velicle that big and heavy.
05-22-2019
"Plus $995 Destination" means that you have to pay extra cost for the delivery?
Sorry for a stupid question
05-22-2019
Can't wait to test X5 M50i.
05-22-2019
-1
05-22-2019
About 10% more than the current 50i??
05-22-2019
Pricing appears to be very similar to the current 50i m sport.
05-22-2019
There's a difference between calibrating the suspension for more power, and bringing in the M division to make it go faster around the Nürburgring.
My last two vehicles - M4 ZCP and X3 M40i had adaptive suspensions tuned by M, and both were a little too harsh to enjoy for everyday long-distance commuting, in my opinion.
05-22-2019
BMW rates the M50i at 4.1 seconds 0-60mph. I get that now so the M50i will be closer to 3.8 seconds in real world conditions. Fall production means a 2020 model if all goes smooth.
05-22-2019
goj wrote
-1
Key word being "offered"....
05-22-2019
I feel like what's happened (recently at least) is that the M240i/340i/550i and other Mxxxi line vehicles have become viable, trackable less costly options than the actual Mx vehicles which have become usable supercars. The M5 is doing 10's stock.
As for an F80 ZCP F8X, those 20" wheels with low profile tires don't help at all, but I get what you're saying. Let's not get into run flats either, those are total garbage.
05-22-2019
I thought the X3 M40i road very harsh. I believe AndroidRobot owned one and reported a similar experience. I personally don’t think 67hp more requires the suspension to be any firmer for even the most spirited driving. I can terrify my passengers going up our twist mountain roads in “Sport Plus” but BMW may feel pushing the M50i’s ride closer to the upcoming X5M was a suitable transition? I hope it’s not as harsh as the X3 M40i.
There is a dichotomy here with performance SUVs more so than with sedans that if you try to make them too stiff and hard edged for performance, you defeated why many purchased a luxury SUV to begin with. Big summer tires and harsh rides are useless in mixed weather and long distance comfort is compromised.
4 second 0-60 SUV’s are the alpha dogs of the SUV world anyway so pushing beyond that most owners will go with a genuine sports car to get a much higher level of performance and handling than what is possible in a SUV.
05-22-2019
Yes!!!
05-22-2019
It would be valuable to see all the technical changes in the updated N63 engine. Any insights where one can find this information?
05-22-2019
The M850i uses the same engine so there are a lot of info on that.
05-22-2019
If I read it right, seems to only be 2k higher than the 2019 X5 50i. Seems like quite the deal.
