01-17-2023, 11:23 AM | #45 |
Rep 100
My pleasure! Best way to see the CCS plug is to drive to one and actually look at the plug. You’ll see immediately how it is different.
Also, the BMW nav map shows charging locations. So if you don’t already have that turned on it’s a helpful feature. I find it faster and easier than fiddling around with PlugShare in Apple car play mode. |
01-17-2023, 11:58 AM | #46 |
Rep 8,888
Drives: eVeRyOnE mAD!
I recently added a second JuiceBox 40 EVSE to our garage after my wife picked up her 530e. we first tried sharing just the one JuiceBox, but that got old within a week. what’s great about the JuiceBox is they can share the same circuit through their Load Sharing program, so I didn’t need to call an electrician for a second install. more details here:
https://www.bimmerpost.com/forums/sh...php?p=29738966 |
Jrg317023.00 |
01-17-2023, 01:41 PM | #47 |
Rep 898
I picked up a used Chargepoint Home Flex for $560.
Overkill for the 45e? Absolutely, but I figure I can uninstall it later, and if I get a faster charging EV I can use it then. |
01-17-2023, 02:09 PM | #48 |
Rep 3,760
Chargpoint flex is a good EVSE. Sure one of the more expansive ones. I like it better than Juicebox that I also have two reasons 1) same apps as I used at work to manage charging. 2) CPF has a much more pliable cable than Juicebox. Even in Cali mild temperature, say 35F at night, Juicebox cable get very stiff. Coil/uncoil the next morning is a lot harder than Chargpoint one.
2022 G05 B58/PHEV
+ a few very old BMWs |
01-17-2023, 03:52 PM | #49 |
Rep 6,946
Clipper Creek has a two cable auto-sharing EVSE if you need two...it's cheaper than buying two EVSEs and having them installed. That's assuming your panel has enough capacity for two in the first place. https://clippercreek.com/?s=dual+output .
The cables are one of the more expensive items in an EVSE. |
01-17-2023, 06:41 PM | #50 | |
Rep 8,888
technically, my panel doesn't have enough capacity for two separate EVSE circuits, but JuiceNet's load sharing program avoids the need. i'm required to stay with JuiceBox in order to continue receiving annual rebates from my utility company. my two Juicebox 40 setup actually costs less than the CC dual EVSE: $427 - JuiceBox 40 #1 (25' cable) + annual utility bill rebates $475 - JuiceBox 40 #2 (20' cable) $250 - JuiceStand $ 85 - NEMA 14-50 splitter, UL certified ———- $1237 total** **not including the initial $500 circuit/install fee since it's shared |
01-18-2023, 07:50 AM | #51 | |
Rep 8,888
01-18-2023, 12:09 PM | #52 | |
Rep 3,760
I started with the 20ft version ordered from costco for $450+tax. It was a very good deal. But then I found if I park in driveway, 20ft cannot reach 45e charge port and close the garage door. so I returned back to costco and order directly from Juicebox for 25ft version. Back then, ambient temp is still not very low, I don't feel the stiffness of the cable. For the last couple of weeks with roof box mounted, car cannot get into garage anymore, so I park outside, and notice the cable stiffness at night and in morning. Charge Point Flex I am also using now is a very old model from neighbor. It wasn't working. I am attempting to repair it and now under some testing before returning back to neighbor. The sheathing of the cable is a different material, more of rubber than TPU like as in Juice box. CPF cable is also thinner. Together, it feels softer. In colder temp, it doesn't doesn't retain shape as in Juicebox cable.
2022 G05 B58/PHEV
03-15-2023, 10:43 AM | #53 |
Rep 1
Need guidance on Level 2 Charging options for 2023 Xdrive45e
Hello,
I just bought a new xdrive45e. We have a 240V 14-50 outlet on a 50A circuit that we had installed for another EV. Can we also use this outlet to charge our Xdrive45e and if so, what would you recommend as a level 2 charger we could buy to plug into it? |
03-15-2023, 10:50 AM | #54 | |
Rep 179
If you want to charge both cars at the same time you could get something like 14-50 neocharge splitter, and slow charge both cars at the same time at lower Amps Ie divide 40amp to 20ampa for both cars or less depending on how much max they can handle. You’ll need two EVSE to do that. |
03-15-2023, 11:01 AM | #55 | |
Rep 8,888
03-15-2023, 11:27 AM | #57 | |
Rep 8,888
looking at your previous posts, it appears you don’t own a 45e (or 50e yet). please be mindful of your recommendations. this mistake could’ve had tragic consequences. |
03-15-2023, 11:42 AM | #58 |
Rep 6,946
Many EVSEs come with a cord attached so you can just plug it in, or with a pigtail so you can hardwire it to the power - they are identical internally, and you often pay a bit more for the cord with a plug on it rather than just a pigtail.
First, check with your local utility company...some offer special deals if you purchase specific EVSEs. As long as you buy an EVSE meeting the J1772 standard (common to all EVs sold in the USA except for Teslas, it will work. With a 50A circuit, you can buy up to a 40A device since the code wants to derate the circuit to 80% for things that could run continuously for hours to ensure things don't overheat. If you read around, you'll find lots of choices. Personally, a rugged, simple choice I have had since 2014 is made by Clipper Creek. At the time, they were one of the few made in the USA that had a UL certification. Lots more choices out there. Note, there's no issue using an EVSE that could supply more than the X5 could use, but an EVSE should never be wired to a smaller circuit than what it could supply to the vehicle. The thing will work just fine feeding a smaller device than it's capable of just like plugging in a cellphone power adapter into the wall that might be able to run a space heater...two very different loads, same wiring. An EVSE is a fancy power cord with some smarts. The charging is IN the vehicle, it's not done in the EVSE. If you think you might end up with two EVs or PHEVs, there are a few out there that can share the load between two vehicles, then when one finishes, bump up to its max for the other. |
03-15-2023, 11:55 AM | #59 |
Rep 8,888
what’s your other EV? knowing may help with specific recommendations
03-15-2023, 11:57 AM | #60 |
Rep 6,946
Even if you have a Tesla...there are adapters that would let a Tesla (acv only) EVSE power a more common EVSE with J1772, and vice-versa...charge a Tesla from a J1772 plug.
03-15-2023, 01:05 PM | #61 | |
Rep 3,760
Many 240 appliance actually do that internally to use 120V to power low voltage portion of the electical, say control logic, wifi, lights ... and only use 240V for heavy lifting, such as heating (stove/water heater) or AC compressor ...
2022 G05 B58/PHEV
03-15-2023, 01:06 PM | #62 | |
Rep 179
PSA no advise regarding what kind of cables, breaker, plug or installation advise- consult certified electrician for that. |
03-15-2023, 01:38 PM | #63 |
Rep 6,946
For home recharging in the USA (ACV), there are really only two choices:
- Tesla - J1772 (everyone else) and, there are adapters that can convert from one to the other (often, less than a $200 extra) The X5 45e and upcoming 50e cannot do DC fast charging of which there are three varieties used in the USA - Tesla - J1772 CCS - Chademo (mostly on some far western vehicles) There are no adapters to go between them, but some locations may have multiple cords on them with the plug you may need. This choice is not generally something a typical homeowner would be able to support, both for the infrastructure that isn't available to many homes, and the cost of the hardware. Again, an EVSE is like an extension cord while CCS and Tesla fast chargers, are a high-voltage DC power supply. Right now, about the biggest one you might find can supply up to 350Kw, but most are smaller. A vehicle is limited using ACV via an EVSE by its internal power supply, and in the 45e, that's a 3700W device (actually, it's 16A)...the 50e is a 7400W device, at least as supplied in the USA (more if there's 3-phase power as the norm). Since power=volts*amps, and amps is the limiting parameter, that can help you learn how the different voltages affect the power available on the inlet. |
03-15-2023, 02:15 PM | #64 | |
Rep 8,888
03-15-2023, 06:05 PM | #65 |
Rep 63
I installed the outlet for charging my 45e which should be arriving later this month. I had decided to purchase a 16 amp 240 volt level 2 charger since this is the maximum charger that the 45e can handle. I spent about $130.00 at Home Depot for everything I needed and it only took about an hour to do a 45 foot run from my breaker box to my garage. I decided not to plan for future expansion as I may be moving in a year or 2 and I usually keep my cars for 3-5 years. The charger I bought was AxFAST Level 2 Portable Electric Vehicle Charger 16 amp it was on sale at Costco earlier in the month it also came with a adapter to plug into a closes dryer outlet in addition to the 240 v 20 amp plug as well at the 110 adapter if needed, it cost around $50 more than similar chargers on Amazon but this company been around for 20 years and is a US company even though it’s made in China like they all seem to be came with a 2 year warranty and Costco backs items they sell with a liberal return policy. Looking forward to my first charge. From what I read it will around 5 -6 hours if the battery is depleted.
nZtiZia4769.00 |
03-15-2023, 06:15 PM | #66 |
Rep 6,946
Yeah, that will max out the 45e. But, I look at it this way, having one in the house when you sell could end up being a plus as more and more people will be needing one as time goes on. The wiring is certainly less expensive to handle 20A versus 40-50 or more! And, not knowing your power panel's status, 20A may be the best or only choice without costly upgrades. When I put mine in, I would have preferred to wire it to handle a larger unit, but that would have entailed a VERY significant and difficult service upgrade.
And, yes, unless you just came off an extensive highway trip that got everything quite warm, or you let the thing cool off to really frigid conditions, both situations can slow the recharging as it either cools things off, or slowly warms them, 5-6 hours is what it takes. Most people probably don't run the battery down all the way on a regular basis. On one long trip last summer, (a bit over 400-miles, mostly non-stop on the interstate), the cooling fans ran for about an hour before it actually started to recharge. |
