08-10-2021, 09:41 PM | #89 | ||
Rep 51
Do some search and clear your basics before even touching anything on your car. If you are not sure what you are doing my advice don't touch as there is lot of potential to brick your car. We are here to help but not to help brick your car. Refer to the starters guide and then take tiny steps. |
08-10-2021, 09:41 PM | #90 | ||
Rep 2,610
Do you have ESysX (not just ESys) of a version modern enough to map whatever your ISTEP is? If not, that's your next research step. Assuming you'll decide to continue, you will need ESysX. Once you understand above two items, the step 2 instructions will be obvious.
Heimdall136.50 |
08-10-2021, 10:29 PM | #91 | |
Rep 28
08-10-2021, 10:33 PM | #92 | |
Rep 28
that's why I'm asking for a video explanation now |
08-10-2021, 11:00 PM | #93 | |
Rep 28
https://www.photobox.co.uk/my/photo/...d=504038669457 Last edited by Abdulllh; 08-10-2021 at 11:07 PM.. |
08-11-2021, 11:16 AM | #94 | ||
Rep 2,610
11-25-2021, 04:39 PM | #95 |
Rep 62
Hi experts,
I did follow your guidance on coding the anti-dazzle feature but get stuck with the FDL. I did remove 5AP and VO coded the mentioned SVTs. I read all coding data (from the top of the SVT tree) and went into the FDL editor and opened the *40F9*.NCD after clicking on "FDL Code" in the coding section. My issue is I don't get the cheat codes displayed even I got the "Auto fetch" on. In the window it says "0 codes found for this ECU" in red. Any idea what went wrong? I use ESYS 3.28 with PSdZData 4.33.32 and the Premium Launcher 2.8.2 Build 155. |
11-25-2021, 05:59 PM | #96 |
Rep 62
I see that I don't get the proper functions displayed while editing the ncd file for 40F9. Can this be from a faulty PSdZData file? I did not get any error while VO coding nor reading the code from the KAFAS4 module.
12-21-2021, 01:28 AM | #97 | ||
146
Rep 345
Hello, I did VO coding for the modules, however when I go to KAFAS to code FDL, I cannot find these params (COUNTRY_VARIATION, C_FLA_BS_ENTER_THRESH, C_FLA_BS_EXIT_THRESH). Where exactly are they located? Search in ESYS doesn't find anything either Update: Looks like esys launcher doesn't map pzdata correctly. Installed updated version (pzdata light, new launcher) - problem still exists. I don't see param names, only numbers. Last edited by mlurker; 12-21-2021 at 03:04 AM.. |
12-22-2021, 03:39 PM | #98 |
Rep 2,610
For everyone having trouble with FDL coding, the reason no one is responding to you about still using Launcher Pro is because most of us are tired of it and it has been discussed ad nauseam across most forums (including here).
In summary, the current (as of Dec 2021) chaotic situation is: - Launcher Pro is dead for G05 onwards — don't try to use it, don't try to acquire it, you will be wasting yours and everyone else's time and money trying to do so - ESysX is really the only remaining FDL coding option, BUT … - ESysX development (including keeping up with the mappings) has been derailed for a few months now due to the death of one of the developers; however, the remaining ESysX team appears to have regrouped and is progressing on a cloud-based ESysX variant; that is not in general release yet and it is not clear when it will be, but it is in active development
GrussGott18207.50 |
12-22-2021, 08:18 PM | #99 | ||
Rep 75
Drives: 2022 X5 4.5e
I lost a few key things with the recent I-Drive update and an having them recoded tonight. They insist on recoding everything that was originally done to make sure everything functions. They will do a recode for $50.00. Great value and Superior customer service. My contact is Steve Ma, steve.ma@cmbsolutionsltd.com. I have no connection with them other than being a very satisfied customer. And everything works! https://www.codemybimmer.ca/g-chassis-coding/
TE Moore
12-23-2021, 01:45 PM | #100 | |
146
Rep 345
12-23-2021, 08:16 PM | #101 | |
769
Rep 1,811
Edit: I immediately disabled remote software upgrade as I have no plans of upgrading only to recode my car again. My car is on 11/21.50 |
12-23-2021, 09:24 PM | #102 | ||
Rep 2,610
12-23-2021, 09:40 PM | #103 | |
Rep 224
12-23-2021, 09:41 PM | #104 | ||
Rep 2,610
Sample57.00 |
12-23-2021, 10:18 PM | #105 | |
769
Rep 1,811
Just saying one shouldn't make a blanket statement that LP is dead. Perhaps yes from the perspective of TM. Some of us still use the ongoing development and it works (a quick search on the forum has others reporting use of "newer version" of LP.) I've FDL coded a bunch of stuff on my car with it. |
12-23-2021, 10:21 PM | #106 | ||
769
Rep 1,811
12-23-2021, 11:34 PM | #107 | ||
Rep 2,610
Did TM release his code and signing system into open source? If not, how is it possible for others to carry on his work? If not, calling the alternate developments by the same name is just adding to the already massive amounts of chaos around this.
12-24-2021, 12:09 AM | #108 | |||
769
Rep 1,811
12-24-2021, 12:13 AM | #109 | ||||
Rep 2,610
