1.3KVIEWS
13REPLIES
5APPRECIATES
3ACTIVE PEOPLE
04-03-2026LAST POST
03-21-2026
Hey everyone,
I’m getting an error about my chassis restricted, continuing to drive possible. There’s no cel or any other errors on my screen. No codes! So confusing. Is this my 60a battery starting to go? How do I test it?
No lowering springs or suspension work done. Car has a Racechip and exhaust flap controller.
This is a new error. I cleared codes (there were none related to this) and it returned. Screenshot of active codes after the error came back.
03-21-2026
Had a similar issue - both batteries needed replacement per dealer. Started using a trickle charger after that.
X
03-21-2026
I guess it’s time! Any idea how to test them? Especially the one under the hood..
I think BimmerLink reported that my main battery was at 70%, but I think that was just the state of charge.
03-27-2026
What stops working when the aux 12v battery dies? The car seems very rough driving over pavement. Very uncomfortable. From my understanding, on an f95, only the active sway bars run off this system, right?
I’m surprised there’s no codes. How can I narrow down the root cause?
03-28-2026
Hook up a diagnostic/scan tool to the OBDII port and pull the codes. Or have the dealer/trusted independent shop do it. A lot of faults will get stored, but sometimes they won’t always activate the CEL for various reasons.
Good luck, curious of the outcome. Sounds frustrating.
03-29-2026
Thanks for the reply. Sadly, no codes related to this. The closest thing I could see was this, but it happened about 1000 km ago and clearing it (plus any other faults) didn’t prevent the “chassis” error come returning. Another scan didn’t reveal codes
I replaced the aux battery (what a pita), but I’m still getting this error. How would the dealer troubleshoot this?
Edit:
It won’t let me upload the image. But here’s the error code that stood out. I don’t think it’s related but it could be.. (I cleared it, and when the chassis error returned, which happens every drive now, this error code wasn’t present during the scan)
030E06
Error description
Power management: energy availability, consumer degradation active
Mileage
77,371 km
Error symptom
Error status
Error not present currently but stored
Error severity
Error would not cause a warning indicator
03-29-2026
I took a closer look at the mileage reports and it was actually only 200 km ago! This could be my smoking gun. ChatGPT says it’s likely the IBS and to disconnect it as a test.. I’ll be doing that tomorrow.
03-29-2026
Yeah, troubleshooting it sounds sort of like shooting into the dark. The dealer diagnostics might break it down a little better. But yeah, the few people with experience sorting that out prob wear a bmw tech uniform.
I’m all about changing parts until it’s figured out tho! I’d be concerned about a connector having corrosion or a broken wire, but maybe the car is newer, not so much corrosion.
Oh, If you haven’t checked before, take a look at the M5 forums. Similar car, but a whole lot more of them. So somebody there might have had this problem before.
03-30-2026
Excellent idea re M5 forum! I’ll give that a shot.
And I wish more information were available :( I’m also thinking it could be a corroded or lose connector. Everything looks good though.
I unplugged the IBS and it takes a bit longer for the error to come back - with the sensor, I get an error within 5 minutes of driving. Without the sensor it can take 15-20 minutes of driving.
CGPT thinks it might be a loose ground - the main battery ground is perfectly secure and no corrosion. Ditto for the second battery in the chassis. I haven’t checked other grounding points but the car is pretty clean and no real corrosion.
Troubleshooting continues.
The good news is that everything works properly before the error. So I don’t think I have an actual failure. The car is very comfortable before and uncomfortable / doesn’t feel planted after the error…
03-31-2026
I suspect it’s my main battery dying or perhaps a connection linking the aux battery to the car’s power system.
Can anyone with BimmerLink pull up the value for “voltage additional power storage”? Mine says 0.00V which makes me think I popped a fuse somewhere connecting the aux battery.
04-01-2026
Ok, apparently additional power storage might be a mild hybrid thing, so I’m ignoring that for now.
I have the following error though:
34F100: Power management: Safety function: AGM battery failure
I can’t tell if this from when I swapped my aux battery or current. There’s no mileage marker with the error. It’s under “info” error codes. I can’t clear it..
I bought a $50 battery tester off Amazon and it reports my battery is excellent.. I don’t know how accurate it is because it’s a nearly 6 year old battery. I’d hate to replace a second battery and still have this problem.
04-01-2026
Just swap out the 48v battery right quick. Just kidding.
04-02-2026
I swapped out both batteries now and the issue persists LOL.. fml!
04-03-2026
Wtf. Tricky issue.
