12-18-2021, 09:32 PM | #45 |
Fueled by Recycled Dinosaurs!
650
Rep 1,180
Drives: F06 M6
Fantastic!
2015 F06 M6 Silverstone Metallic II, Individual Full Leather, B&O, Night Vis, CCB, RKAutowerks (CP Rods/Pistons, DI Cams, CF Intakes, Coated DP's & Billet Diff Brace), InfinityAuto Turbo Inlets, Mishi Oil Cooler, JB4, XHP S3, BM S3
01-20-2022, 10:46 AM | #46 | |
Rep 214
Rebuilt Engine Installed
I need to drive about 300 more miles and then the break-in oil change is due at 1200 miles. Mike, the General Manager at RK Autowerks, has always been very responsive to my emails and calls. He suggested that in Maryland, I should use 5W-40 or 5W-50 synthetic motor oil due to the cool winter temperatures. He mentioned, that in Texas, they use 15W-50 because of the higher temps. Update: NAPA has a sale on Mobile 1 Full Synthetic 5w-50 at $5.99/quart. Per RK Autowerks recommendation, my driving for the first 1200 miles has been gentle with no consistent periods of the same rpm. I have kept my rpms below 4200 rpms and have not gone beyond 1/2 throttle. Now I’m looking forward to an early spring and hopefully getting out to meet others from the forum. Let me know if any of you are interested in renting an airport in the DMV region for roll races. If this works out to be an annual event, I want this to become a fundraiser for cancer research.
Current:2021 Mazda MX5, 2013 BMW M5 Tuning Tech Stage 1, 2013 Buick Encore, 2013 Chevy Traverse LTZ
Past: 2002 Jeep Grand Cherokee, 2014 BMW 550i MSport, 2005 Jaguar S-Type R, 2000 BMW 540i, 1997 BMW 540i, 1997 WS6 Pontiac Firebird, 1992 Eagle Talon TSI Last edited by 1320racer; 01-22-2022 at 03:38 PM.. Reason: Typo |
TinCanSailor650.00 |
01-20-2022, 03:09 PM | #47 |
650
Rep 1,180
Drives: F06 M6
Mike, Raza and the RK team still take time to chat back on occasion. I've got nothing but high praises for RKAutowerks
In a few hundred miles you are going to have the best ownership experience possible. I am looking forward to hear more about your progress in the days, weeks and years ahead.
1320racer137.50 |
01-23-2022, 04:40 PM | #48 |
16
Rep 33
Man, just went through this exact process, and then some. Long story short, diff mount broke, damaged diff, axles, drive shaft and gas tank. 2 months later, I have it back and doing my 1200 mile break in period. Total cost, $16k from a dealer. My cost, $500 for insurance deductible.
1320racer137.50 TinCanSailor650.00 |
01-26-2022, 02:13 AM | #49 | |
Rep 214
I just changed my oil for the break-in service and I’m just over 1300 miles now. I’m honestly afraid to go much beyond 1/2 throttle as the new AS4 Michelin rear tires just spin due to the frigid air temps. Today’s high temperature is only 29 degrees Fahrenheit. Supposedly, late next week, the forecast indicates the mid 50s so I hope to stab the throttle a few times then. I’m thinking about sending the oil to be tested for the first few oil changes. I’m just curious what they’ll find. With the new motor, it was nice not needing to top off the oil during the break-in. The oil level indicator remains completely full. The original motor drank nearly an entire quart every 850 miles when driven modestly, and swallowed an entire quart every 700-750 miles if driven aggressively. Be safe and enjoy your M5.
Past: 2002 Jeep Grand Cherokee, 2014 BMW 550i MSport, 2005 Jaguar S-Type R, 2000 BMW 540i, 1997 BMW 540i, 1997 WS6 Pontiac Firebird, 1992 Eagle Talon TSI Last edited by 1320racer; 08-05-2022 at 05:35 PM.. |
07-19-2022, 12:34 PM | #50 |
Rep 214
Consistent misfire on cylinders 1, 3, 4
I'm afraid I may have an issue with my new motor. When beyond half throttle, I get a code for random misfires and specific codes for misfires on cylinders 1, 3, and 4.
I have cleared the codes multiple times but eventually, when beyond half throttle, I receive the same error codes… random misfire and misfires on cylinders 1, 3, and 4. The new motor did have new plugs and coils installed and now has 9,200 miles. Any suggestions or ideas would be appreciated before I change the plugs and move the coils? I have been looking but have not found similar scenarios on other F10 M5s. Is a code typically seen when the HPFP is failing?
Past: 2002 Jeep Grand Cherokee, 2014 BMW 550i MSport, 2005 Jaguar S-Type R, 2000 BMW 540i, 1997 BMW 540i, 1997 WS6 Pontiac Firebird, 1992 Eagle Talon TSI Last edited by 1320racer; 07-20-2022 at 11:44 AM.. Reason: Reframed sentence for clarity |
M5Rick61854.00 |
08-02-2022, 03:51 PM | #52 |
Rep 214
Good idea! Unfortunately, my scanner is too low-end to test the injectors. I’m wondering if HPFP is failing on bank 1 (cylinders 1-4).
Bosch Fuel Pump; HPFP on Engine 2013 BMW M5 4.4L V8 (S63B44B) P/N: BS-13518604232 $131 https://www.autohausaz.com/cart
Past: 2002 Jeep Grand Cherokee, 2014 BMW 550i MSport, 2005 Jaguar S-Type R, 2000 BMW 540i, 1997 BMW 540i, 1997 WS6 Pontiac Firebird, 1992 Eagle Talon TSI Last edited by 1320racer; 08-06-2022 at 06:24 AM.. |
M5Rick61854.00 |
08-04-2022, 05:29 PM | #53 | |
61854
Rep 19,974
1320racer137.50 |
08-05-2022, 05:14 PM | #54 |
Rep 214
Problem Found And Easily Resolved
The problem with my engine not running correctly has been found and the issue has been easily resolved.
As I lifted my plastic engine cover to begin the process of changing the plugs and coils again, I noticed the hose clamp at the passenger side turbo had slid backward and off the charge hose. I re-installed the hose clamp at the turbo inlet and the engine runs normally again. Take care and have a great weekend everyone!
Past: 2002 Jeep Grand Cherokee, 2014 BMW 550i MSport, 2005 Jaguar S-Type R, 2000 BMW 540i, 1997 BMW 540i, 1997 WS6 Pontiac Firebird, 1992 Eagle Talon TSI Last edited by 1320racer; 08-06-2022 at 11:21 PM.. |
08-10-2022, 09:59 AM | #55 |
Rep 291
Drives: E46 M3 & LCI X3 35i M Sport
What a wild ride of a thread, I enjoyed reading it.
Good to hear all is well now. I got some good insight on dealing with private warranty companies. |
1320racer137.50 |
08-13-2022, 09:52 AM | #56 |
650
Rep 1,180
Drives: F06 M6
Man so glad to hear ya got it pinned down. How has the last week been?
1320racer137.50 |
08-16-2022, 11:55 AM | #57 |
Rep 214
I was back in Virginia Beach, VA with family and friends for a few days. We had some really fun times this trip.
Past: 2002 Jeep Grand Cherokee, 2014 BMW 550i MSport, 2005 Jaguar S-Type R, 2000 BMW 540i, 1997 BMW 540i, 1997 WS6 Pontiac Firebird, 1992 Eagle Talon TSI |
03-24-2024, 04:41 AM | #58 |
Rep 214
Vehicle & Rebuilt Motor Update
Hoping you are all well.
I’ve been away from the forum for a bit. I am chiming in with a general update after installing new rotors and pads, courtesy of FPC Euro’s lifetime warranty. I have driven over 38,000 miles and the rebuilt motor continues to run well and uses no oil. I no longer experience “finicky” drivetrain errors do to plugs or coils. I have not needed to replaced plugs and coils, which is often recommended every 10-15k miles, when running a tune. So far my stage 1 tune with downpipes has been enough fun me. I am reluctant to let others drive the car. Even when the road is warm and dry, I feel accelerating aggressively below 60 mph is very often a handful. When not traction limited, and with a Density Altitude (DA) at or below 2,500 feet, the vehicle runs an okay 1/4 mile time. Unfortunately, our F10 M5s are not designed to launch well. The majority of 1/4 mile runs I manage are between 11.5-11.9 seconds between 124-127 mph. My best 1/4 mile pass so far is 11.2 seconds at 129 mph. It is spring break here in Maryland this week and I hope the weather cooperates to allow me to check the suspension, motor and trans mounts and, replace the rear differential fluid. It is time to enjoy some road trips and maybe go to a few tracks.
03-25-2024, 09:25 AM | #59 | |
650
Rep 1,180
Drives: F06 M6
I am considering CF driveshaft and forged axles to help with the durability of the car when it comes to launching. Post up some track shots or video.
