175.7KVIEWS
209REPLIES
148APPRECIATES
33ACTIVE PEOPLE
5 hours agoLAST POST
04-29-2026
ok Max Well's user avatarMax Well OhioSpyderman's user avatarOhioSpyderman maybe it works now? (would have to refresh browser cache) :)
04-29-2026
Trying 'Smiley's in Edge (Current Version 147.0.3912.86 (64-bit) - :) ; Result - Successful. :thumsup:
04-29-2026
Trying 'Smiley's in Chrome (Current Version 147.0.7727.138 (64-bit)) - nothing (and font color doesn't work), nor does highlight... :-)
04-29-2026
Trying 'Smiley's once again in Firefox (Current version 150.0.1 (64-bit)) - :) ; Result - Successful. :thumsup:
04-29-2026
:D
Works!
Great Job apptest's user avatarapptest
Bob.
04-30-2026
How are we doing today :D
05-01-2026
Trying 'Smiley's in Chrome current version once again - :) Works this time - good work, apptest's user avatarapptest :thumsup:
05-02-2026
Just a quick one, what is with the pinned posts on the off topic section and how do I remove said pinned posts?
05-02-2026
Your main page used to have a RSS feed but now it’s not working anymore. Was it removed on purpose? Any plans on adding it back?
05-02-2026
TBH I don't know the first thing about RSS, I built one back in at /rss. can you check it out and see if its useful?
05-02-2026
It works, thanks!
05-03-2026
I noticed that as well. apptest's user avatarapptest mentions pinned threads in his first post in this thread under "New additions" so it's probably being worked on, or going to be.
05-05-2026
There are multiple threads when I try to open show only a gray screen. I am on the AP. Anyone else having similar problems? All of these have a lot of activity just unable to see any of the content. Just a gray screen.
05-05-2026
Can you post up which thread, in which forum/site and I can take a look
05-05-2026
Ervin87's user avatarErvin87 Did that solve it for you?
05-07-2026
Yes. Thank you VERY much.
05-13-2026
apptest's user avatarapptest - great to see the location and car details showing up again on the side without having to hover - thanks! I know you are swamped but curious if you have a rough ETA as to when we might expect to be able to check on our attachment download numbers again? :)
05-13-2026
No ETA but its alot closer then you think (like very close!). I'm curious, on the old site, what was your workflow for viewing those stats? Im creating something a little different and more robust for it
05-13-2026
It'll be easier for you to F/U with what I write here by going to one of the sites still using the old version to see this flow for yourself, but here goes:
Just as example I went to the F44 BMW 2-series Gran Coupe Forum page as it is still old format.
After logging in, the upper main title bar which shows an image of the F44 and the Sub-Forum title in large font then populates in its lower right section seven potential clickable options: "User CP", "BMW Garage", "BMW Meets", "New Posts", "Search", "Quick Links", and "logout".
Clicking on "User CP" opens a left-side oriented vertical column entitled, "Your Control Panel" which includes a host of well-organized and useful options with sub-titles. The last sub-title at the bottom of this lengthy column is "Miscellaneous" which has two clickable options:
-Event Reminders
-Attachments (I placed underline and bold to emphasize to you the one I always go to, it is in normal font on the site)
Clicking on "Attachments" opens a 3-column organized list with master title, "Attachments Posted by Max Well", and the 3 columns are "Attachment", "Title", and "Date". The "Attachment" provides the 'image size', the '# of downloads', so one can get a sense of which attachments provide the most interest and relevance to Forum Members. And the Date posted allows one to track the duration of interest. All important variables (at least to me) when trying to sort out which information is best to share in attachment form, what size, etc.
Hope this helps answer your question. :)
05-14-2026
-Event Reminders
Ok ive added that function which you can find if you click your user name at the very top right of the screen, then in that drop down you will see it, im currently working on the sorting function to sort by the size or views, etc.. im also going to work on it slowly to add some more features as time passes, but if you had ideas im also all ears
