12-26-2019, 07:49 AM | #45 |
Rep 3,242
I did this exact thing with both of my homes which were new construction. Not only does it help in tracking down how the cabling is run, but also the mechanicals such as plumbing. And it really came in handy with my primary home when I had some renovations done. The architect needed to know how a certain area of my house was framed. I happened to have video of that section and that was all he needed to come up with the appropriate plans.
12-26-2019, 07:50 AM | #46 | |
dances with roads
4763
Rep 4,101
I took pictures of the garage walls, post-wiring and pre-drywall, so that I'd know where the wires ran. |
pennsiveguy3552.00 |
12-26-2019, 08:01 AM | #47 |
Rep 158
My house was built in 2007 and I'm very thankful that the original buyer put in 2 x Cat5e and 1 x RG6 in every room. I run everything I can over gigabit ethernet and even go out of my way to buy devices that have ethernet like my smart TV and Roku. I also have some PoE cameras where I used a flat ethernet cable to run under the window frame to the outside. You don't really need to run a ton of lines to each room because if you need more ports like in an office, you can just daisy chain a $20 8 port gigabit switch.
It has been running rock solid for the past 12 years and I don't think wireless has caught up yet. I tested my laptop using iperf3 over an AC1750 router on the 5GHz band and it only got around 130 megabits. Also, the 2.4GHz band drops out every time I use my microwave. |
12-26-2019, 08:03 AM | #48 | |
Rep 3,242
For my data center, the slowest connection between switches are 10Gig running over SFP+ DACs. I do have 2 twisted pair copper connections going between one switch in my data center to a 10Gig switch in my office running 10Gig in a LAG. All other connections between switches are 40Gig over QSFP+ DACs. My servers are also 40Gig attached. And I do have one switch which is 100Gig. |
12-26-2019, 08:09 AM | #49 | |
Rep 3,242
But as far as I know, because Category cabling is low voltage, I do not think it's against code to have couplers in the wall nor does it require a junction box. But I think it varies with locality because I seem to recall either where my primary house is or my vacation home that the county required any runs of low voltage wiring in the home to also be permitted. But can't remember as this was years ago. |
12-26-2019, 08:18 AM | #50 | |
Rep 3,242
Also you cannot connect more than 1 Ethernet connection to a switch that is not a managed switch. The reason is you'll introduce a switch loop which will in short order bring your network to its knees with infinite frame flooding. Even with managed switches on both ends, you have to either configure spanning tree or LAG to allow this to work. |
pennsiveguy3552.00 Stubbie Blue146.00 |
12-26-2019, 09:00 AM | #51 | |
1047
Rep 1,564
2021 Jeep Grand Cherokee SRT Black 2006 Ford Mustang GT Convertible (show car) |
wdb4762.50 |
12-26-2019, 11:21 AM | #52 |
Rep 1,062
Drives: F15 xDrive50i M-sport
Another thing to remember if you're doing any of the wiring yourself is to keep the low voltage wires away from the high voltage conductors. Don't run your UTP wires right alongside or in the same conduit with high voltage wires. Avoid running them parallel, and if you have to do so then make sure there's 6" or so between them. The magnetic field from the high voltage conductors can create noise in the UTP circuits that'll make them flaky. It'll be hard to diagnose and even harder to fix.
If you're having a contractor do the wiring, make sure they do it right. Don't count on the inspector to catch their errors, because there are some inspectors who don't give a rat's hindquarters about low voltage wiring and don't inspect it diligently.
2017 F15 xDrive50i M Sport | Superformance GT40 Roush 511 IR FE
12-27-2019, 06:09 PM | #53 | |
1192
Rep 1,550
To the OP and not that it hasn't already been covered but what to do really depends on your lifestyle, preferences, and construction type. I don't mind WiFi for some device use (e.g. Ring, tablets, etc...) but for things like IP cams...I go hardwired. It's not that hard to jam WiFi so it becomes useless for security if you have WiFi-only security stuffs. Run empty conduit and PVC in a wall(s) so you can add wiring in the future w/o having to break into drywall. I have a 2" EMT pipe running from my primary breaker box to a large distribution box in my attic. This greatly minimizes the work to pull new wire for additional AC circuits in the future. I also have a 2" PVC pipe run from the basement to the attic for low voltage (same idea as the 2" conduit). These + the pre-drywall pix will make life easier. If running Eth wiring, go at least Cat6. Like zx10guy said, you can still run 10GbE over it for shorter runs and it should be plenty good for most home owners. Go Cat6 for coax. Pre-wire for security system if you think you might want one. Same for in-wall speaker wire.
- Jeff
bosstones' flickr |
12-28-2019, 12:57 AM | #54 |
2JZ-GTE
3072
Rep 4,022
I'd run fiber to all the rooms. Copper wire just doesn't have the throughput that fiber does.
12-28-2019, 06:48 AM | #55 | |
Rep 3,242
Other than a desktop which you can add in a fiber NIC, you'll be looking at buying media converters to allow devices to connect into the fiber plant plus the expense of the fiber itself and the network hardware, it just makes no sense in a home setting. I'm not your typical home user and I have all the networking equipment to utilize fiber. But I'm not running any fiber except in my server rack where Fiber Channel requires the use of fiber for my SAN. |
12-28-2019, 08:48 AM | #56 | |
dances with roads
4763
Rep 4,101
I had people telling me to pull fiber back when I did our house in the early 2000's. I still wouldn't be using it. It sounds sexy but I agree that it is largely a waste of money for 99.997% of residential situations. |
12-28-2019, 10:47 AM | #57 |
11818
Rep 23,187
Dont forget the wiring for heated stripper pole.
hubbahubba9030.50 |
12-28-2019, 01:02 PM | #58 | |
Rep 3,242
But as I've said, I would run Cat6a if you're doing any new cabling install. One of the key things about the various speed protocols is the frequency requirement of the cabling. Cat6 is certified up to 250MHz but can still carry 10GigE up to 55 meters. Cat6a is certified up to 500MHz. And Cat7 is certified up to 600MHz. The incremental improvement to go to Cat7 over Cat6a is to me not worth it given the uncertainty of what the next IEEE spec will be for the next fastest Ethernet speed will be. Most likely this will be 25GigE. And when will 25GigE become affordable enough for home use is to be determined. But I can safely say it's probably at least 10 years out. |
12-30-2019, 02:22 AM | #61 |
2JZ-GTE
3072
Rep 4,022
Sounds like some serious storage =)
12-30-2019, 09:35 AM | #62 |
Rep 3,242
It is. The storage array is a Dell/Compellent SC4020 with 25TB of storage. It was 50TB but I decided to offline the DAS shelf because I didn't need all of it online at once. Main reason why I'm running the SAN is for shared storage for my VMware vSphere 6.5 cluster. I need shared storage to be able to do various things such as vMotion. I have some other SANs in my collection which I had used for other projects: NetApp FAS3020, Equallogic PS6100 and PS4000, and a MDS 3800i.
12-31-2019, 12:55 AM | #63 | |
2JZ-GTE
3072
Rep 4,022
vreihen1615631.00 |
12-31-2019, 11:56 AM | #64 | |
Rep 2,548
Drives: '08 135i, '88 325is
Damn, that is some serious storage for a home network. I use similar equipment in my company's data center.
Delivered in Munich, broken in on the Nurburgring.
12-31-2019, 04:12 PM | #65 | |
Rep 3,242
Not to mention, I'm a tech nerd and love doing this crap on my spare time. |
01-02-2020, 01:05 PM | #66 |
2006 TIME Person Of The Year
9720
Rep 6,445
Corn, make sure you're having them run at least 2 (I'd run 3) CAT6e to every TV location. You don't want to be relying on WiFi for streaming video. This should be considered a standard setup in 2020. I'd go so far as saying I'd be concerned if your low-voltage contractor didn't recommend this without your suggesting it.
