453VIEWS
1REPLIES
1APPRECIATES
2ACTIVE PEOPLE
08-12-2025LAST POST
08-02-2025
I can't get the door open. I already had the panel removed because I was going to replace the broken door handle carrier and didn't get around to it. I had been using the pull that inserts into the door panel to open the door. That had been working fine. Now the door latch won't release. The door is unlocked and the lock/unlock mechanism works. I tried manually manipulating the mechanism by hand and it actuates but does not actuate the latch. I also have the driver's rear door panel off, and using the same method I'm able to get the door to open.
I can't get at the 3 external screws to remove the door latch because the door won't open.
I sprayed some deep creep on each side and I am letting that sit. Opening the rear door allows me to get the deep creep in by the latch area.
Is there a trick other than removing the rear passenger door to get at the door latch screws?
Any other ideas?
08-12-2025
Any other ideas?
is the rear passenger door the issue and only issue? I only read it at your very last sentence about which door this is.
what do you meant by "Now the door latch won't release. The door is unlocked and the lock/unlock mechanism works. I tried manually manipulating the mechanism by hand and it actuates but does not actuate the latch."
The door is unlocked but latch is not released? how do you know lock/unlock mechanism is working?
See if this helps:
