I’ve been looking at the TSW Aileron in 22", which TSW lists as compatible with the G05 chassis. However, the specs differ slightly from the OEM 22" staggered setup, so I wanted to get some opinions before moving forward.
Front:
OEM – 22x9.5 ET37
TSW Aileron – 22x9 ET37
The Aileron front wheel is slightly narrower but keeps the same offset, which seems like it shouldn’t cause any issues based on what I’ve seen on wheel-size.com.
Rear:
OEM – 22x10.5 ET43
TSW Aileron – 22x10.5 ET38
The width is the same, but the offset is 5 mm lower than OEM. Wheel-size.com mentions this would push the wheel outward and change the scrub radius by about 6 mm, which could potentially affect handling.
My main concern is whether this rear offset difference could cause any real-world issues such as rubbing, clearance problems, or noticeable handling changes.
For those familiar with the G05 platform, would this setup still be considered safe and practical, or is it better to stay closer to the OEM 22" offsets?
Appreciate any feedback or firsthand experience before I go ahead with the upgrade.
