M5Rick wroteMercedes CAUGHT (!)A MAX wipe out , eat his dust
///M Power-Belgium wroteAI slop and click-bait.Mercedes CAUGHT (!)
Car-Addicted wroteSpot on (!)
Car-Addicted wroteSay it's true Merc has variable compression. Are they allowed to make changes to the engine post June 2026? If not, can they still do it and get away with it?Motorsportive @MotorsportiveHQ
2h🚨 BREAKING: FIA to ENFORCE STRICTER engine compression ratio tests from June 2026.
New rules require compliance at HIGH TEMPERATURES, targeting allegations Mercedes' design exceeds the 16:1 limit when hot.
Mercedes DENIES the claims. The change aims to CLOSE a technical loophole and ensure a level playing field.
As I said before who was stupid enough not to see this was an issue. Anyone who has performed a leak down test knows temp is critical for accuracy.
Toad wrote2026 Formula 1 engines are subject to strict homologation rules where power units are sealed by the FIA to prevent illegal, in-season modifications. Manufacturers must submit their final, detailed technical dossiers by March 1, 2026, locking in their designs to control development costs and ensure fair competition.Say it's true Merc has variable compression. Are they allowed to make changes to the engine post June 2026? If not, can they still do it and get away with it?
Car-Addicted wroteIf Merc went to confession, the priest would feint.Motorsportive @MotorsportiveHQ
///M Power-Belgium wroteBetter than my twin turbos heheh
Toad wroteWhile Merc say they're already in compliance, here's the scenario if indeed change is needed:Say it's true Merc has variable compression. Are they allowed to make changes to the engine post June 2026? If not, can they still do it and get away with it?
Now a sticky wicket, engines in service will have higher leak downs based on hours and conditions. IMO the only way this test is valid is fresh off the dyno and compression test and seal. In season this becomes problematic.3798j wroteBut how can they modify the engine if it is already sealed, as Car-Addicted says?Mercedes, therefore, if it has to intervene on the V6, could introduce modifications on the second engine, which would be introduced around then providing reliability is up to scratch."
https://www.motorsport.com/f1/news/f1-compression-ratio-there-will-be-a-tolerance-for-measuring-it-when-hot/10804160/
Toad wroteThe "sealed engine" rule won't come into play because of the FIA's change in testing compliance. With new testing rules, Merc will be allowed alter its engines (if needed). Picture a field of only 14 cars if cars using Merc PU's weren't allowed to take the grid.But how can they modify the engine if it is already sealed, as Car-Addicted says?
3798j wroteI'm probably slow here, but to be clear: Mercedes and all the other engine manufacturers will be allowed to break the seals because of this rule change?The "sealed engine" rule won't come into play because of the FIA's change in testing compliance. With new testing rules, Merc will be allowed alter its engines (if needed). Picture a field of only 14 cars if cars using Merc PU's weren't allowed to take the grid.
Toad wroteTeams can perform the same compression test as the FIA. If a manufacturer finds their PU will pass the new "hot" rule...they'll do nothing.I'm probably slow here, but to be clear: Mercedes and all the other engine manufacturers will be allowed to break the seals because of this rule change?
3798j wroteSo Mercedes played their cards well thenTeams can perform the same compression test as the FIA. If a manufacturer finds their PU will pass the new "hot" rule...they'll do nothing.
M5Rick wroteThey are not forgiven..hehIf Merc went to confession, the priest would feint.
Car-Addicted wroteNot good for me = not good for everyone lol
