I’m currently dealing with a persistent swirl flap issue on my 2020 BMW X5 M50d (B57S Quad-Turbo) with 170k km. I am planning a full physical delete, but want to handle the software side myself using BimmerUtility and E-SYS. I'm afraid of the flaps and snapping ruining engine.
The Problem:
I am getting fault code 2F8500 (Swirl-flap controller, position sensor, signal: Too low).
Live data under WOT confirms the severity — at 2930 RPM boost reads 3280 hPa against a nominal of 3859 hPa. At 4234 RPM it's 3431 hPa vs 4037 hPa nominal. Consistently ~600 hPa under target at full throttle. At partial load the actuator tracks fine (30° commanded = 30.21° actual, no fault). Failure only at the full-open extreme
The Hardware Plan:
Full removal of the rod and plastic flaps from the aluminum intake manifold.
Plugging the manifold hole.
The Software Questions:
I am looking for the specific FDL parameters in the DDE (DDE8) to permanently suppress these monitoring functions via OBD without a bench unlock.
After the physical delete I plan to do the ISTA adaptation reset (Vehicle Management → Service Functions → Powertrain → DDE → Adaptations → ABL) followed by FDL coding via E-SYS + BimmerUtility to permanently suppress the 2F8500 monitoring.
BimmerUtility Experience: Has anyone successfully used BimmerUtility to code out these specific checks on a 2020 G05? Is this DDE usually write-protected for FDL changes via OBD?
What I need specifically:
Confirmed FDL parameter names inside the B57S DDE CAFD to disable swirl flap fault monitoring — the master enable switch and any position plausibility checks
Whether anyone has done this successfully on a 2020 G05 via OBD without a bench unlock
Whether there are any secondary parameters I need to address to avoid blocking DPF regeneration after the delete
Has anyone done this on a G05 M50d or similar B57 platform? Any confirmed parameter list would be hugely appreciated — happy to post full results back here once complete.
Thanks in advance!
