676VIEWS
17REPLIES
4APPRECIATES
9ACTIVE PEOPLE
05-12-2026LAST POST
04-23-2026
Hi - my 2024 x5m just received a drive train malfunction at 19k miles. anyone else had this before? It went in limp mode and after parking the car and calling for a service appointment, when i went to start it again, the drivetrain malfunction error went away and it had a check engine light on but no more limp mode.
I had an oil change the previous week, could the tech have some how messed up the oil change that would correlate to this? i am waiting for my SA to get back to me on the cause. but i havent able to find many cases of the x5m having this issue, looks like this is common for the x5e
04-24-2026
So all cylinders were misfiring. SA said they ran the test plan and took for a road test and the error was cleared. They did not replace anything and said if it comes back again, they would have to open a case with BMW. Should I be concerned ? What would cause cylinders to misfire and drivetrain malfunction but have it go away by itself ?
04-24-2026
Sounds like software and I haven't heard of this happening on our models. I'd drive like normal but watch and listen for anything out of the ordinary. But, I'm sure it'll be fine. Keep us posted.
04-24-2026
I had a nightmare a few years back on my 2022 X6M with all kinds of crazy issues from not starting, to uneven roadways alerts when none existed and then drivetrain malfunction. There were other alerts/issues that don’t immediately come to mind. This went on for weeks. It was determined that a software update went bad. Hope they figure it out. Good luck.
04-24-2026
Not sure if it was the limp mode but idle was rough and the car kind of vibrated a bit when it was in limp mode due to drive malfunction. But the car seems to drive fine now so I dont know if maybe I got bad gas ? I did fill up right before this happened
04-24-2026
BMW troubleshooting process is a head scratcher....whenever I clear a code without addressing what triggered the error code...the code is bound to come back. You have to deal with the cause or the issue will come back. Ok, so what am I missing here?
04-27-2026
Just had the same drive train issue this weekend with my F95 2024. software update over air in April went probably wrong. Today my local dealer did a just released software update and now all ok…fingers crossed
04-27-2026
Were you on 03/2026.30?
04-28-2026
Correct and now 03/2026.50
04-28-2026
Did the dealer confirm that the previous version can cause the drivetrain issue? Or were they just guessing ?
05-10-2026
Just hit with this as well.
2026 X5M Comp w/ 7,000 km
"Drivetrain malfunction"
• Alert came came without warning. Car flat-bedded to dealer.
• Dealer replaced the ISM and returned the vehicle to me.
• Drivetrain malfunction occurred again that same day after the first repair.
• Currently in the shop, two weeks and counting...
• Latest dealer communication calls the issue a "known software issue" with a fix planned for July. No idea if this purported fix is part of a SIB (that's too new for inclusion on NHTSA), QI Campaign, or a Service Action/Measure.
My guesses:
• I am on 03/2026.30 and didn't have issues before the update, so possible that 03/2026.30 contributed to the error.
• A "July" fix sure implies that 03/2026.70 will address this issue. How do they know? Do they have a fix working already?
• BMW did not appear to recommend 03/2026.50 (I-Level 532 OTA version or 540 dealer-only version I believe) to my dealer as a full or partial fix, but I'm going to push for that just in case based on your comments, Guys.
I hope they don't expect me to wait patiently until July.
05-10-2026
My goodness that is terrible. I wonder why they couldn't try to backdate the software to render the car drivable? Interesting these issues only seem to be happening to a select few.
X
05-10-2026
Excellent idea -- I'll ask about that tomorrow. I had been enjoying the improvements to CarPlay reliability, but would happily sacrifice that (and whatever AI they added to the Nav recommendations) for a working vehicle that won't leave me on the side of the road.
05-11-2026
05-11-2026
Rfsbranch wrote
It's starting to smell lemon-fresh, that's for sure. BMW Customer Support has been useless to this point. I'm in a jurisdiction that doesn't have strong lemon laws, but I'm definitely not "going away". I really don't want to threaten anything legal at this point, as I suspect everything will get very formal, very fast. (?)
Lots of ways to approach compensation including: buyback, cash payment (calculated using estimated depreciation, monthly payments while off road), extended warranty and/or service package, etc. I've also purchased full PPF, OEM winters, and a hitch.
Open to ideas on what would be most likely to succeed.
05-11-2026
I've had one and known people that have done buybacks. Mine was an Audi and had to work with my dealer's Service Manager. I had viden Audi USA a deadline to fix the issue and when it came they did the right thing. They gave be a 100% credit on the OTD price (as they should for you) and $5k cash towards new car for my troubles. Also gave me a loaner for the 3 months until new build came in.
Porsche was the same way with a friend who had a new Macan with a bad cam or crankshaft.
BMW could be a bit more of a challenge where you are but I would try the polite way first before threatening any action. Clearly with your car I would tell them "the dog don't hunt" :lol: There is zero way I would wait until July, they want to make their problem yours.
05-11-2026
A couple of us had this happen but for different reasons and had different fixes. For me I had it come right after driving over a few aggressive speed bumps out of a toll exit. I pulled over immediately, turned the car off, waiting a minute or two and fired her back up. Didn't have an issue the rest of the week but also took it in and the only response I got from the dealer was it was a "software glitch" and it was fixed. Luckily I haven't had it come back since. It's been about 5 months now.
05-12-2026
Well, heard back from the Dealer and Corporate:
- reaffirmed that 2026.70 is the fix for my situation. 2026.50 apparently will not help, and you cannot revert to older software as X5MC4ME's user avatarX5MC4ME had proposed I research.
- with the fix now known and scheduled, appears that BMW will actually consider a proper resolution on my case. Should know more this week, hopefully.
