VTENGR wroteI've not used 3.27 for years so can't comment with authority. If it's working for you and your use case then it should be fine.Is there a drawback to just using 3.27.1?
There may be some restrictions if you were planning to flash ECU but I don't believe you are planning to do that, so should be good.
