Parts list
- X5M brake calipers front in red: 34-10-9-504-107, 34-10-9-504-108
- X5M rotor splash shield (save some money and just cut yours instead): 34-10-8-074-294, 34-10-8-074-295
- X5M rotors front (SHW substitute): BFL43501, BFR43502
- EBC Red Stuff front brake pads: DP32331C
- X5M brake calipers rear: 34-20-6-898-601, 34-20-6-898-602
- X5M brake caliper bracket: 34-20-9-504-115, 34-20-9-504-116
- X5M brake pad clips: 34-20-6-881-294
- X5M rotors rear (SHW substitute): BRL43507, BRR43508
- EBC Red Stuff rear brake pads: DP32320C
- Goodridge brake lines: SBW1211-4C
- Castrol SRF
Installation
Overall pretty straight forward. Similar to Ninefourteener's experience it's worth disconnecting the negative terminal on the battery so that you avoid any CELs with the ABS system; once I completed the installation I needed to recalibrate the parking brakes before the CELs would clear.
One thing to note, the M-car wheel hub is a different part number and you will not be able to bolt down the rotor to the hub if you don't change this. I elected not to change the hub for now, and instead opted for an alignment bolt to help with ensuring the holes line up.
Overall Impressions
I knew if I just upgraded the pads and added some stainless steel lines I'd get some additional stopping power, but that wasn't the point of this upgrade...there's just something about the 6-pot calipers and drilled rotors that sets the car apart, and I couldn't bear dealing with the fomo.
I did a side by side comparison on the front rotors, M-Sport vs M-Competition, and learned they're both 395x36mm. I've previously seen others mention the M-Sport rotors are 374mm and was pleasantly surprised. The rear rotors are larger than the M-Sport.
