41.3KVIEWS
441REPLIES
335APPRECIATES
69ACTIVE PEOPLE
04-29-2026LAST POST
07-25-2025
K9-44 wrote
I asked the shop that I purchased my system from and who also did the install to reach out to Valvetronic and discuss with them the issue of the outer exhaust pipes being too short.
We spoke today and the shop stated that Valvetronic is currently working on a revised version that might be ready in a few months. I asked if Valvetronic will be replacing mine at no cost and he didn’t have an answer.
I plan on reaching out to Valvetronic directly next week. I feel since they are doing a revision then they clearly know there is a problem with the original design and it should be replaced at no cost to me.
Thanks for the info. If that's the case and they send us new outer pipes I'll hold off on installing the tips.
07-28-2025
apeas2 wrote
Can you get the trim pieces off with the muffler and bumper cover still on the car? I wonder how accessible those screws are with muffler and cover still on
Good question, guess I'll have an answer when and if I decide to have the tips installed. I have been looking at the available video's and the bottom-ass-end of my car and it doesn't look good. It appears that the muffler and several pipes could be in the way. It definitely looks like the bumper cover needs to come off to get the trim inserts out. Maybe somebody who had a hands-on experience will share...
07-29-2025
Bumper cover has to come off. I think I’ll do that in the morning if I wake up early enough. Seems pretty easy to take the bumper cover off.
07-29-2025
When the valve Tronic exhaust is installed, do you have to use the valve Tronic valve controller or can you use existing one? For example I have a an SST valve controller on it at the moment and I want to continue using that so will it just plug straight into The valves mechanism on the exhaust or do they have to actually put the valve mechanism? Sorry if it sounds like a dumb question but I’m getting installed tomorrow and I have an unpacked out of the box yet and the installer asked me about it.
07-29-2025
You can use your existing SST controller instead of the Valvetronic unit.
07-29-2025
You'll need to put the oem actuators on as the plug is different on the valvetronic.
07-29-2025
Is that a plug and play job? And they wil operate the same?
07-29-2025
If you use valvetronic controller you can use the actuators that come with the exhaust if you're using another valve controller you'll need to put the oem actuators on. It seems the actuators that come with the exhaust have a different connector than the oem actuators.
Or if you mean will the oem actuators fit on the valvetronic exhaust, then yes that is a plug and play. Remove actuators that came on it and replace with OEM from the stock exhaust
07-29-2025
Interesting the installer just contacted me. Said the actuators of the OEM doesn’t fit onto the valve Tronic exhaust. I’ll head down there in a bit and have a look.
07-29-2025
Weird they swapped mine no problem. Unless he's talking exhaust (valvetronic actuator) and oem as OEM wiring. Not the physical actuator that is on the exhaust
07-29-2025
Yeah I’m talking about the actual wiring - allowing me to use the oem harness not the physical actuator. Not sure if that’s the same thing that you were talking about.
07-29-2025
Yes you need to put the oem physical actuator on. The connector on that is different
07-29-2025
That needs to come off and the oem one back on. Only the valvetronic wiring fits that
Or leave the valvetronic physical actuator and take the connector off the valvetronic wiring and put in on your existing valve controller wiring. (Second picture)
07-29-2025
For those who have done the valvetronic or I think the dahler is the same where did you run the wire into the rear cargo area to get the power from the fuse and what Gromit or other access did you use?
07-29-2025
I contacted Valvetronic and they told me that in this Bill apparently the OEM ones can’t be switched out on the exhaust so I do need to put in the valve Tronic Setup. Just trying to figure out where to get the power from the rear cargo area. Seems there’s no cigarette lighter which is not an issue. There’s infuses there. But also where to get the wire through to the outside I need to pull spare out and have a look. I guess any thoughts?
07-29-2025
There should be a grommet in the bottom or look for any small opening that would fit a power wire from the rear fuse panel. Alternatively you can carefully drill a small hole and seal up the metal edges and place a wire grommet there.
07-29-2025
That makes zero sense at all as they say you can. I'm also pretty certain that's what they did with mine. I'll take a look at it tomorrow when I pick it up. But you should 100% be able to use oem. You can go option two though and switch the connection from the valvetronic wire with the wire from your sst control box
07-29-2025
Thanks. Seems there should be an existing access but I can’t find one. A few people have already installed in the M60 - wondering how there’s was done? I’ll pull the spare out tomorrow and have a look as well. Also thought we had a cigarette lighter outlook back there but appears not. Hmm. Just had a thought. Maybe I can pull power from the trailer socket.
07-29-2025
Ya I had my trunk all apart and still couldn't find a grommet that made it all the way down. I found some inside and under the car but none of them that connected. So if anyone has some photos of how that works or which one to use that would be helpful
07-30-2025
FYI I got the same answer from Valvetronics about using the oem valve. I got the impression their actuators won't fit in the OEM slot? It wasn't an issue of just the connections. Haven't actually had eyes on just based on conversation with Valvetronics. On a '24 m60 there is a main fuse location in the rt. Rear area. You can splice into the cigarette lighter right above the fuse location. Its my understanding the transmitter can be placed in the same fuse location. Haven't heard anything about problems snaking the wires. My turn Thursday.
07-30-2025
Thanks. Yeh I don’t think power Source is really an issue. Interested to hear back on where they feed the wires through.
07-30-2025
I have an M50i not sure if for whatever reason it's different.
