New classes of warships incorporated hangars and clear decks for takeoff and landing. The standard became twin hangars, although often only one helicopter was embarked.
The Navy already had a turbine-powered helicopter in service -- the Sikorsky SH-3 Sea King. But the SH-3 was too large for use on surface warships and was restricted to operation from aircraft carriers.
A helicopter had other valuable attributes: It was an excellent, though short-ranged, antisubmarine warfare (ASW) platform and could be used for logistic support as well.
The initial surface combatant-embarked helo was the very compact Kaman SH-2, originally designed as a utility/rescue aircraft.
The Navy selected the H-60 as an H-2 replacement in 1978, although the new aircraft was too large for some older ships. The initial model was the SH-60B Seahawk, which was equipped with search radar, sonobuoy launchers and electronic warfare systems and could carry lightweight ASW torpedoes. A key modification from the UH-60 was a tailwheel moved forward 13 feet in order to fit on ship's landing decks. Another was powered blade folding, to allow the helo to be hangered.
The ASW helicopter squadrons aboard aircraft carriers were also in need of replacement aircraft, and a further version of the SH-60 was ordered to replace the ageing SH-3s. This SH-60F had a dipping sonar and other ASW sensors.
A further Navy version was a search and rescue version, also used to support SpecOps, the HH-60H. Carrier helicopter squadrons would have 6 or so SH-60Fs and a couple of HH-60Hs.
The above versions of the Seahawk were replaced after 2000 by a new MH-60R that incorporated features of both the SH-60B and the SH-60F. Production of the MH-60R is complete.
At the same time, the Navy replaced H-46 logistics support helicopters with a MH-60S model. The MH-60S can easily be distinguished since it uses the original UH-60 tailwheel. The S model is also used for search and rescue, support to maritime SpecOps, and mine countermeasures. Like the R, production of the S model is complete.
Each carrier air wing has one MH-60R squadron and one MH-60S squadron embarked, although the aircraft are distributed to escorts and replenishment ships. There are also squadrons of each type that deploy detachments in non-carrier scenarios.
Both currently serving Navy versions can be armed with Hellfire missiles and machine guns. There is a total of 450-plus MH-60Rs and Ss in service.
