2.2KVIEWS
6REPLIES
2APPRECIATES
7ACTIVE PEOPLE
12-18-2025LAST POST
06-02-2025
My lane keep assist and blind spot monitoring kept shutting off whenever I would go over the lane markers so I took my 2019 X5 into the dealer. They said the vibration generator in the steering wheel has gone bad and want $1162 to replace it. I can find the part for about $120 and there are plenty of videos showing how to get to it in the steering wheel since so many people replace their stock steering wheels. However, the estimate included a $565 charge to recalibrate the lane keep assist camera. When I asked about this they said when you replace a component of the system you have to recalibrate it to let it know a part was replaced. Is this BS? I have Bimmerconnect and can see the vibration motor fault and clear it; it comes back since the motor isn't working but would it come back if it was working? Has anyone ever done this replacement? Thank you!
07-23-2025
Have you resolved this issue? I encountered a similar problem with my vibration generator, but I managed to fix it by disassembling the steering wheel and addressing a faulty connection in the internal wiring.
07-27-2025
I can’t see any reason why the camera over the windscreen would need recalibrating when it’s a ‘dumb’ non-adjustable or tweakable part you’re replacing. It isn’t anywhere near it and I’d guess the vibe gen has no feedback into the system.
Maybe a fault code would need clearing, but recalibration can’t surely be necessary?
08-10-2025
the recalibration charge for the camera is just another bs (fake) charge they are trying to get from you! 100%
Recalibration is only necessary when the camera has been moved from its initial place - like in a windshield replacement situation.
Even in that situation, the recalibration fee does should NOT exceed $200.
Long story short, anything replaced in the steering wheel should not involve recalibration of the camera on the windshield. Hope this helps
11-15-2025
Any update on what you ended up doing?
11-18-2025
How can we just code all and any steering wheel vibration off. That would be great. Do we ask someone to create this coding?
12-18-2025
Well I can give confirmation that the camera doesn’t need recal if you’re just changing the vibration generator. Replaced it on mine and no issues, I did unplug both batteries.
