601VIEWS
29REPLIES
5APPRECIATES
8ACTIVE PEOPLE
2 days agoLAST POST
05-14-2026
Web search (forums etc.) to get an understanding of the charging system has raised a few questions .. so hoping that a reasonable explanation can be offered by a forum member.
BMW says that charging (both batteries 12 & 48) occurs during breaking, coasting etc., but doesn't specifically say that 'a normal alternator' recharges whenever the motor is running.
The last iDrive update was paused due to low voltage / charge and my current understanding is that a 12v charger also charges the 48v battery .. which must be via an inverter.
Is this correct ?
BTW I've not experienced any problems other than noticing that indeed the charger sensed a low charge .. but is that only for the 12 or also associated with the 48 ?
I'd appreciate anybody's take or understanding of the system generally.
05-14-2026
The 48vdc battery can be recharged only when driving or if you have a suitable 12vdc charger on the underhood charging points. There are a couple of preconditions, though, the charger must exceed 20A and the hood cannot be closed.
In a fault condition, if the 12vdc battery gets too low, the 48vdc one will try to augment it to let you keep going, but no batteries like to be deeply discharged, and you don't want to get that battery damaged, as it's quite expensive, and in normal circumstances will last the life of the vehicle.
Some people's driving habits don't keep the 12vdc battery(s) charged, and you may then start to damage the 48v one when it tries to help the 12v one. The 12vdc battery is key to keeping the 48v one healthy.
It would probably be useful to you to use a battery maintainer on your 12vdc one occasionally, but get it fully charged first. If it has problems, it may need to be replaced.
I'm not familiar with the diesels, as they haven't been sold in the USA for years now, so there could be differences. Diesels are hard on any battery with their higher cranking currents, but the petrol versions when people don't drive as BMW engineered things vary too far from their thoughts of what's normal, end up needing a manual charge periodically.
BMW in general, does NOT charge their batteries and try to maintain them at full. So, a long drive may not help. It DOES engage the charging circuits when coasting or braking, but on a long trip when people would expect it to be fully charged, often may not happen with a modern BMW. They've been doing this for years...my first BMW in 2011 had that technology. My first battery was changed at one year under warranty, then, I started to use a battery maintainer, and the next one lasted 7 without issues.
Not sure if the diesels are mild hybrids, again, none sold in the USA. But, if it is, then keep your 12vdc battery up, or you'll be replacing the 48vdc one prematurely.
05-14-2026
^^^^Excellent info here. The 48V mild hybrid system in my LCI is great, wish it were even stronger but very noticeable as is. Really pleasing to have this additional torque in many different situations and from what I can see about a 2 MPG bump shown on the vehicles long term average display however accurate that may be.
05-14-2026
Is this correct ?
What jad03060's user avatarjad03060 03060 is correct. The mild hybrid is a great system, I have the pre LCI version of it. Since I only use mine for trips, it sits a lot and while sitting is always on a battery tender. I use the Ctek but many others will do as well.
Since my Ctek is not capable of supplying a min of 20a current, I simply leave my engine hood propped open a few inches which disconnects the 48v battery from the system thereby allowing the 12v battery to be charged by the Ctek. If you properly maintain the 12v battery by both charging and driving, the 48v battery should remain in good shape.
There are quite a few threads on the topic of batteries in this forum, do yourself a favor and search for them, they make good educational reading and will most likely dispel any battery myths you may run across. Mine is now five years old, the batteries are in great shape, no battery related issues. In a previous BMW with two 12v batteries, I was able to get 14yrs out of them simply by using a battery tender.
05-14-2026
On the Pre LCI, where is the 12v connected into the system. It's like it's missing lol
05-14-2026
Right, their pic just didn't show it but I just modified my pic and included it.. .. just for you ;)
05-14-2026
Thanks I feel better now lol. I thought maybe I didn't have a 12v battery in the rear :lol:
05-15-2026
"Battery tender/charger for 2021 M340i with 48 volt system" - seems to be one of the better threads and after 16 pages, frankly, the subject is not well understood (collectively).
Does a 20A + charger replenish the 48v battery (hood open)?
Did BMW design the car (s) with a hybrid system that is designed for stop / go conditions (whereas being semi-rural I have little breaking / coasting)?
Also to mention that almost nothing is detailed in the BMW manual ... but thanks, I appreciated the responses.
05-15-2026
Yes, if you use a 20+ amp charger the 48v hybrid battery will be charged also.
It will charge more if you are in urban areas. I'm mostly highway driving and my 48v battery is usually at just two bars except for when ending the trip it will go to three most times.
05-15-2026
When I had my MY21 X6 I drove 5 miles to work and 5 miles home. That was essentially my use of the car. I was always concerned about the batteries 12v and 48v not getting fully charged. So my thought process lead me to monitor the 48v battery charge on my iDrive and coast a lot during that drive. The LED segments on my 48v battery had 5 segments and I kept it up to 4 segments at all time. From my Internet web searching that was most likely as much as this system will charge the 48v lithium battery ( ~80% ). The 48v battery would also keep my 12v fully charged. Even with that short distance of driving in the 3 years I owned the car, I never had battery issues and the 12v was always fully charged.
05-15-2026
If your commute is stop and go in the city, all batteries will likely be sufficiently charged. It's when it may sit unused for long periods of time or you're on a major highway that is flowing freely where you're not slowing and accelerating to stay with traffic where it could be an issue.
Most people don't live where the roads are billiard table flat, so even little undulations in the road will have some charging opportunities.
But, again, IF the battery charger has at least 20A output, the 48VDC battery will also get charged...it won't if your hood is closed or it's smaller than that.
05-15-2026
Wait, if you use a charger capable of 20+amps, how will it charge the 48v battery if the hood is open? Because when you open the hood, it disconnects the 48v battery, at least that is what I've always thought.
05-15-2026
It doesn't disconnect the the 48v from the power distribution system it just shuts down the connection from it outward. In other words, the charge from the terminals can be routed to the 48v battery.
05-15-2026
Where are you seeing battery status? In iDrive?
05-15-2026
You wouldn't want to just leave a 20A or greater battery charger on the vehicle non-stop when not driving it. But to actually charge the 48vdc battery at home, it needs to be at least that large. If you use one that is smaller, it does not charge the 48vdc battery. But, if you can keep the 12vdc batteries charged, it should not, while off, tap the 48vdc one and LiOn tend to have a fairly long life when treated well.
Most battery maintainers are in the 1-6A range, with many around 4A or so. You need an honest to god battery charger to interact with the 48vdc battery, or it is disconnected when the hood is opened.
Basically, in normal use, the EV motor can get switched into alternator mode when you are braking or decelerating...that output is of short duration, but much greater than the battery maintainer that some use.
If the 12vdc battery is fully charged through a battery maintainer, it will not normally look to augment itself with the 48vdc one while not in drive ready state; i.e., in the ON position.
The battery logic does a bunch of things which is why you need to use the specified terminals under the hood, and not try to directly charge one of them on the battery itself.
The 48vdc battery is really intended to last the life of the vehicle whereas, the 12vdc ones, probably not. That will only happen if you treat it well. I've heard they cost like $2K to replace (I have a PHEV, so don't have that system, so am not sure).
05-15-2026
.... and that's why a forum (like bimmerpost) is important these days!
My drives are virtually always 'on the flat' and a majority of the mileage is ~ 10 or so hours (Australia is pretty flat). In my second year of ownership I now have a better understanding of the hybrid and can even operate the climate control!
Time to look after my batteries ... VCR Remote next!
05-16-2026
Ya know, just when you think you understand it.. .. this happens :(
Ok, its actually the opposite than what I thought.. so, opening the hood tells the charging system that you are charging the batteries (both of them) and they are now connected via the internal system circuitry) even though you are only supplying 12v, the DC/DC converter then jumps into action for the 48v battery, if needed.
When the hood is closed and the car is turned off, the system disconnects the 48v battery from the engine compartment charging terminals. This disconnection prevents the 48v battery from discharging during periods of non use/storage.
How's that, is this correct?
05-16-2026
What about charging the dual storage battery on the older models? I use a ctek 5.0 but not sure if it charges it
05-16-2026
This was on my MY21 (sold) and I don’t remember how I got the 48 volt LED segment display. I always drove in sport mode
05-16-2026
Everything is correct except the last sentence. The 48v is still connected to the electrical system and can become discharged when it charges the 12v battery.
05-16-2026
I believe he's referring to the Eco Mode display where it shows a graphical representation of the energy flowing out of and into the battery as you drive. I'm going from memory but try driving in Eco Mode, then on the LCD screen poke around till you see it, I forget the exact name of the display.
Found this pic online, looks like its called Energy Flow.
05-16-2026
It is under Car->Driving Information->Energy Flow. The screen is not associated with the Eco Drive mode and is available and active in all drive modes.
