2.8KVIEWS
4REPLIES
2APPRECIATES
4ACTIVE PEOPLE
05-01-2026LAST POST
04-30-2026
Is there anything to worry about in the long term when installing PPF on carbon fiber parts?
I recently installed some OEM CF parts and wanted to get the air inlet ducts and sideview mirrors PPF'ed. The shop that did the PPF on my front end said that it's possible that the coating/clear can come off if ever needing to remove or replace the PPF down the road. Has anyone experienced this before?
04-30-2026
Nope. No issues. The full exterior carbon
option on my car is wrapped with PPF.
My installer has done hundreds of these.
No issue with removal or replacement.
04-30-2026
Unless the clear didn't fully cure before applying PPF, it could be an issue. I think the time frame is about a month before applying PPF if you had a respray or anything like that.
But most of the time, shouldn't have an issue.
05-01-2026
+1
Same here...jus insure all application surfaces are properly prepped & cured.
05-01-2026
Thanks for the input. Spoke to another shop and they said the same thing. From the talk I had with the owner, he takes pride in his work and is super meticulous with his work with some videos he showed me. Going to get it done next week.
Appreciate the input. My main concern was with PPF on carbon fiber as the shop told me they've experienced some clear pulling off on some CF they've worked on in the past, but that all depends on the quality of the CF. I'm gonna go ahead and give it a shot.
