05-15-2021, 06:44 PM | #155 |
824
Rep 1,799
Looking good. Just ordered a set from BMW of Atlantic City off eBay for $225.
COL(Ret), US Army Hagerstown MD 2019 X5 40i MSport Alpine White/Coffee (my 13th BMW) 2015 Mercedes SL400; 2009 Lexus RX350 |
GOLFFRR10873.00 |
05-16-2021, 03:02 PM | #156 |
270
Rep 376
I had the OEMs at first bc when I bought my 2019 X5 40i that was the only option. I switched to Thule later on and will use those on my '21 X5MC. I still have the OEM ones so if anyone wants to buy them let me know.
05-16-2021, 04:10 PM | #157 |
824
Rep 1,799
Darn. I would have been a buyer. Did you have an issue with the OEM bars? I will only mount mine when carrying my kayak. Are they noisy?
05-16-2021, 07:55 PM | #158 |
270
Rep 376
There is wind noise, but isn't too terrible and I kinda got used to it. The biggest thing for me was the Thule's are a lot lower profile and all black so I can leave them on all the time. They blend in.
05-17-2021, 09:10 AM | #160 |
10873
Rep 27,644
5k mile update on the OEM racks. No wind noise that I could notice so far. Loving them, work great
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
rmorin1249824.00 |
05-17-2021, 10:57 PM | #161 |
Rep 485
I went with the Thule Wingbar Evo because it has an all black option and blends in and just looks a lot cooler since I have the black roof rails. There's a slight whistle at around 40mph, but I'm not sure if it's cuz I don't have it perfectly straight or need to move it forward or backwards? Never had aftermarket crossbars before.
Still, you can only really hear it with the moonroof shade open and because I have the 45e so there's no engine noise in all electric mode. If the engine ever kicks in, no way you can hear it. I don't notice anything at freeway speeds. |
Wait What?421.00 |
05-19-2021, 07:17 PM | #162 |
824
Rep 1,799
Mounted the OEM bars and took a quick drive. Didn't hit 60 mph but I did not notice any extra noises with the windows up or down. I'm sure I will notice some extra noise when I strap my kayak on the roof.
GOLFFRR10873.00 |
05-28-2021, 11:58 AM | #163 |
X5 Enthusiast
462
Rep 762
Drives: 2021 X5
Hi all, trying to setup Thule AeroBlade Edge racks (7603 & 4023 kit) to go with Motion XT XL cargo box on M Sport flush rails.
I checked all the posts on this thread and tried mounting on B and C pillars, but getting little bit of whistling (first picture). However, with music it is not noticeable. Have anyone revisited their preferred rack location on the rails? Second picture is from GOLFFRR's video. He has no whistle issue, and I am noticing that his OEM rack (first rack) is mounted slightly after the B pillar. Could this be the ideal solution/location? As many suggested I am going to try this: "open the trunk and then position the box as far back as possible that doesn't affect the trunk operating correctly and then set the bars to accommodate that position." If nothing works then I'll try the tapping method on the bottom part of the rail (as a last resort), I'll report back, but also wondering if anyone found a good solution.
2021 X5, Excellence, M Sport, DHP, DAP, RSE, MW, Merino.
GOLFFRR10873.00 |
05-28-2021, 12:15 PM | #164 |
10873
Rep 27,644
I had the guys measure it based off the instructions. I would assume in the instructions it states where to place the racks for ideal support etc..??
for what its worth though, yes currently no issues. Just drove it down to SD this past week for a golf tourney and 4 hour drive no issues at all with wind noise
SmartSaves462.00 |
05-28-2021, 12:23 PM | #165 |
Rep 268
The picture is not my car but I drew arrows to where the suggested mounting points are according to the OEM roof rack instructions. It maybe different on non-Msports but if you run your hand across the inner part of the roof rail, can feel slight indents on the rubber seal. They feel like imperfection in the rubber.
SmartSaves462.00 Muto102.50 |
05-28-2021, 12:29 PM | #166 | |
205
Rep 339
SmartSaves462.00 matthew_hull65.50 |
05-28-2021, 12:47 PM | #167 | |
X5 Enthusiast
462
Rep 762
Drives: 2021 X5
05-28-2021, 01:35 PM | #168 |
Rep 6,946
The instruction manual says that there are five versions of the rails, and only four part numbers of the five have the cross-bar locations marked...but the factory OEM cross-bars are supposed to be centered on these two points (note,the bars will fit multiple BMW models):
for part numbers the front bar goes here: - 2414373, 2444243, 2444056 460mm from the front of the rail (this is for the X5) - 2444244 250mm - 2457814 280mm for the rear bar: -2414373, 2444243, 2444056, 2444244 700mm from the front bar (this is for the X5) - 2457814 650mm from the front bar On all but railing 2444243, there should be marks to indicate where to put the bars. On the OEM bars, they tell you to retorque the attachments at 500-miles FWIW, I picked up the OEM bars from an on-line BMW dealer out of NJ for $225, shipped. Last edited by jad03060; 05-28-2021 at 05:12 PM.. Reason: Fixed some typos on p/n |
SmartSaves462.00 |
05-28-2021, 03:30 PM | #169 | |
824
Rep 1,799
I have an MSport and could not find any marks on my rails to indicate install location so I used 250 and 650 mm.
05-28-2021, 03:36 PM | #170 |
X5 Enthusiast
462
Rep 762
Drives: 2021 X5
Thanks jad03060, very helpful info. The OEM roof rack part number for G05 is 82712444056 (2444056) and I don't see that on your list! I tried to match the part numbers and found the followings:
05-28-2021, 04:59 PM | #171 | |
Rep 6,946
Proper positioning can make a big difference in how quiet they are. Bars that are higher, lower, or shaped differently than the OEM ones may need a different sweet spot. Last edited by jad03060; 05-28-2021 at 06:50 PM.. |
SmartSaves462.00 |
05-28-2021, 08:32 PM | #172 |
X5 Enthusiast
462
Rep 762
Drives: 2021 X5
Took the first rack off and kept the rear rack, went for drive, rear rack still made the whistle sound (same as before, tolerable). Took off the second rack too.
Next, installed both racks (Thule AeroBlade Edge) to the BMW specs: 460mm/18.11 inches from the front edge of the rail. 700mm/27.56 inches between the first and the second rack. Mind you, Thule foots are wider than the OEM. Observations: Faint whistle is still there around 50 to 80 km/h. Perhaps slightly improved. Wind noise isn't an issue at various speed. Passengers don't notice the whistle even after I pointed it out. With music at low volume I don't hear it. The point that was made earlier on the thread to install the racks on top of B and C pillar - for structural strength/support - seems to be not supported by BMW specification. What gives?!? GOLFFRR's first rack was not installed as per BMW spec, but it works for him. Waiting for my Thule Motion XT XL cargo box to arrive on Monday. Will install and report back on the whistle noise.
05-28-2021, 09:54 PM | #174 |
10873
Rep 27,644
just checked with our service director and said they installed them based off what the specs stated in the install guide which came with the racks in the box. So that's all I can say. no issues so far, use them all the time. maybe there is a couple ways to install them based off the application you use? who knows but yea when you get the racks in the box there is a install guide so I would just follow whatever it says when you get them and it is what it is
any who I'm going to bow out of this thread I think I posted enough in here lol. hope everyone has a great weekend!
SmartSaves462.00 |
05-29-2021, 06:02 PM | #175 |
Rep 29
Drives: 2022 BMW X5 MSport
Roof rack is a addition to our 2021 and looks fantastic. I was told it wouldn’t work on prior years x5.
05-30-2021, 11:29 AM | #176 |
Rep 802
Silly question, but were all "gaps" filled on the aero blades with the included rubber trim? I don't know how much the Aeroblades have changed over the past few years, but when I had it on my Golf TDI if you didn't use the included rubber piece to fill the gap, you would get whistling noises.
Current: MB 21 X5 M Comp | '20 Z4 M40i
Past: 09 M3 Coupe DCT (sold) | 11 1M Coupe MT (sold) | 15 i3 REX (returned) | 15 X3 35xi (sold) | 16 M235xi Vert (returned) | 18 M3 Comp Ultimate DCT (sold) | MW 20 X5 M Comp (totalled) |
