10-03-2019, 12:59 AM | #111 |
Rep 272
Didn't try after upgrading to iOS, will try today. I am already on 13.1.2, so I guess issue may have been resolved.
10-07-2019, 07:55 AM | #112 | |
Rep 1,449
The BV app on my iPhone and iPad were updated and I can connect to the BV with no problems.
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS retired; 2008 X5 4.8i; 2012 X5 5.0i retired, 2004 X5 4.4i retired R360c + EL, V1G2 + V1Driver, Uniden R8 |
10-07-2019, 09:59 AM | #113 |
Rep 494
I've been having the same problem as you. I fiddled around a bit and can't get it going yet. I'm not sure if it's a iOS issue or something else. I have tried disabling the wi-fi assist and playing around with the location setting for the BV app but still nothing. let me know if you figure it out and I'll do the same as well.
2019 BMW X5 40i Phytonic Blue/Tartufo
2016 BMW X3 35i M-Sport, Dinantronics (sold) 2012 BMW X3 28i (sold) |
10-07-2019, 09:45 PM | #114 |
Rep 419
Had the same issue last night. I couldn't find the BV forum page where I got the fix but apparently IOS13 requires that the location services is on.
Open the BV app and select BV cloud. Logout if you are using it. Click on the cross hair circle within the map. The app should pop up something about enabling location service. Select "while using app". After this it started working again for me.
2019 X5 40i M-Sport
07/2020.54 -> 11/2020.50 -> 03/2021.50 -> 07/2021.85 [All OTAs] |
bichoo280.50 |
10-07-2019, 10:12 PM | #115 | |
Rep 419
2019 X5 40i M-Sport
10-08-2019, 07:27 AM | #116 |
Rep 419
Version 2.97 is out (2 days ago per app) which fixed the same WiFi compatibility issue with ios13. That must be where Xeno updated to.
2019 X5 40i M-Sport
10-08-2019, 03:35 PM | #117 | |
Rep 163
Thank you for letting us know. Will try tonight with my new iPhone 11 , remote software 2019/.55 and BV newest firmware. Will let you guys know if this work. Thank you
BMW X1 F48 2017 sold
BMW X5 G05 50i 2019 sold BMW X5M comp F95 2022 Mini clubman JCW F54 2019 |
10-09-2019, 12:54 AM | #118 | |
Rep 494
10-09-2019, 01:28 AM | #119 |
Rep 163
I can connect to BV again now. Problem solved!
Thanks again
03-08-2020, 09:26 AM | #121 |
JoseSportM
415
Rep 371
Don't know if it will help but you guys should use z44 in the front fuse 31 and Z2*2b in the rear fuse 2 and ground z10 in the front.
This is what BMW use to install the bmw advance car eye on G05. I will install myself the BlackVue DR750S-2CH with power magic pro |
03-14-2020, 10:20 AM | #122 | |
Rep 481
I watched the DIY from barrowdad and he had to enlarge the hole to get the USB cable through. I'm going to install my 2ch dashcam soon but want to avoid having to drill holes in my car. Anyone else found a good location to store the batterypack? I don't want to install it on top of the car battery (right rear fuse box). |
03-14-2020, 10:36 AM | #123 | ||
91
Rep 306
ikheetleon218.50 |
03-14-2020, 10:41 AM | #124 |
Rep 481
Thanks a lot, will use that instead of drilling holes.
03-14-2020, 10:51 AM | #125 | |
91
Rep 306
03-14-2020, 01:14 PM | #126 | ||
Rep 419
2019 X5 40i M-Sport
03-14-2020, 01:58 PM | #127 |
Rep 481
But it’s standing on top or the car battery right? Or is it only the 45e that has it’s battery in that location? In my f15, that was the spot I had my dashcam battery.
03-14-2020, 02:05 PM | #128 | |
Rep 419
2019 X5 40i M-Sport
03-14-2020, 02:34 PM | #129 |
Rep 481
Yes there is more space on the other side, but I would have to cross from right to left. I don’t want to remove the floor panels since the high voltage battery is underneath. I might be able to go via the ceiling/roof.
03-22-2020, 10:26 PM | #130 |
15
Rep 47
Does parking mode not kick in right away? I tried hard wiring mine in and keep thinking I did incorrectly but I remember the power stays on for like 10mins afterwards. Is that the issue?
03-23-2020, 07:43 AM | #131 |
Rep 419
That is correct. The switched fuses have delays (I timed about 10 minutes also) before they power off completely.
2019 X5 40i M-Sport
