1.1KVIEWS
6REPLIES
5ACTIVE PEOPLE
03-26-2026LAST POST
TurtleBoy wroteThanks, grok was wrong again.What is listed on the web site is all that is available for Bimmercode. There is no way to turn off ASS or set the default driving mode using any available tool.
TurtleBoy wroteYou can turn off ASS in idriveWhat is listed on the web site is all that is available for Bimmercode. There is no way to turn off ASS or set the default driving mode using any available tool.
TimmyBHGM5 wroteYes, but only temporarily on iDrive 8.5/LCI vehicles. You'll basically have to do it each time you start the car from the quick menu pull down.You can turn off ASS in idrive
Is there a sheet available that shows what can be coded on a 2026 X5?
Wintrmte wroteThe sheet would be very, very small, just a few sound options.What about coding using BimmerUtility? I would like to see about enabling Comfort Plus mode, maybe some of the traffic light stuff.
There are some pro coders that can enable anti-dazzle and there is a company that can provide signed NCD files so you could do coding as normal but have not heard anything one way or another as to whether it works or they are reputable.
Edit: The site is blocked by this forum so not sure of that says anything or not. Use your OEM Navigations should pop up.
