1.4KVIEWS
72REPLIES
2APPRECIATES
2ACTIVE PEOPLE
03-21-2026LAST POST
03-17-2026
A BMW user wrote
Again, the OBD2 device you are using for BC can ALSO be used for ANY software (like BU). BU's website wants you to think you need another one because they probably make money on you doing that. Lame.
All you need to do at this point is buy and download BU. Then figure out how to use it carefully on your tiny phone screen.
You'll then be able to code more stuff like the xOFFROAD pack, which is super cool. It'll make the $109 + tax feel more worth it.
Alright, Sounds good!
03-17-2026
Id advise that you ONLY use BU for the modules missing in BC. In other words, don't surf around looking in that app. It can be dangerous vs BC is intuitive and not really dangerous... Learn from my mistakes.
03-17-2026
I know I’ll use it in the morning when I’m FULLY Awake and be very careful. Is there any way you could screenshot all the information that needs to be changed so I don’t screw anything up? It’s be seriously appreciated. We’re treating BU like Covid-19..
03-17-2026
Wear a mask while coding lol!
DSC_VIP_IB4:
IntRxSWINVarianten Nr002 G07 _RxSWIN_neu (02)
C_SLA_UCC_Land_aktiv Werte (FF,FF,FF,FF)
C_UCC_vorhanden Werte (01)
C_SLA_Anzeige_Zusatztexte Nr001_aktiviert
C_SLA_aSLA_Land_aktiv 0xFFFFFFFF (FF,FF,FF,FF)
C_SLA_aSLA_vorhanden Nr001_vorhanden (01)
C_SLA_Vorausschau_Land_aktiv 0xFFFFFFFF (FF,FF,FF,FF)
C_SLA_Vorausschau_Land_aktiv_erweitert Werte (FF,FF,FF,FF)
C_SLA_Streckenregelung_vorhanden → NR_002_vorhanden_SLA_entkoppelt
C_SLA_Streckenregelung_Land_aktiv 0xFFFFFFFF (FF,FF,FF,FF)
C_SLA_Streckenregelung_Land_aktiv_erweitert Werte (FF,FF,FF,FF)
C_VZA_Funktion_Land_aktiv Werte (FF,FF,FF,FF)
EM_ElectronicHorizon_MostProbablePathBending - kParameterSet01
EM_AdasIntegration_AdasExtendedPdu - enabled
Also this if you enabled COASTING: C_Segeln_Topologie - nr003_accdcc (03)
Then this stuff too:
SAS3:
C_UCC_vorhanden Nr001_vorhanden (01)
C_SLA_aUCC_Land_aktiv Werte (FF,FF,FF,FF)
C_ACC_verlaengertes_Wiederanfahren_ohne_Resume Nr001_aktiviert (01)
C_ACC_verlaengertes_Wiederanfahren_Laendermatrix Werte (FF,FF,FF,FF)
C_ACC_verlaengertes_Wiederanfahren Nr001_aktiviert (01)
C_Umschaltung_ACC_DCC Nr001_aktiviert [01]
C_QmaN_vorhaden - nr001_vorhanden
C_RGA_Funktion - nr001_vorhanden
C_rechtsueberholden_verbieten - nr001_aktiviert
Em_ElectronicHorizon_MostProbablePathBending - kParameterSet01
C_SLA_qmaN_Land_aktiv - FFFFFFFF
C_Rga_Land_aktiv - FFFFFFFF
C_RGA Seitenwahl_links_Land_aktiv - FFFFFFFF
And again this if you enabled COASTING: C_Segeln_Topologie - nr003_accdcc (03)
03-17-2026
DSC_VIP_IB4:
SAS3:
C_SLA_Streckenregelung_Land_aktiv_erweitert Werte [...]
Thank you so much! I will NOT Wear a mask I need full visibility LOL!
03-17-2026
And after you get the newest version of BC, decode the DLS_VERBAUT back to not active.
You need to uninstall and reinstall that so you not only have the newest version but also so you force BC to install all of its support files. It downloads that on the first connect. THAT is how I saw all those additional matrix/antidazzle coding lines. You definitely will see an improvement.
03-17-2026
I have the latest version of Bimmercode, Are you sure to disable DLS?
03-17-2026
Yes, it seems to dim the lights a little and make the tunnelling too big.
I thought you said you cannot see any of the DLMB and MXB lines of coding in BDC using BC??? Those are crucial for getting the most light and best functionality.
Because you sure as hell don't wanna try to do that in BU.
03-17-2026
Haha, I just re-installed BC and I’ll try and find it in a bit. Appreciate it!
03-17-2026
Got a question FOR YOU this time. Do your low beams swivel with the steering wheel going like 10mph or so? Only my high beams swivel starting at about 32mph. I could've sworn my low beams swiveled before I messed up in BU the other day.
I can't figure out how to get them to swivel at neighborhood slow speeds again! Very useful for seeing people dressed in all-black walking their dog late at night.
03-17-2026
So to be clear, I get better results from having dls_verbaut to not active after coding ALL of this:
C_AFS_ENA - 01
C_AFS_EX_FOG_ENA - 01
C_AFS_EXT_CNTRY_IGNORE - 01
C_BLC_DRIVING_ON_RIGHT - 01
C_BLC_PRE_ENA - 01
C_BLC_PRE_H_ENA - 01
C_BLC_STREET_TYPES — 00, FF
C_CLC_BLINK_ENA - 01
C_CLC_ENA - 01
C_CLC_EXT_ENA - 01
C_CLC_REV_ENA - 01
C_DLMB_BLC_MXB_ENA - 01
C_DLMB_ENA - 01
C_DLMB_LSR_LOWB_ENA - 01
C_HBA_DIM_Delay - 0A
C_HBA_DIM_ENA - 01
C_HBA_ENA - 01
C_HBA_FOG_ENA - 01
C_HBA_GFHB_ENA - 01
C_HBA_GFHB_HGWY_ENA - 01
C_HBA_PLATOON_MODE_ENA - 01
C_HBA_SWITCH_DEL_T - 03
C_MXB_2D_ENA - 01
C_MXB_ENA - 01
C_MXB_GAP_ENA - 01
C_MXB_HWY_LPT_ENA - 01
C_MXB_BLC_ENA - 01
C_DLMB_BLC_MXB_FLA_ENA - 01
C_MXB_PRES_MHB_DESIGN - 04
C_MXB_PRES_REAC_L_DESIGN - 04
C_MXB_PRES_REAC_R_DESIGN - 04
C_MXB_PRES_REAC_L_DELAY - 03
C_MXB_PRES_REAC_R_DELAY - 03
C_CLC_CURV_V2 - ECE
C_CLC_CURV_V3 - ECE
C_CLC_EXT_ENA - enable_roundabout
LUT_AFS_DRV_H0R - G05_Laser_ECE
LUT_AFS-DRV_VERT - G005
Laser_G015_Laser_AHL_ECE/G07 _ECE/Laser_US
LUT_AFS_CODRV_HDR - G05_Laser_ECE
C_HBA_GFHBA_ENA_V_HI - 28
C_DLMB_BLC_ENA_V_LO - 28
C_DLMB_DLS_MODE - 02
C_BLC_Cont_Zero_Ena - 01
C_BLC_Drivingexperience_ENA - 01
C_FLC_ENA - 01
C_AFS_EXT_ENA - 01
C_DLMB_MOTO_BLC_ENA - 01
C_DLMB_MOTO_VERT_OFF_ENA - 01
C_BLC_PARALLELISM_HB_ENA - 01
03-17-2026
C_AFS_ENA - 01
C_BLC_PRE_ENA - 01
C_CLC_ENA - 01
C_CLC_EXT_ENA - 01
C_CLC_REV_ENA - 01
C_DLMB_ENA - 01
C_HBA_DIM_ENA - 01
C_HBA_ENA - 01
C_HBA_FOG_ENA - 01
C_HBA_GFHB_ENA - 01
C_MXB_2D_ENA - 01
C_MXB_ENA - 01
C_MXB_GAP_ENA - 01
C_MXB_BLC_ENA - 01
C_CLC_CURV_V2 - ECE
C_CLC_CURV_V3 - ECE
C_FLC_ENA - 01
C_AFS_EXT_ENA - 01
Sounds good! Will adjust them tomorrow morning and code with BU for the other stuff.
03-17-2026
They swivel perfectly fine with the DLS coded to Matrix when turning the wheel at any speed even in Park.
03-17-2026
Weird, not mine no matter how I code dls_verbaut. It's gotta be a different line of coding or maybe because all that add'l coding with dlmb or mxb. I didn't have that stuff coded before updating BC. Oh well the advantages outweigh the low speed swiveling and the vehicle is being driven at road speeds a lot more than thru my neighborhood.
03-17-2026
At this current moment I have no DLMB or MXB coding added, Just DLS and the Swiveling movement.
03-17-2026
I guess BU does not work with my UniCarScan adapter as it’s always trying o get a connection and I told the app I was using an Adapter.. Bummer.
03-17-2026
There's an option menu where you can set the adapter. Did you try that?
03-17-2026
I did and no luck and I couldn’t find the Bimmercode stuff. But I found a good “Work Around” I just have to set it from Automatically to Manually. Just wondering what’s the difference?
03-17-2026
So manually finds the adapter?
03-17-2026
No I’m talking about the manual mode for the speed limit assist lol.
03-17-2026
A BMW user wrote
I use a wired obd connection for more reliability and speed. I can use any software with this one... Probably because it is wired.
https://www.amazon.com/Bluechok-Ethernet-Interface-Cable-Coding/dp/B07Y5FJ695
https://www.amazon.com/Ethernet-Adapter-ABLEWE-Network-Compatible/dp/B0837QGZMY
Weird.. in the Automaticity mode the Region warning will deploy but I switched it to Manually and turned the car off and restarted it and it ended up going away even after messing with the Adaptive Cruise/Assisted Driving so I guess that’s my work around.
