11-23-2022, 09:48 PM | #89 | |
Rep 26
Drives: 2022 X5 xDrive40i
You can honestly drive yourself crazy with range stuff. I think plug-in hybrids are a smart move right now, especially if most of your average driving is commuting to the office with occasional longer trips. My unsolicited advice is not to pay much attention to the range. Drive it and enjoy it... punch it occasionally or all the time if that is what you like. |
11-23-2022, 10:23 PM | #90 | |
Rep 213
One thing about the L2 charger: For this car, there's no point in putting in more than a 220V-20A circuit because the car can't use any more amps than that. Only reason to put in a higher amp circuit is if you think you might get an EV that can pull more amps. Also, there's no point in spending $600 on a fancy EVSE. I got this one for $180 and it gives me a full charge in 5.5 hours just fine on 220/20.
X5 xDrive 45e 2023 / Mineral White / Tartufo / Anthracite-Brown Poplar
11-23-2022, 11:03 PM | #91 |
Rep 6,946
Depending on how far the wiring must run, the labor is pretty much the same if you run 12g or 6g (but the price of the wire itself will go up!). It highly likely your next PHEV or EV will accept more power. You can install a smaller EVSE onto the heavier wiring, but you can't put a bigger one on smaller wiring. So, depends somewhat on how long you think you'll be there what you install. There's something to be said for a larger EVSE, drawing less power, that might last longer, but that mostly depends on the quality of the unit you select.
11-24-2022, 12:09 AM | #92 | |
Rep 3,751
To answer the highlighted part, yes 45e show this, but it is a misleading number. It uses the total milage driven (EV + ICE), divided by kWh usage. So if you did some mixed driving, you will see a very high number, makes you think you beat Tesla in mi/kWh.
2022 G05 B58/PHEV
+ a few very old BMWs |
TX-BMW15.00 |
11-24-2022, 12:11 AM | #93 |
Rep 3,751
Mind sharing your trip computer screen shot "since factory" setting?
2022 G05 B58/PHEV
TX-BMW15.00 Flyboy201754.00 |
11-24-2022, 08:00 AM | #94 | |
Rep 787
Being new to hybrids/EVs of any sort, it has taken me 6 months or so to get to this point. I now know for certain that I can do my daily chores on electric only, no matter what the reading shows, and if for some reason I run out of juice, the machine will just flip into hybrid. And I d love driving the car, esp in electric mode. It is so quiet and smooth. The ICE loaner the dealer gave me felt archaic. YMMV |
11-24-2022, 08:29 AM | #95 | |
Rep 26
I think you have the right mindset on range. If you didn't watch the estimated range in your ICE, then don't do it now. It is a little different for a full EV because you can't pull in and charge everywhere, but no reason to worry about it much with the 45e. |
11-24-2022, 08:41 AM | #96 | |
Rep 26
A 60A breaker (assuming you have the capacity) and appropriate gauge wire will be nice for the future (48A charge rate on supported chargers). I believe that you get a one-time tax credit (not full credit) for installation and charger, too. |
11-24-2022, 09:31 AM | #97 | |
Rep 213
Generally the smaller of 30% or $1000. Disclaimer: I am not a tax expert.
11-24-2022, 11:25 AM | #99 |
190
Rep 367
Typical usage for me two days ago. (Pure EV driving; no ICE.)
11-24-2022, 12:17 PM | #100 |
Rep 3,751
I saw this from you a few times, but never the trip computer from “since factory”. It is life time consumption, representing the real life usage. In your case 13k miles. The range number from EV mode can be all the place. The can archive 50-55 here if I choose to.
2022 G05 B58/PHEV
TX-BMW15.00 |
11-24-2022, 12:57 PM | #101 | |
190
Rep 367
I have posted since factory actually on another thread. Cannot remember which one… My factory results are skewed to a lot of ICE driving as we took the vehicle on a cross country trip. Actually makes miles/kw look extremely high (double digit high); whereas the 2.7 miles per kw is VERY representative of our EV usage around town. Going on memory we're probably about 9,000 ICE and 4,000 EV. PS- You and I have already danced this dance. My factory numbers are posted in thread "45e and auto journalism" (or words to that affect) mpg results. Last edited by LarsOtium; 11-24-2022 at 01:07 PM.. |
11-24-2022, 01:05 PM | #102 | |
Rep 3,751
2022 G05 B58/PHEV
11-24-2022, 04:44 PM | #103 |
Rep 185
Just finally was able to get back to 100% on stock charger. App shows 27 while in car says 24. Its not crazy cold either and car has right now about 80 miles. The capacity shows full.
I went and got a 320$ charger but after looking back on the thread Im thinking to down grade, but I already have a 20a circuit to 14-50R. So looking maybe for a cheaper solution for that. Or maybe change the circuit. |
11-24-2022, 05:01 PM | #104 |
Rep 6,946
I think the X5 shows the amount put into the batteries, but the app might take into account power that was used to provide cooling and that lost in the conversion process. You'll always put more watts into the vehicle than eventually get into the battery. That depends some on how hot/cold things are and the capacity of the EVSE. A level 1 device is less efficient getting the high voltage DC needed to charge the batteries versus starting with 240vac versus 120vac.
11-24-2022, 05:39 PM | #105 | |
Rep 185
I honestly never paid attention I would be able to go from O to 100% over night and never even cared, there was a point where I was preping to buy a L2 and did install outlet and circuit but only at 20Amps and never went thru with getting a charger this was few years back as getting charged over night was more then sufficient. Looking at specs its a 11.6kW so at 120 at 10amps over night about sounds about right. Here at 24kW closer to over double sounds right. |
11-24-2022, 07:06 PM | #107 |
Rep 6,946
Drag goes up non-linearly with speed. IOW, the faster you go, the less efficient.
Driving smoothly versus small speed-up/slow-downs when possible, even with regeneration affects range. Precondition while plugged in when you can. Using the seat heaters versus keeping the whole cabin warm can make a difference, and having the rear seat heater option can help keep people from complaining back there. Acceleration isn't a big energy user, but overshooting and then having to slow down is. An ICE tends to be less efficient during acceleration, but an EV motor isn't significantly different in overall usage. Don't rush up to a stop sign or stopped traffic and use the brakes...regen helps, but coasting is better and you'll still be producing regenerative braking, but for a longer time. If you time it properly, you may not have to stop at all. Once the cabin is where you want it, Eco mode can help as it makes the throttle less sensitive, so fewer spikes of current requested, and the HVAC will be less aggressive. Or, just drive and don't worry about it! |
11-24-2022, 08:49 PM | #108 | |
Rep 185
Thank you. |
11-24-2022, 09:33 PM | #109 | |
Rep 8,873
Drives: eVeRyOnE mAD!
11-25-2022, 12:15 PM | #110 | |
Rep 185
On a 20amp circuit. But I can just add a 50amp circuit and I have the plug already, or replace the plug and I still have dedicated 20amp outlet. Im looking at chargers and thinking to get a lower 16amp one for about 100$ cheaper but not smart at all and only 240/16amp. While I got a smart one for 300$ with 110-240 10-40amp (not that this applies much here.) Any recommendations for a cheaper smart one with low 16/min/max/amp you guys use or see in sale now? |
