16.6KVIEWS
0REPLIES
1ACTIVE PEOPLE
09-03-2025LAST POST
09-03-2025
BMW X5 E53 2004 3.0 Automatic
Hey Everyone,
I have an issue with my 2004 BMW X5. I have tried a lot of things to get this code fixed. I will list all of the solutions I tried below. After each fix, I deleted the code and went for a 20-mile test ride. I will try to keep this post straight to the point and would love all of the feedback I can get. I need to pass the smog on this car.
Problem: P1093 (1/1) Stored Pre-Catalyst Fuel Trim System Too Rich Bank 2 DTO Severity 2 of 3:Repair immediately if there are drivability issues.
Attempt 1: I tried removing the air filter, thinking that the engine was not getting enough air and that is why it was running rich. I also swapped the MAF sensor.
Attempt 2: I swapped the O₂ sensor places and put the bank 1 sensor into bank 2 manifold exhausts—put bank 2 sensor into bank 1 manifold exhaust,
Attempt 3: I swapped the fuel injector bank, putting the first 3 injectors to the back and the back 3 injectors to the front. I also cleaned them up and the slots they go in.
Attempt 4: I removed the coils, checked out and replaced the ones that were in worse condition, and also pulled out the spark plug and cleaned up the sparks.
Feel free to ask any question or give feedback. I think I hit a dead end on where else to look. Thank you all!
