03-25-2026
B58c 2019 G05 x5 40i, yesterday i decided to check the oil level and found out that the car was below the max level which is weird because it's always been right at the max, cars never burned or leaked oil. Didn't think much of it then today i checked the oil level again and found out that it went from 3/4 down to 1/2, in a panick i started searching for leaks and making sure it wasn't burning oil (blue smoke) i found nothing, made sure oil wasn't going into the cooling system aswell. no idea whats causing this issue, the car doesn't appear to be burning oil i know the oil level sensor is faulty sometimes the test fails which can be corrilated with a bad oil pump however a lot of the time it works. I have been driving the car hard but to consume at least 2 quarts of oil in 300km is outrageous.
Have something to add?
Join the community and share your thoughts.
