10.6KVIEWS
39REPLIES
20APPRECIATES
20ACTIVE PEOPLE
08-02-2025LAST POST
03-23-2024
Hello, I encountered a problem while working on my 2019 X5 40i transfer case fluid change. The car is shaking while doing tight turns, slow speed turns.
After opening the drain plug, I tried to drain the old fluid but, the hose cannot pass some gears/obstacles. When I checked it with my hand, it does not let you pass inside where oil stays.
So, I decided to change the old fluid by adding some new into the case cause I couldn’t drain any.
This failed and all the new fluid could not be added to the case and new fluid directly drops to the drain pan.
What am I missing here to drain the old fluid and adding the new one? Should I follow any other procedure to open that hole?
Cause whatever I watched on Youtube, for transfer case oil change, they all can place the drain pipe inside the transfer case very easily.
Thanks in advance.
03-23-2024
I believe along with removing an underbody protection panel, the transmission cross member needs to be removed to gain access to the oil fill plug.
03-23-2024
That part is done. It is hard to reach but I believe it is not required to remove those. I can reach out to plug and can open it. The problem is, the hole itself is going nowhere. There is an obstacle inside I believe some gears. So, I can not send the extractor hose(even a smallest one) inside to extract/fill up fluid.
03-30-2024
Inside the transfer case are two oil chambers that are electronically controlled. You need ISTA to put the transfer case into service mode (opens the gates). This will let you remove all the fluid from the case. The software will then set the transfer case to recalibrate.
03-30-2024
Where about in ISTA? Could you please let us know a bit more details. Than you
04-07-2024
Found this under ISTA. Run service function transfer box VTG - oil change - ABL transfer box VTG : oil change. Once steps are followed as per instructions on every screen was able to get about 600ml oil out from transfer case.
05-10-2024
does anyone know if this service can be performed without ista? Is there another 3rd party app that can control the vtg service mode?
05-11-2024
Without ISTA it didn’t work. I couldn’t drain the oil (maximum you can drain is around 50-100ml)
I also tried with Foxwell BMW scanner but the operation has been cancelled by indicating the temperature of the oil was 0 degrees celcius. (It was 15 degrees celcius reported on ISTA. I believe below 20 degrees celcius there is a threshold in that device and does not allow you to continue below that temperature. Just because of that message I didn’t try it again and continue with ISTA either)
I recommend warming up the oil a little bit before the procedure. (ISTA also recommends that too) In my case, I warmed up the car for about 10-15min. but it didn’t heat up the oil inside of the transfer case and I continue draining the oil at 16 degrees celcius. I think putting the car into gear would help on that one rather than idling. I could only drain about 500ml instead of 600ml. Maybe low temperature is the reason (not sure) and I hope this information helps.
05-12-2024
I had the same issues with the temp, so I went and drove the car for 20 minutes. The oils definitely should’ve been up to temp by the time I got back and tossed the car in the air, but I also only got about 550ml out. Not too worried about it.
05-18-2024
Did the fluid replacement help with your shuddering?
If you don’t mind me asking, where did you get ISTA from?
05-20-2024
I’m literally planning on changing my oil this upcoming week and reading here and elsewhere I never seen a step where the car has to be put into some maintenance mode. People did suggest to have a flexible hose because there are obstructions but ultimately you can jam it to the bottom and siphon out. 550-600ml is the volume quoted.
The only foxwell step was to initiate a recalibration. I bought the ECS tuning version since they’re running a 20% off sale and that’s my only worry finding that menu.
https://f15.bimmerpost.com/forums/showthread.php?t=1860683
05-21-2024
F15 and G05 transfer cases are different, not the same.
05-23-2024
Fair comment, but here’s a g05 video with same
05-23-2024
You can always give it a try, just in case if you can't get oil out then try ISTA function for opening the internal lock which is according to BMW TIS
05-23-2024
This is so unnecessarily complicated :(
I don’t know where to get ISTA and also only have macs, so I ended up buying the ECS programming tool because it was on sale and it’s worthless. Cold it read the temp at 0c and would not open the valve.
I did the oil change and got about 200ml of dirty oil out, replaced with new and went on a 20 min highway/city drive. Came back, tried the tool and it still said 0c and did nothing.
Did the change again, got another 100ml of dirty oil out, replaced with new and tried the calibration procedure at which point the tool would just say loading for 5 mins at a time and did nothing.
Gonna be returning the tool asap as it’s totally worthless, should just have gone with the regular foxwell so I could at least do calibration.
Went on another short ride through the city and car felt good. Still have about 600ml of oil left and a local Indy quoted me about $260 the job included with oil - should have just done that and will do that in about 2 weeks anyways.
Still happy I went through this mess myself because I learned something. And the gearbox is right there so in the future I can do that myself. Also poked around rear diff and that seems very easy to get to. Front diff seems to be more intensive?
Also, did not remove the brace, used the ECS wrench they sell and it’s easy to get to.
05-24-2024
Yeah spend the money and get a good scan tool if you want to work on it yourself. I’ve been pretty happy with my Foxwell except it did the same thing when trying to read the t-case temp. Oh well. It has been good for everything else I’ve used it for (retract parking brake, reset CBS, doing brake fluid, registering new battery, running through the trans service, etc). Though I did most of that on my 2017 540i, both my cars are B58 w/ the 8HP trans so I expect it’ll function just fine on my 2019 X5 40i.
Still, I wish I would’ve spent a little more money getting a nicer scan tool. The Foxwell works, just pretty basic interface that is sometimes slow.
The front diff has a fill and drain plug, so the process is much easier than the transfer case. The rear diff is fill plug only but you’ll have no problem getting a tube down in there to pump all the fluid out. I just did all this on my X5 a few weeks ago.
05-28-2024
Thank you for your comment - outside of ISTA setup what better off the shelf tool is there available that would allow me to do the transfer case and other things?
05-29-2024
The F95 X5M has a fill and drain plug on the rear diff.
05-29-2024
That’s great but not relevant to this thread.
06-01-2024
Welp, I took this whole week trying to figure out how to get Ista on a Mac (I plan on posting instructions) and redid everything today with ISTA - was able to activate the open, close and recalibrate functions. Got about 400ml of dirty oil out and recalibrated to 0.3deg difference, whatever it means.
Point being here is, sadly, one way or another you gotta invest in ISTA for this procedure, the diagnostic tools won’t help here.
06-02-2024
I’m in the same boat. I have an older version of ista 4.14 but it does not have the option for oil change. So I guess I need the newer version. Where did you download it?
